Old 08-15-2003, 02:26 AM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default compresion on a SOHC
what is the compresion of a SOHC 2.5l stock engine?????
AntonioS is offline   Reply With Quote
Old 08-15-2003, 02:42 AM   #2
Thead
Member#: 16412
99 2.5RS
Slllooww Silver
IIRC (but probably not)
99- 10:1
00-01- 11:1
Thead is offline   Reply With Quote
Old 08-15-2003, 03:27 AM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
99- 10:1
00-01- 11:1
I believe the MY99's were 9.7 and the MY0x's are 10:1.
Whatever. They're around 10:1
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-15-2003, 09:21 AM   #4
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
LaterZ!
Darren!!
we have a winnah!
DanzBorin is offline   Reply With Quote
Old 08-15-2003, 11:55 AM   #5
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
yup 10.0:1.
see here
Compressed is online now   Reply With Quote
Old 08-15-2003, 02:46 PM   #6
AntonioS
Member#: 23233
2000 2.5RS-T
white
OK But what compression should the gauge read on every cylinder??
Old 08-15-2003, 04:26 PM   #7
Penphoe
Member#: 269
Ah, that's a different thing. You'll have to look that up in a service manual. There'll be an acceptable range where the numbers can vary. I"m sure someone has posted that up somewhere.
Try searching for cylinder compression or something like that.
LaterZ!
Darren!!
Old 08-15-2003, 04:54 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Are you guys talking static or dynamic compression because they are two different numbers, and the winning response mixed them I do believe. No winner yet.
Old 08-15-2003, 05:15 PM   #9
DanzBorin
Member#: 7131
2015 Outback - Croc
actually he's right... 99s have 9.7:1 and 00-01 have 10.0:1
Old 08-15-2003, 05:58 PM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Not sure about Subaru's calculations, but every time I do a compression calculator on a SOHC 2000-2001 EJ25 I get near 11.2:1
Not sure if some of Subaru's published data is wrong or if there is some other change they didn;t tell us about.
Eric SS is offline   Reply With Quote
Old 08-15-2003, 06:30 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
Actually,
1996 Phase I SOHC 9.5:1 rated at 155hp
'97-99 Phase I S&DOHC 9:71:1 rated at 165hp
'00-later Phase II 9.5:1 rated at 165 hp,
the 10.1:1 was the static compression which is higher. No idea why SOA changed which way they were reporting it, but they were inconsistent
What's my prize?
Need Suby Engine Guru Help On EJ25 SOHC Cam Question! NW OBS Normally Aspirated Powertrain 4 10-18-2006 12:28 AM
Oil fill tube to go on my sohc heads White 2.5rs Private 'Wanted' Classifieds 2 05-07-2006 02:01 PM
Trigger Pattern Group? on EJ25 SOHC Flying Subie Engine Management & Tuning 0 02-18-2006 10:12 PM
Flow numbers on my SOHC Ej25 heads Matt Monson Normally Aspirated Powertrain 33 11-18-2005 08:01 PM
Vavle Lash on 99 sohc heads? ASAP! chrismindless Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-19-2005 08:56 AM
