Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 08-15-2003, 03:22 AM   #1
Cao Cao
Member#: 40685
2003 H6-3.0 Wagon
Titanium Monotone
Default H6-3.0 Performance Parts
Hey guys, I've been looking around for a while and really can't seem to find any performance parts for the Outback's H6-3.0, except for the K&N filter. Does anyone know of any parts? I've heard that you can retrofit the exhaust for a 2001-newer OB to the same setting of that of an H6-3.0 OB. Can anyone tell me if this is true. Any help is gladly appreciated
Cao Cao is offline   Reply With Quote
Old 08-18-2003, 05:00 PM   #2
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
someone said something about a chip or reprogramming from Cobb tuning.
anders8 is offline   Reply With Quote
Old 04-09-2011, 10:51 PM   #3
Government Grant
Member#: 279401
Subaru Stars H6-3.0 Performance Parts
There are some surprisingly low cost things you can do to your H6 3.0 Outback. (Mine is a 2001 model.) First - install a K&N filter. Expect about 5% fuel efficiency improvement. Second -install a flex tube (aluminum defroster type) inside the big airbox next to the intake manifold. Stretch the tube so it sticks out the exit slightly. This will give a cold air type tube effect. Thirdly - install two vortex generators. These are those devices that make the air spin as it enters the engine. Put one at the entrance to the airbox and the other between the air filter box and the sensor in the rubber flex tube. Those two changed my fuel economy from 30 mpg to 44 mpg with a slight power improvement. Fourthly - install E.3 spark plugs. (Do it from the underside - it's way easier.) At this point I knocked 3 sec. off my 0-60 acceleration. Finally, replace the muffler. You can use the 4-cyl performance system type but have to make an adapter for the larger pipe system at the front. Auto supply stores should be helpful there. I installed a basic S/S Magnaflow 4x9 size with auto supply elbows and tailpipe for under $200. I installed the system just before the snow came and haven't measured the acceleration difference yet. I lost a bit of the fuel economy, but gained even more power. The wagon looks totally stock, has great fuel economy, with the only giveaway to the performance is the exhaust tone.
Government Grant is offline   Reply With Quote
Old 04-13-2011, 01:56 PM   #4
Lega-seeyalater
Member#: 279771
2005 3.0R VDC Wagon
With all due respect, I have a hard time with that number. Assuming, generously, that a 3.0 does 0-60 in around 7 seconds, that would mean that you had your Subie going 0-60 at around 4 seconds. That just doesn't seem possible.
Am I missing something?
Lega-seeyalater is offline   Reply With Quote
Old 04-13-2011, 03:37 PM   #5
Cole
Member#: 64219
2011 Outbackness
2008 Legacy NA Hellastock
yeah, the part where this troll-bot also gets 44mpg
Cole is offline   Reply With Quote
Old 04-13-2011, 08:19 PM   #6
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
CosmoTheCat is offline   Reply With Quote
Old 04-14-2011, 09:09 PM   #7
Government Grant
Member#: 279401
I have some information & updates on the dual vortex generated, E3 ignited H6 3.0 Outback. When I installed the E3's, it appeared to be the second set of plugs since new at about 180,000 km. My initial acceleration showed best power at about 4500 rpm, with poor power before and after (on the old plugs). My dual vortex setup also caused about 1/4" reduction in the intake pipe diameter with my tube inside the air box. The slightly starved engine lost some bottom end power then but definitely got 44 mpg. I forgot to add that I am up in God's country, where we use the Imperial gallon (160 fl. oz.). When I installed the E3's, I got a power increase throughout the whole rpm range. My 0-60 mph was 12 sec. and became 9. With the Magnaflow muffler in back, my acceleration is now about 6-7 sec. with the tranny just entering third gear. It is surprisingly smooth and even acceleration. You can choose to believe the numbers, or not. (It doesn't take much money to try it yourself.) All I know is I'm smiling all the way to the bank. An improved suspension system is next on my list. [FYI - I'm a retired auto service manager who was a member of two private racing teams.]
Old 04-14-2011, 10:32 PM   #8
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
I absolutely do not believe you're getting anywhere near 44 mpg - Imperial or otherwise - however I do believe you're getting close-to-stock acceleration times.
Let us know when you get anywhere near 750 miles on a single fill-up.
Old 04-28-2011, 09:19 AM   #9
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
I changed my power steering fluid and get close to 50mpg...
PMDSOA is offline   Reply With Quote
Old 05-11-2011, 05:37 PM   #10
twagoon
Member#: 80551
1999 Outback
Green
I drained my power steering fluid and got 51mpg...
twagoon is offline   Reply With Quote
K&N air filter for H6 3.0 engine Heather Legacy Forum 3 05-06-2002 04:49 PM
H6 3.0 or EJ20 for 4EAT : is it possible? aek Normally Aspirated Powertrain 8 03-25-2002 07:41 PM
H6 3.0 turbo? Fubaru Normally Aspirated with bolt-on Forced Induction Powertrain 11 09-11-2001 12:58 AM
H6-3.0 at Paris Motor Show miksmi General Forum Archive 11 10-03-2000 04:31 PM
H6-3.0 at Paris Motor Show miksmi Legacy Forum 0 10-01-2000 04:07 PM
