Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-15-2003, 08:17 AM   #1
RedMenace
Member#: 31758
1999 Legacy Wagon
Burgandy
Default This may be the n00b question of the year....
Would a 2.5 auto engine bolt up to a manual tranny? My '99 wagon made a loud POP and died today when I tried to start her, and I want to have a contingency plan just in case the worst is realized. Thanks for the assistance.
RedMenace is offline   Reply With Quote
Old 08-15-2003, 09:46 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
yes
Legacy777 is offline   Reply With Quote
Old 08-15-2003, 10:18 AM   #3
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
There have been nOObier questions this year
nitrohuffer is offline   Reply With Quote
Old 08-15-2003, 10:19 AM   #4
Legacy777
Member#: 4800
Originally posted by nitrohuffer
There have been n00bier questions this year
agreed
Old 08-15-2003, 01:33 PM   #5
RedMenace
Member#: 31758
1999 Legacy Wagon
Burgandy
Heh, glad to hear... thanks for the replies.
Old 08-15-2003, 03:57 PM   #6
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
To add detail, yes, but I think you'll need to transfer the flywheel from the other engine, as they're different...
Herbie is offline   Reply With Quote
Old 08-15-2003, 04:37 PM   #7
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
IIRC there's a difference in the block to transmission hole/bolt pattern between the Phase I and Phase II decks. Haven't had to swap one out so don't know if this effects bolting back up but that may be one area to check in addition to the torque converter/flywheel issue which was already mentioned. Is your contingency engine out of a Auto car or ther other way around?
Br, Dale
Subietonic is offline   Reply With Quote
Old 08-15-2003, 04:41 PM   #8
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Default not really the n00b question of the year
Given this line:
it sounds like his car is a 5 spd manual, while the potential donor motor comes from an auto.
But that's just my interpretation
-Brian
KD7000 is offline   Reply With Quote
Old 08-15-2003, 06:03 PM   #9
RedMenace
Member#: 31758
1999 Legacy Wagon
Burgandy
What he said.
Old 08-15-2003, 06:21 PM   #10
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
That's what I thought but better to ask the question...
The the flywheel will be an issue and the, as still unresolved question of whether your're going with a P-I or P-II block... and you should be good to go. I believe Legacys produced after April 99 transitioned to the P-II blocks but there are some older models that have been back-fitted with the P-II block. Just check the bell-housing holes to make sure they'll bolt up.
Br, Dale
Old 08-15-2003, 06:44 PM   #11
noahr
Member#: 15434
98 legacy gt
caucasian
if you're going to get a new motor, why not a turbo? a wrx motor will bolt up as well (with some minor complications) ->crossmember, ecu, fuel pump to name a few.
noahr is offline   Reply With Quote
Old 08-15-2003, 07:10 PM   #12
RedMenace
Member#: 31758
1999 Legacy Wagon
Burgandy
Well, I'm not even sure I have to do this yet... the only reason I ask is because if I do have to replace the motor, I've got a good lead on an auto '98 Outback and just wanted to make sure there weren't going to be major fittment issues with the tranny.
Eh, the turbo was the original plan at one time, but trying to buy a house kinda kills things like that.... unless I can find a cheap rolled WRX and someone to do the install... erm, cheap.
Old 08-15-2003, 07:32 PM   #13
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
WRT the 2.5L's introduced on/after April 1999, believe that was the point where Subaru introduced the MAP sensor and did away with the MAF so you'll have some potential rewiring to look at as well if you're not swapping apples for apples. If it's MAF (98 OB for sure) to MAF (Your pre-4/99 Legacy), you'll be good to go with just the other things mentioned above.
Br, Dale
Old 08-15-2003, 08:52 PM   #14
noahr
Member#: 15434
98 legacy gt
caucasian
i'm almost positive they didn't switch the legacy's to map until 2000 with the release of the newer body. the only changes were using the phase II blocks with the dohc heads. should not be a problem wiring.
Old 08-15-2003, 10:30 PM   #15
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
The en masse conversion really took place in 2000 with the 3rd Gens as you mention, however, I've got a 99 sitting in the driveway right now with a MAP engine in it. The torque box is now the air filter box and all the other snorkus "stuff" sits along the inside of the right fender. That plus I always get asked at the dealer when I order parts for it, what the production date is and when I tell them April 1999, they say hold on that's when Subaru changed over... I've seen other 99 Legacy 2.5L's here in CA with the same set up so there is some segment that is converted over. RedMenace may have the 2.5L MAF but I thought it prudent to mention just in case.
Br, Dale
Old 08-16-2003, 03:40 PM   #16
noahr
Member#: 15434
98 legacy gt
caucasian
subietonic- that's freakin rad that you have a map sensored legacy. those are a little easier to turbo by the way. is it a dohc or sohc?
Old 08-16-2003, 06:19 PM   #17
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
It's a SOHC.
Br, Dale
Old 08-17-2003, 11:51 PM   #18
RedMenace
Member#: 31758
1999 Legacy Wagon
Burgandy
Actually, I don't have a 2.5 yet, I'm smokin' with the supah-leet 2.2.... if it went (which doesn't seem to be the case now -- oh well ), I was gonna just drop a 2.5 in there from a wrecked Outback or Impreza or something.... bah. If I decide to do it anyway, is there any extra wiring that would have to happen for the 2.5 ECU to go in there? Would it just be a "plug and play" type of deal? Thanks for the info folks... you've been informative.
This may be a dumb question So-CaliWRX Electrical & Lighting 3 05-17-2006 03:06 PM
this may be a stupid question redgrocerygetter Service & Maintenance 4 04-05-2006 04:38 PM
this may be a dumb question but im going to ask anyways version2.0a Off-Topic 23 03-28-2006 05:48 PM
This may be a dumb question... chopstix Transmission (AT/MT) & Driveline 4 04-19-2005 06:37 PM
this may be a stupid question, but... sergeant launch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-17-2005 03:12 PM
