Old 08-15-2003, 01:20 PM   #1
jorgy23
Member#: 24324
2011 STI 5-door
Midnite Black Metallic
Default Loud Turbo
And I mean LOUD!!!! Basically when I'm climbing hills or under hard acceleration when the turbo spools up it sounds like a diesel truck turbo.. it's that loud. Now I know this is not normal. I have no modifications to the intake. I had a K&N dropin but put stocker back and it's still very loud... Does anybody have any ideas...
jorgy23 is offline   Reply With Quote
Old 08-15-2003, 02:14 PM   #2
Austin
Member#: 7089
2016 STi
It's possible you've knocked out one or more of the grommets on the firewall, allowing increased engine noise into the cabin.
Austin is offline   Reply With Quote
Old 08-15-2003, 02:24 PM   #3
jorgy23
Member#: 24324
2011 STI 5-door
No I don't think it could be that because my friend was following me in his car the other day and commented on how loud the turbo was... and its' really only loud when going up steep hills in fifth or heavy acceleration... other than that it sounds normal...
Old 08-15-2003, 09:12 PM   #4
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Do you have an exhaust on it?? A downpipe will make it a LOT louder...
cavymeister is offline   Reply With Quote
Old 08-16-2003, 01:30 AM   #5
jorgy23
Member#: 24324
2011 STI 5-door
Ok... I guess I should have just looked under the hood... Long story short... I found out that the hose connected to the what I assume is the inlet pipe of the turbo was loose... "it's just below the intercooler and slightly in front of it.. if you reach down next to the throttle cable you can grab it..." I tightened up the damn hose clamp and Wallah no more turbo noise... I am totally cringing at the damage that might have been done by basically letting unfiltered air into the engine and turbo...
loud turbo ikes wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 04:59 PM
Loud turbo whine / noice at idle Bill_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-13-2002 06:32 PM
loud turbo noise. Is it normal for turbo car? myfirstnewcar Warranty Issues & SOA Problems 11 03-07-2002 06:10 PM
how do i get really loud turbo whine? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-16-2001 11:28 AM
Loud Turbo ninetalesnwf Normally Aspirated Powertrain 4 03-01-2001 10:03 PM
