Old 08-15-2003, 01:20 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default Part Identification Help
I got a mess of stuff the other night and I am trying to sort through it all. Below you will find two pictures of unknown parts. I believe the first one is the FBC, but I am not sure. The second one I don't have a clue as I've never seen it before. I'm also trying to find the fuel pump controller which isn't jumping out at me...
-Jon
Old 08-15-2003, 02:03 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ooh oho i know this one
1st fbc -correct
2nd ballast for the day time running lights -throw away
Old 08-17-2003, 11:54 PM   #3
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
BZZZZZT, oh sorry the correct answer we were looking for was "what is the resistor for the day time running lights"
GLwagon is offline   Reply With Quote
Old 08-22-2003, 12:43 AM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Next up on the identification block...
My bets are that it is the ABS relay connector, however I'm not 100% because the surrounding connectors don't look like they match up with the diagrams.
Eversifted through 160 pages of wiring diagrams and 50lbs of wiring, hehe? What a pain in the arse.
-Jon
Old 08-22-2003, 04:15 AM   #5
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
ABS no it isn't I am pretty sure cause that plug does not run with those wires. It is run seperate all by itself to its sensors and so on. ABS is a stand alone kinda thing doesn't flow with engine harness.
And yes I have looked through about 300 pages of diagrams and manuels. Also sat next to same amount of wires. Lets see if I can get my pic to work. YOu can correct me if I am wrong but that is what I encountered in my car!
SOME OF THE WIRES
AWJunkies is offline   Reply With Quote
Old 08-23-2003, 07:05 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
There is nothing else that it could be besides ABS. I've laid out my wiring harness and everything lines up perfectly to the connectors surround this location. Besides that, it is made my Bosche and I know that Bosche was contracted to do the ABS for the WRX. The organization for the ABS is most likely different on the RS.
-Jon
Old 08-23-2003, 09:17 PM   #7
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
It is ABS looked in some diagrams only thing is it shouldn't be with that bulk of wires. Correct?! that is where the confusion is.
Old 08-24-2003, 02:03 AM   #8
Austin
Member#: 7089
2016 STi
For starters, what wiring harness is that connector on?
Austin is offline   Reply With Quote
Old 08-24-2003, 11:33 AM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
MY03 WRX Sedan.
-Jon
Old 08-24-2003, 01:15 PM   #10
Austin
Member#: 7089
2016 STi
Yes, but which wiring harness?
Front wiring harness, engine compartment bulkhead wiring harness, engine wiring harness, cabin bulkhead wiring harness (I'm guessing that one?), rear wiring harness?
How many pins/how many wires?
Old 08-24-2003, 02:22 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Regardless of how they define the harnesses, it is all one harness. The different harnesses, in my opinion, are merely an easier means to identify locations of components. I've seen no easy way to seperate any of the three harnesses I have. But since you asked, it is the front wiring harness. It is located right next to the RH headlight, the RH turn signal, the RH abs sensor, RH side market, and RH radiator fan.
It has ~30 pins, but its not the easiest to count. I have just spent the last 15 minutes tracing wires, counting pins etc and I have it 100% confirmed that this is the ABS Control Module connector, id B301. The main ABS power wire traces from the connector to fuse #8 in the main fuse box.
-Jon
Old 08-24-2003, 03:15 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes it is the abs that pice hooks right into the abs pump right behind the passenger head light
Old 08-24-2003, 03:35 PM   #13
Austin
Member#: 7089
2016 STi
What MY are the harnesses from?
Old 08-24-2003, 03:40 PM   #14
Austin
Member#: 7089
2016 STi
For MY02, the front wiring harness includes F49, which is the 31 pin ABS control module connector.
For MY04, the engine compartment bulkhead wiring harness includes B301, which is the 31 pin ABS control module connector.
Old 08-24-2003, 03:41 PM   #15
Austin
Member#: 7089
2016 STi
Here are pics from the MY04 Impreza manuals for the engine compartment bulkhead wiring harness.
Old 08-24-2003, 03:43 PM   #16
Austin
Member#: 7089
2016 STi
Here are pics from the MY02 Impreza manuals for the front wiring harness.
Old 08-24-2003, 04:00 PM   #17
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It's a MY03 But it's ok, I've got MY02-MY04 wiring diagrams.
It was mostly me doubting my ability to read the diagrams properly.
-Jon
Part Identification Help STiRA-435 Brakes, Steering & Suspension 2 05-25-2009 09:16 AM
Help with part identification atlblu General Community 1 07-06-2008 10:34 AM
Engine part identification help... 02blueru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-12-2008 03:03 PM
Part identification help needed Trin_Starr Legacy Forum 4 03-28-2006 10:23 AM
part identification alphamale Interior & Exterior Modification 5 06-07-2002 03:06 PM
