Notices
Old 08-23-2003, 03:44 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default clutch cable part number ?!?!?
does the fwd clutch cable have the same part number as the awd clutch cable because we are having a problem installing ours with the swap and all
Dan
scobaru is offline   Reply With Quote
Old 08-23-2003, 05:41 AM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
this is the reason why I'm asking
the picture shows what my clutch looks like right now i'm using fwd cable clutch type of deal for the awd tranny I'm not sure whats going on with it my brother tried to put it back to gether he does'nt know so am I missing something or what I can push the clutch down but it doesn't spring back up someone help
Old 08-23-2003, 09:21 PM   #3
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
DID you bleed your clutch. Does your fork move freely? No back pressure for hydralic system to push or pull fork? Need to be more specific. You could have had your throwout bearing slip off and then have to open tranny up and put it back in correct or easy as bleeding the clutch.
AWJunkies is offline   Reply With Quote
6 Speed Reverse Cable Part Number? suby25 Private 'Wanted' Classifieds 6 03-13-2010 11:50 AM
clutch kit part number Mr Aryan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-30-2006 08:52 AM
2002 2.5 RS Stock Clutch Replacement Part Numbers e_a_olson Transmission (AT/MT) & Driveline 1 07-25-2005 09:21 AM
complete clutch kit part number request 555 Transmission (AT/MT) & Driveline 0 12-09-2002 08:31 AM
Magnecor cable part number? Mariano Technical Forum Archive 1 07-13-2000 04:22 AM
