Old 08-15-2003, 04:21 PM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default Degree on crank pulley??
In a ej25 SOHC with all the bolt-ons what should be the degree of the crank pulley for getting the optimun performance of the engine???? I noticed that when installing the timing belt the crank pulley has a pointer with some mark of certain degrees where should I set it up for better performance??
AntonioS is offline   Reply With Quote
Old 08-18-2003, 09:41 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The crank pulley will only go one one way, and as long as it's securely on there, it doesn't make any difference.
Legacy777 is offline   Reply With Quote
Old 08-18-2003, 04:16 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I think "AntonioS" is getting confused between the adjustable cams and the timing mark on the Alt/PS and AC pulley.
AntonioS: The pulley you speak of does nothing except drive belts. No matter what direction you moved it (if you could) it wouldnt make a difference.
timing mark on crank pulley Tim Sanderson Service & Maintenance 1 11-06-2016 02:30 AM
Crank Pulley Stuck- NOT Crank Pulley Bolt SubieNOVA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-23-2008 01:36 PM
WTT Brand new gold cobb crank pulley for polished crank pulley IllNastyImpreza NESIC Private Classifieds 2 03-02-2007 06:08 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 11:51 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-22-2005 12:56 AM
