Welcome to the North American Subaru Impreza Owners Club Tuesday September 30, 2014
Old 08-15-2003, 04:11 PM   #1
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Default Slight chirping noise
Hi all.. When I drive with the AC on, sometimes I'd hear a squeak from the front of the car, sorta chirpy, for a quarter of a second, and the car loses power for a tiny bit. Only happens under acceleration.. could this be a belt that is slipping or something?
Mirage is offline   Reply With Quote
Old 08-16-2003, 02:15 AM   #2
mike270
Member#: 12863
2002 2.5RS
yeah it sounds to me like the belt is slipping a little when the compressor turns on. Should be easy enough to fix.
mike270 is offline   Reply With Quote
Old 08-16-2003, 03:04 AM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
The clutch in the AC compressor could also be the culprit.
BAN SUVS is offline   Reply With Quote
Old 08-16-2003, 01:32 PM   #4
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
mike270 - How easy is the fix?
BAN SUVS - Is that a big job?
I'll just have to bring it by the dealer since its to do with belts.. should be covered under warranty?
Old 08-16-2003, 05:25 PM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
It would be covered under the 36/36,000 basic warranty. The clutch replacement isn't a supremely difficult job as long as you have the right tools. If you don't have them, you would probably be better off having a shop or dealer do it. It is still more likely to be the belt however. Check the belt for cracks and adjust the tension properly before jumping to my conclusion.
Old 08-16-2003, 05:45 PM   #6
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
I take it if its the belt that it is a consumable item and not covered under warranty?
I know very little about this A/C clutch so I probably will go by the dealer..
Old 08-17-2003, 11:29 PM   #7
imprezaRS420
Member#: 35212
2001 Impreza 2.5 RS
My car did the same thing. I had the Boone, NC Dealership (John Cook Subaru) check out a squealing or chirping noise I was experiencing at 3000 RPM's when my AC was on. I had a loose drive belt and was fixed in under 2 minutes for free.
I have a feeling that your chirping noise is the same as mine.
Bryan Rippy
imprezaRS420 is offline   Reply With Quote
Old 08-18-2003, 01:26 AM   #8
mike270
Member#: 12863
2002 2.5RS
It wouldn't be the physical belt really. Odds are it would simply be an adjustment that would have to be made. I haven't had to do this so I am not sure on the exact procedure but maybe someone else can help out here. If all else fails that is why we have warranties.
Old 08-18-2003, 09:06 PM   #9
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Default Well well..
I brought it to Subaru of Calgary..
Dropped my car off and the guy said he'call me and let me know. He never did, so my buddy and I drove back before they closed to pick her up. Anyway, they replicated the sound and adjusted the A/C belt (without calling me first ) and I got charged $27.xx cuz he said it was a wear and tear item (??).
Does that sound right? ***..
Old 08-19-2003, 01:37 AM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
That does sound right, and if it was $27 Canadian, you got a pretty damn good deal. No other shop would do it for less.
Old 08-19-2003, 04:29 AM   #11
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Man.. I guess u'r right.. yeah, that's Canadian.
Guess what I'm really pissed about is they said they'd call me if they found something but they didn't.. they just went ahead and fixed it..
Don't go to Subaru of Calgary if you don't have to..
Old 08-19-2003, 04:37 AM   #12
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Well, in order for them to look at it, you had to approve $XX in inspection... by just fixing it, they didn't have to charge for inspecting it and take the chance you wouldn't let them fix it, or charging for both. You are right about not calling though, they could have done that.
Old 07-04-2004, 05:25 PM   #13
PeterJ
Member#: 14727
2002 impreza RS
Hey, I lightly hosed down the engine and I immediatley got the chirping sound when the AC compressor cycles. This sound comes and goes, but started at just 20k, now I have 44k. The belt looks fine, but I'll check the sevice manuals to see if I have to replace the belt or adjust the tension. Im not sure about those "stop belt squeak" sprays. Why does the AC have to cycle when its not even on anyway?
PeterJ is offline   Reply With Quote
Chirping noise...help! Boujie Transmission (AT/MT) & Driveline 7 06-09-2003 12:25 PM
Slight knocking noise, various noises on springs? twotacosfor99cents Brakes, Steering & Suspension 4 02-21-2003 01:26 PM
WRX develops chirp noise? toobee1 Factory 2.0L Turbo Powertrain 36 05-08-2002 01:50 AM
Fluttering chirp noise @70mph and up anyone? munkis Normally Aspirated Powertrain 2 01-31-2002 06:54 PM
Chirpping noise coming from right front tire? ImprezedRS Brakes, Steering & Suspension 1 08-21-2001 01:44 PM
