Old 08-15-2003, 05:40 PM   #1
mofobaru
Member#: 37416
2004 WRX Wagon
Default Cobb Stage 2 without a full TBE?
I'm just about ready to pull my stock ECU and get the Cobb Stage 2 reflash.
Thing is, I don't yet have a full TBE. I have the catless uppipe and downpipe, the rest of my exhaust is stock. What can I expect from this reflash?
Cobb say I will not get the full Stage 2 performance, which I understand. But is there anything else I need to know, such as CELs or any "bad" things that could happen?
If it helps, my car is an 04 running 91 octane.
Thanks in advance!
-matt.
mofobaru is offline   Reply With Quote
Old 08-15-2003, 05:56 PM   #2
Kyle Jones
Member#: 13163
Talking Cobb Stage 2
Matt You can run stage 2 without a full exhaust set-up. To take full advantage of the re-flash get the exhaust opened up from the downpipe back. Don't forget to have Cobb nix the o2 sensor in the rear at the re-flash. I've got the stage 2 with TurboXS turbo back and I love it.
Kyle Jones is offline   Reply With Quote
Old 08-15-2003, 06:16 PM   #3
mofobaru
Member#: 37416
2004 WRX Wagon
Great! I'll run Stg 2 ECU now, then do the rest of my exhaust later. Which I plan to do, I just haven't decided what I want. And have only limited funds at this point, so want most for my $.
Thanks for the nfo!
Old 08-15-2003, 10:14 PM   #4
esteve
Member#: 28716
2006 STI
Since I'm on a budget (i.e. nagging wife ), I don't have a full TBE with my Cobb stage 2 either and it works great with no problems at all.
Someone posted about his dyno run at Cobb with his similar setup (Bosal DP, STi uppipe, Prodrive muffler) and he was getting 219 whp and identical torque numbers so figure about 5-6 whp less than a full TBE...not bad at all.
esteve is offline   Reply With Quote
Cobb Stage 2 TBE w/ AP V.2 '07 STi rs2.5-3.0 Engine/Power/Exhaust 16 04-24-2008 08:33 PM
Driving with VF39 on Cobb stage 2.5 map without JDM pinks... gopsu AccessPort 16 08-01-2006 10:50 PM
Cobb Stage 2 install without problems? Rob Watson Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-17-2004 08:09 AM
full boost w/ cobb stage 2 or just tbe/up? elijahwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-31-2004 06:33 AM
Cobb Stage 2 without downpipe Lordhowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-16-2003 12:18 PM
