Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 08-15-2003, 06:38 PM   #1
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Default UTEC MAP off?
Im having a little trouble with my UTEC, when in the dashboard and the logger its showing 16.7psi in 4th, full throttle..
but my built in boost gauge reads much less, like .105 mpa which if im not mistaken is like 15.0psi
just wondering if i should trust the reading of my stock boost gauge, or the utec... im sure I should trust the mechanical boost gauge, but i want a second opinion =P
GMTarkin is offline   Reply With Quote
Old 08-15-2003, 07:15 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Read the appendices in the manual. It tells you how to calibrate the UTEC to your boost gauge.
The real question is:
Which is right?
or
Which is more right?
Concillian is offline   Reply With Quote
Old 08-18-2003, 05:32 PM   #3
Mildmanneredman
Member#: 29962
I seen a lot of posts of people saying that their boost gauge reads anywhere from 1-3 psi different than their utec.
Mildmanneredman is offline   Reply With Quote
Old 08-19-2003, 01:35 AM   #4
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
That's exactly what I'm seeing. What's right? Gauge or UTEC?
big_adventure is offline   Reply With Quote
Old 08-19-2003, 01:54 PM   #5
CobraKLR
Member#: 12986
If you are at higher altitudes these values should be different as the UTEC reads MAP sensor pressure which is in absolute and the gauge reads relative pressure which changes based on your altitude.
If you are at sealevel and they are off by more than a little I would go to a third party source to see which is more accurate. If I had to choose between the two I would usually trust the MAP sensor as hose kinks, etc will really affect a boost gauge.
CobraKLR is offline   Reply With Quote
Old 08-19-2003, 07:15 PM   #6
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
I would trust the UTEC before you trust your gauge. I would say that 8-10 cars that show up for dyno tuning have inaccurate boost gauges. The UTEC which uses the factory MAP sensor has been very close to our dyno readings. Your logger also reads in abosulte pressure and not gauge.
If you decide that I'm wrong and want to trust your boost gauge, just remember that the UTEC could care less what your gauge says and will run the load site as it relates to what it sees.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Utec map compare tool: fyi http://www.clegg.us/UTEC/UTECMapCompare.asp AaronWRX UTEC 12 01-26-2009 01:00 PM
What's the stock map look like if it were a UTEC map selection? bpwatts UTEC 8 02-09-2007 07:17 PM
Need Help Pulling UTEC Map off of my car to send off for tweaking....HELP ME!!! YourMother'sLover Texas Impreza Club Forum -- TXIC 10 11-09-2005 12:37 AM
downloading UTEC maps to UTEC? axion7606 Newbies & FAQs 1 11-01-2003 07:05 PM
UTEC Users: UTEC map compare tool paul99se Engine Management & Tuning 3 10-23-2002 11:11 AM
