Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-15-2003, 07:45 PM   #1
WRXed
Member#: 3898
2004 WRX STi
White/gold
Default BIG difference in OEM vs. Prodrive STi wheel fitments. Why?
The following question was raised but not answered in another thread about Prodrive USA having updated the wheel section of their website. So let me raise it again:
Why are the offsets on their (Prodrives) new wheel fitments for the STi so different from the stock +53? It's one thing to have a wheel that will clear the front calipers (I'm confident these do), but it's another thing to clear the calipers AND preserve optimum suspension geometry. A 9mm offset difference seems extreme to me and I am concerned about scrub radius and wheel bearing isssues.
I know Prodrive enjoys a great reputation in the Subaru community and they know infinitely more about suspension tuning than I do. Can someone explain why a 9mm offset difference is something I shouldn't be worried about? Thanks.
Ed
WRXed is offline
Old 08-15-2003, 08:35 PM   #2
Darwood
Member#: 29669
2004 Impreza WRX STi
I want to know this as well. What is real interesting is that Rota makes wheels that mimic the Prodrive wheels but have an offset within 5mm of the stock wheel.
Darwood is offline
Old 08-19-2003, 11:17 AM   #3
WRXed
Member#: 3898
2004 WRX STi
White/gold
Before I pronounce this thread dead, I am bumping this in the hope that someone will respond.
WRXed is offline
Old 08-19-2003, 12:49 PM   #4
stiski
Member#: 34850
'98 BMW M3
STi SOLD:(
I was curious so i looked this up. I copied these the from the tirerack and prodrive websites. You should call prodrive and luke at tire rack. They may be able to answer your questions.
tirerack.com
"When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly."
prodrive-usa.com
"All Prodrive wheels are specifically designed for high strength and OEM fitment, for maximum performance and wheel-bearing life. Correct offset wheels ensure no increase in steering kickback, torque steer or tramlining."
stiski is offline
Old 08-19-2003, 01:46 PM   #5
Janq
Member#: 33246
1993 Legacy L+ AWD
Phoenician blue met./blue
Has anyone tried contacting Prodrive-USA directly and asking by phone?
- Janq
Janq is offline
Old 08-20-2003, 01:06 AM   #6
quynce
Member#: 15409
Default ttt
Perhaps you would have better luck in the wheels/tires forum? I did a when I saw Prodrive's post too.
josh
quynce is offline
Old 08-21-2003, 03:29 PM   #7
zacek
Member#: 19467
02 WRX
WR Blue
so this means that if we were to get 18x8 wheels the offset woudl have to be much less than 53mm correct?
zacek is offline
Old 08-21-2003, 03:43 PM   #8
MTMS4
Member#: 5227
The point about some of the Prodrive wheels is that in standard STi size (17x7.5") the GC010 forged wheel is available with either an ET38 or ET46 offset.........the 46 offset is probably OK (if it actually clears the Brembos and it's not absolutely clear that this wheel with this offset does) but the 38 seems extreme given that the standard offset is ET53.
The closer you can get to ET53 (if you use a 17x7.5" rim) the better off you will be.
MTMS4 is offline
Old 08-21-2003, 09:11 PM   #9
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Why would you want 18's? You lose performance. It may look better but the wheels are heavier and you sacrifice some handling?
essogas is offline
Old 08-21-2003, 09:15 PM   #10
pitbul09
Member#: 19471
Total not true!
pitbul09 is offline
Old 08-21-2003, 09:17 PM   #11
somebody else
Member#: 21618
Not according to Prodrive.
Not according to tarmac rally setups.
Not according to any racing class that allows them.
somebody else is offline
Old 08-22-2003, 05:37 PM   #12
zacek
Member#: 19467
02 WRX
WR Blue
you will actually affect performance, acceleration and reaction a bit. But since the Forge Allow wheels are very light the performance drop is being reduced considerably.
zacek is offline
Old 08-25-2003, 09:31 PM   #13
Darwood
Member#: 29669
Default ttt
This still doesn't explain why the offsets are so screwy. I personally think it's due to lazyness/cost. An 18x7.5 wheel should still have an offset of 53mm.
Darwood is offline
visual differences with oem vs group n tophats? Jared703 Brakes, Steering & Suspension 8 07-18-2005 11:38 PM
Is there a big difference in up-pipes? MikalsWRX Newbies & FAQs 18 05-04-2004 06:20 PM
Big difference in tire pressure needed to oversteer wcbjr Brakes, Steering & Suspension 10 07-16-2003 12:02 PM
Are there really big differences in the various rear endlinks? Schleppy Brakes, Steering & Suspension 15 11-19-2002 10:19 PM
