Old 08-15-2003, 08:09 PM   #1
BADWRX
Member#: 3792
2002 6MT almost GDB
Question EJ257 block with EJ207 heads. Mas redline?
I am thinking of making a frankenstien EJ motor. Slapping some EJ207 heads on a EJ257 motor.
Anybody know the CR of this badboy, and how about the max RPM's of the bottom end. Would like to run her up to 8 grand like the EJ207 if possible.
Plan on mating this setup to a FP20G turbo and maxim works headers.
Thanks,
Andy
BADWRX is offline   Reply With Quote
Old 08-16-2003, 03:34 AM   #2
wickedwrx
Member#: 23826
2002 impreza
No color it is invisible.
bump. I wounder what our new US STI short blocks can actually take.
wickedwrx is offline   Reply With Quote
Old 08-16-2003, 10:43 AM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
They spin the ra 207 block to 9k right? I know the rev limit from the factory is 8400. From what Ive read the only problem is there is no knock corection after 5500-5800? So you could run into big problems.
You could just slap them up and run it but I dont think it would be a good idea to try it unless you have the money for a new 257 and an extra set of heads. Cobbs ej25 spins to 8k but I dont think the factory block will. Make sure you get the spec c ra heads they have bigger ports then the sti.
Old 08-16-2003, 04:06 PM   #4
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
De-stroke it and rev it to the moon, I recommend the current STI EJ20 crank(More oil galleys) But a WRX one will be just as strong but rut a little warmer and ware a little faster.
Destroking it would make it run cooler and more efficiently at those higher RPMs. More power/less ware=Winner. You would also need the appropriete cams(Jun). MHO
k2
DeliciouSpeed is offline   Reply With Quote
Ej257 block with Ej22 heads HiCompwagon Built Motor Discussion 14 02-15-2010 06:26 PM
ej207 block with ej251 heads? ralliboi Subaru Conversions 1 07-08-2009 12:03 PM
WTB: EJ257 block or EJ207 block blueribbon NWIC Private Classifieds 0 10-16-2006 09:06 PM
Compression Ratio on EJ257 block with 98 DOHC 2.5 L heads jkjersey Subaru Conversions 0 04-20-2006 10:32 AM
EJ257 block with SOHC heads. GrandpreRS Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-27-2005 11:38 AM
