Old 08-16-2003, 08:34 PM   #1
03mbpREX
Member#: 33953
2015 STI
Default Questions about cobb stage 2
I got Cobb stage 2 reflash a lil over a month ago and its great, but I have a few questions now. Im not seeing 16 psi in any gears at all, i did for a few weeks but im not anymore. Also does the reflash change the rev limiter to higher rpms or does it stay stock? I would call cobb but its the weekend kinda want answers now so if anyone has and ideas let me know
03mbpREX is offline   Reply With Quote
Old 08-16-2003, 08:56 PM   #2
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
I thought ST2 was 15.5psi? Not sure about the rev limiter...
Bill
Camperguy is offline   Reply With Quote
Old 08-17-2003, 02:26 AM   #3
marder
Member#: 32366
If I rember right they keep the stock rev limiter, they will change it upon request. If you where seeing 16psi it was probally a boost spike ( small spike but still a spike ) as the computer learns it will lower itself to the specs it was programed for.
When I first got my stage 2 it did the same, thing mine actually only hit 16psi a few times then settled down to 15.5
Jordon
marder is offline   Reply With Quote
Old 08-18-2003, 07:46 AM   #4
Nitro Don
Member#: 19820
2007 NINJA ZX-10R
My stage2 was boosting about 16.5 lbs the first night I installed it. After giving it a while to "learn",it has settled down,but the outside weather has a big role in my boost performance. Lately
since I got the stage2 it has been hot and humid every day. When I drive it, I'll see 14.5 lbs of boost.
The few cool nights that we have had I took the wrx out and it ran boost right back at 16.5 lbs.
So Iv'e come to the conclution that weather has a huge control of boost performance.
Hope this helps
Don
Nitro Don is offline   Reply With Quote
Old 08-18-2003, 10:21 PM   #5
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
There are tons of threads here about hot weather and lower boost.
I have been getting up early on the weekends to drive just to experience the car on full boost (Cobb Stage 1).
brizey is offline   Reply With Quote
Old 08-19-2003, 10:39 PM   #6
esteve
Member#: 28716
2006 STI
My car won't hit 15.5 psi either...it never has with the stage 2. Believe it or not, I was hitting .11 mpa easily with the stage 1 when I used their restrictor hose.
Target boost is 15.8 psi +/- .5 psi for the stage 2. The most I can manage is .1 mpa on the stock gauge, so right around 14.5 psi. I emailed Cobb about it and they told me since I don't have a full TBE which isn't optimal, that could be the reason. I'm not sure I buy that since I was hitting .11 mpa easily before with the stage 1.
BTW, what are you hitting in all your gears? I have a hard time exceeding .06 mpa in 1st, so I'm more worried about that than not hitting peak boost. A few times I managed to hit .085 mpa in 1st so that made me feel better.
esteve is offline   Reply With Quote
Old 08-20-2003, 08:18 AM   #7
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
First off, your stage 1 was overboosting... you shouldn't have been using the Cobb restrictor. The boost target for Stage 1 is 14.5psi = .1mpa.
Second, stage 1 is designed to work with the stock exhaust, so....
Thirdly, stage 2 is designed for a full turbo-back. So the fact that you're a little off the mark as far as the boost goes isn't too surprising if you're not running a full TBE.
I'm assuming your removed the Cobb restrictor that you installed with your stage 1?
heffergm is offline   Reply With Quote
Old 08-20-2003, 10:35 PM   #8
esteve
Member#: 28716
2006 STI
Yeah, I knew my stage 1 was overboosting but I left their restrictor hose in there since I figured it wouldn't hurt short-term.
I guess I'll just have to live with the lower boost since I don't have the full TBE. Hopefully, Cobb will come out with a map for my setup later since it seems to be pretty popular and that I can use the accessport.
Yeah, the first thing I did was to re-install the stock restrictor hose. I didn't like how the thicker Cobb hose stretched out my poor hose clamps!
Question about COBB stage 2 kit Glenlivet AccessPort 2 04-01-2006 07:01 PM
question about cobb stage 2 bigstag Texas Impreza Club Forum -- TXIC 6 01-19-2006 10:15 PM
some questions about COBB stage 1... ChrisWRB Engine Management & Tuning 8 07-04-2005 07:06 PM
question about AP stage 2 ero2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-04-2004 04:19 PM
Question about txs stage 2 unichip Carlito2002WGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-25-2003 08:00 PM
