Old 08-16-2003, 09:44 PM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Question Why do I have more torque than horsepower???
I thought WRX made more HP than TQ?
Bill
Camperguy is offline   Reply With Quote
Old 08-16-2003, 10:45 PM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Hey most ppl would love a torque curve like that. You buy hp and drive torque.
What are your mods/
mr2guru is online now   Reply With Quote
Old 08-16-2003, 10:56 PM   #3
Camperguy
Member#: 21274
2002 Mc_Bains car
Well at the time of the tune I had Samco I/C hoses,PDE up-pipe,Pro-Drive WR Sport axle-back,Amsoil air filter and snork remove with a velocity stack in my air box.I also had Amsoil synthetics in the engine/driveline.I`m also running a TXS st1 unichip with plug+play harness.
Bill
Old 08-16-2003, 11:17 PM   #4
wrx320
Member#: 28631
2002 WRB wrx wagon
AVO stg I,II Shiv ECUtek
I say there is something wrong with the dyno your car ran on. Torque and HP are ALWAYS equal at 5252 rpms. On this chart your torque and hp values cross at 4300+/-, therefor something was not right with the dyno at the time this run was performed. IMO
wrx320 is offline   Reply With Quote
Old 08-17-2003, 12:13 AM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
The scales are different on the same graph.....look closely they still seem to cross at 5252. I was about to post the same thing until I looked harder at it. They both seem to make 220hp/tq. or so at 5250.
Old 08-17-2003, 12:20 PM   #6
scuzzy
Member#: 29214
05 WRX Wag (Work)
91 Legacy Wag (Play)
it wasn't very smart for them to list the graphs like that with two
seprate scales on the same page.
scuzzy is offline   Reply With Quote
Old 08-17-2003, 01:41 PM   #7
wrx320
Member#: 28631
2002 WRB wrx wagon
oh, I kinda see that now. guess camperguy is now torqueguy
Old 08-17-2003, 03:57 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I see dyno graphs with higher torque than horsepower all the time on my friends turbo 4's also.
Two examples would be my freinds FWD DSM, with basic mods, and a large 16G turbo. At the dyno he got a moderate boost spike when the turbo spooled and he made 276torque, but only 240hp because the boost dropped back down in the higher rpms. they later eleviated the spike with some tuning.
My friends Spririt R/T has done the same thing, he made 236whp, and 260-270tq because the boost spiked alittle on the dyno.
PaulRex is offline   Reply With Quote
Old 08-17-2003, 04:31 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You realize that the WRC cars make upwards of 500 ft.lbs. of torque and only 300hp, right? What people don't realize is that turbo = torque... it's just where you place that torque in the rev band that changes your horsepower curve.
Old 08-17-2003, 06:12 PM   #10
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
Easiest way to think of it:
more torque equals bigger booms
more hp equals bigger booms and/or faster booms
Turbos do both, depending on setup and tune. They force more air volume so you can use burn more fuel which makes bigger booms. They also can increase intake air velocity which fills rapidly moving cylinder chambers which makes faster booms.
brizey is offline   Reply With Quote
Old 08-17-2003, 07:54 PM   #11
Full_Clip
Member#: 22218
What physics textbook did you use?
Full_Clip goes back to OT.
Full_Clip is offline   Reply With Quote
Old 08-17-2003, 10:32 PM   #12
brizey
Member#: 36505
That is exactly the point. Makes it easy to explain to people without getting into thermodynamics.
Besides, I'm an EE, and I hated thermo way back when.
Old 08-18-2003, 02:47 AM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm assuming your unichip wasn't dyno tuned? I'd put my money on the unichip for this. All the properly tuned WRX dynos I've seen do make more HP than torque... always close but still. I suspect the unichip tune is a bit conservative up top causing a bit less peak HP. This is just an educated guess though. Give TXS a call.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-18-2003, 09:54 AM   #14
redobs
Member#: 1501
2009 WRX wagon
Dark grey
-- Ed
Actually, that is after a dyno tune.
redobs is online now   Reply With Quote
Old 08-18-2003, 02:59 PM   #15
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
I suspect this is because the stock turbo is fading quickly up top thus your hp falls off... if you held the 16-17 psi all the way to redline you'd see hp numbers that were higher... but his graph is very common on the TD04 it looks just like mine.
MustGoFast is offline   Reply With Quote
Old 08-18-2003, 04:53 PM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No way... the turbo does fade up top but even with a proper boost taper up top most WRX's make more peak HP than peak TQ.
You're running an MBC right? Maybe the MBC is actually holding too much boost up top sending the turbo out of its effeciency range robbing you of a little HP up top. That's why the newer ECUs taper boost much more up top.
-- Ed
Old 08-18-2003, 10:02 PM   #17
03WRXMA
Member#: 35081
2012 WRX
-- Ed
IIRC Bill DOSENT have an MBC. He does have a sweet wagon however
03WRXMA is offline   Reply With Quote
Old 08-18-2003, 11:44 PM   #18
jackansi
Member#: 23894
'07 3.2L Audi A4
Why didn't they run you out to 7K? looks like they stopped 500rpm short. I know there isn't much up there on the WRX but...
Mixed scale graphs vs a common scale are probably one of the least professional looking More torque isn't a bad thing, I'd just always be wondering if there is some piece missing since you do see more graphs with bigger HP #'s on the forum..
jackansi is offline   Reply With Quote
Old 08-19-2003, 12:45 PM   #19
TexRex2002
Member#: 36303
06 Evo IX
Those are pretty good numbers!!!
I have up and downpipe, 3" high flow cat, and UTEC with a stage 2 dynotune, and I top out at 210hp and 230 torque...
you must have a strong running car!
TexRex2002 is offline   Reply With Quote
Old 08-19-2003, 03:36 PM   #20
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
Those are very good numbers! I have a similar setup and I too have more torque... 212hp/229ftlbs...very similar to texrex....
Javier is offline   Reply With Quote
Old 08-19-2003, 06:19 PM   #21
MustGoFast
Member#: 33370
2002 Impreza WRX
no most tuned WRX's on a stock turbo have more torque... in fact all the ones I've ever seen have... no I'm not running an MBC and yes the cause is the lower boost at redline....
it's not just the ECU its also the turbo just running out of steam... I have engine management so I can stop the ecu from pulling the boost and it still fades very noticeably
WRC: why do they flick more than 2 times? chimchimm5 Motorsports 8 08-05-2007 01:07 PM
"My lug nuts have more torque than your Honda." SkirtBoy Off-Topic 25 07-15-2004 02:30 PM
Why does newer ej22 have more power than older ej22? d4d4d4d4 Engine Management & Tuning 7 10-10-2003 12:21 AM
Why are OZ Prodrives more expensive than Superleggeras? megatron Brakes, Steering & Suspension 2 05-14-2001 09:51 PM
Why do some engines make more torque than others? Arnie Newbies & FAQs 20 04-02-2001 11:54 AM
