Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 08-14-2003, 02:30 PM   #1
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
Default creaking noise after dealer service
I posted this over in the General section but hopefully I'll get more responses here.
My car started making a creaking noise when going over something on an angle, like when turning into a driveway that has a short, steep lip, or when driving over a speed hump at an angle. Doesn't seem to do it when going over straight on.
The car NEVER made this noise until I had the dealer perform a 30K mile service which included rotating tires, fluid changes, etc.
It sounds like it's coming from the suspension or the body structure itself on the passenger side.
Any ideas what could be causing this?
It's driving me crazy.
harrydog is offline   Reply With Quote
Old 08-14-2003, 03:20 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Make sure all the lug nuts are tightened down and torqued correctly. Aside from that, bring it back to the dealer if the problem still persists.
Calvin
cnk is offline   Reply With Quote
Old 08-14-2003, 07:54 PM   #3
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
i bet you that you have a bushing that the lube went bad in. if it is you can get it relubed for 60 bucks, but if you dont mind the noise it is structurally sound even tho it creeks.
-Dan
thewhitewrx is offline   Reply With Quote
Old 08-14-2003, 08:21 PM   #4
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
Dan,
Can you explain this a bit more? Which bushing do you think it would be?
Old 08-14-2003, 08:26 PM   #5
cnk
Member#: 10757
He could be referring to the sway bar bushings although it usually doesn't happen with the stock bushings. . .usually with the polyurethane aftermarket ones.
Calvin
Old 08-16-2003, 03:25 PM   #6
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
The noise turned out to be something more serious (in my opinion).
http://forums.nasioc.com/forums/show...hreadid=407706
Old 08-16-2003, 03:32 PM   #7
cnk
Member#: 10757
This is something that has occurred on other people's cars and is a known issue with some. The fix is to use some screws to provide enough separation between the metal pieces. I don't remember exactly what the issue was called, but you can do a search for 'creaking noise' in the suspension forums as that is where I had found it.
Calvin
Old 08-19-2003, 02:14 PM   #8
xer
Member#: 29714
2002 wrx
Unhappy creek
Ihad the same problem. The dealer had the car for a week until they found out it was actually the lower sway bar brace. It was not completly flush . Once the replaced it it has been fine ever since. It's been about 10k miles so far.
xer is offline   Reply With Quote
Front suspension creaking/groaning noise after some suspension work Somboa Brakes, Steering & Suspension 6 06-22-2011 02:45 PM
Oil / grease stains inside car after dealer 7500 mile service STiMUL8 General Community 6 07-02-2005 09:28 AM
Car stumbling and hesitating after dealer service. zuczek Canada Region Forum 21 09-01-2004 01:31 AM
new 'fluttering' noises after EGT replacement at dealer forsaken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-29-2004 09:08 AM
