Old 08-17-2003, 02:15 AM   #1
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
Default Anyone replace thier rear differential?
If you did how much did it cost and how hard was it?
quickscooby is offline   Reply With Quote
Old 08-19-2003, 11:40 PM   #2
matt8416
Member#: 34929
2004 sti
07 Lexus Breakwater Blue
Default diff
it's easy to change a rear diff
lift car as high as safely possible
drain rear diff
remove
cat back exhaust
prop shaft
2-17 mm nuts above drain plug
4-14 mm bolt &4-17mm nuts by prop flange
the diff is now loose in the rear cross member
push up on front u-bolts and down on diff while slideing the diff foward out of rear member
now the diff is free- the axles are still inside diff
let the diff drop down as low as it will go
take a pry bar and pop out the axles one at a time
your done
reinstall new rear diff in reverse order
matt8416 is offline   Reply With Quote
Anyone ever replaced their Rear Diff Brace?? coqui2004miguel Alaskan Impreza Club Forum -- AKIC 1 10-10-2009 05:40 PM
Has anyone replaced their clutch w/an aftermarket one? byroll01 Legacy Forum 9 08-23-2002 05:12 PM
Has anyone replaced their WRX sedan struts? Godmal Mid West Subaru Owners Club Forum -- MWSOC 1 04-26-2002 12:33 AM
Has anyone replaced their seats? 02_Forester Forester Forum 4 10-13-2001 12:18 AM
Anyone replaced their stock plugs? BoomerRS New England Impreza Club Forum -- NESIC 7 07-19-2000 09:55 AM
