Old 08-17-2003, 03:16 AM   #1
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Axis 2.35L,6-speed,ect
Thumbs up Few questions about the Perrin Turbo Inlet and about the Samco MAF arm????
Will the perrin turbo inlet fit with the samco MAF arm? Also will the Samco MAF arm fit with the TXS short ram intake. Cuz i wanna get the Samco MAF arm with the perrin turbo inlet pipe and i have the TXS short Ram inatke, and wanted to know if that would work? Also how good is the perrin turbo inlet compared to the samco? I would Appreciate any help or comments that you can give me. thanks,eric
BLUETURBOWRX is offline   Reply With Quote
Old 08-18-2003, 03:31 AM   #2
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Question
70 views and no one can help me out? --ERIC--
Old 08-18-2003, 09:00 AM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I can only speculate, and I think you're not getting responses because not many people have the Samco MAF hose.
Yes.
Yes.
Perrin looks like a better piece to me, but there is very likely nobody that can compare the two performance-wise.
jblaine is offline   Reply With Quote
Old 08-18-2003, 02:12 PM   #4
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
For those of you that dont know what the MAF hose is it just that samco arm that goes from the turbo inlet to the intake to smooth out the air flow.. Anyone who has a perrin turbo inlet also let me know how you like it. thanks,eric
Old 08-18-2003, 03:25 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Do you have pictures of the MAF pipe?
-Jon
Old 08-18-2003, 09:34 PM   #6
impreza99
Member#: 7601
hey, I just installed the samco maf pipe and I had to trim at least five inches off. I was very unhappy with this peice. The samco turbo inlet pipe was ok, but you had to modify the peice a little to get one of the sensors on, so hopefully your perrin inlet pipe is much better. So you might want to check into maybe the perrin maf kit if they make one. Thats my 2 cents good luck
impreza99 is offline   Reply With Quote
Old 08-18-2003, 09:51 PM   #7
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Does the samco MAF arm acctually have a spot for the MAF sensor? Also does it work with the TXS Intake? Thanks for the help guys but i would still like to hear other peoples opinions and experiances with these. thanks,eric
Old 08-18-2003, 10:19 PM   #8
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
It just replaces the accordian piece in the center.
enewtabie is offline   Reply With Quote
Old 08-18-2003, 10:26 PM   #9
cronic
Member#: 9749
WHy not just go with the perrin short ram and perrin inlet? The perrin short ram connects right to the inlet replacing the accordian piece you speak of. I just instlalled the perrin inlet two weeks ago and the install wasnt too bad..
Dave
cronic is online now   Reply With Quote
Old 08-19-2003, 09:57 AM   #10
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Default I have the Samco MAF.....
I also purchased a Samco MAF hose. I was a little disapointed with the piece. I also had to cut about 5 inches off of the hose in order to get it to fit between the airbbox and the stock inlet pipe. The bends in the MAF hose are also just a bit off so it took some definite "finagling" to get it in and also to make sure that there were no leaks in the airbox due to the MAF pulling it up.
Once I got it is it looks pretty good, but it definitly could have been made better. My only guess is that it was meant to go with the Samco inlet pipe.
I also had some issues with my Samco intercooler hoses. So far their batting average is piss poor with me.
-Jason
Jsunn is offline   Reply With Quote
Old 08-19-2003, 10:11 AM   #11
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
^^Did you notice any difference.
Old 08-19-2003, 10:32 AM   #12
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Default I also....
I also took the fender resonator out and I have a K&N high flow air filter.
The only difference that I noticed is that before with out the Samco MAF hose the "sucking" sound that was there when I got on the gas has now quieted down.
AS far as any performance gains, I don't think there are any. It is quite a bit larger in diameter and a lot smoother.
My EGT's may have gone up a tad, but my Autometer EGT guage has been on the fritz for about 6 months so I can't be sure.
Here is a picture of my setup...
-J
Old 08-19-2003, 10:39 AM   #13
PureWRX
Member#: 11739
2002 Impreza WRX
Blue - VF-23, Vishnu
I am currently running with the metal Zero/Sport MAF hose and the Perrin Inlet Hose. In order to get the Zero/Sport MAF hose to fit between the Perrin inlet hose and the airbox, I had to shave off about a 1/4" off the lip on the factory airbox. The combo of the the two now looks really good.
PureWRX is offline   Reply With Quote
Old 08-19-2003, 11:44 AM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Originally posted by PureWRX
I am currently running with the metal Zero/Sport MAF hose and the Perrin Inlet Hose... The combo of the the two now looks really good.
Ah, but did it DO anything?
-Jon
Old 08-19-2003, 12:30 PM   #15
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Thanks a lot guys for the feedback... One more questions it may be a stupid one but will the perrin short ram intake work with the perrin turbo inlet. I heard one of mention it i just wanted to make sure it would work. thanks,eric
Old 08-19-2003, 03:46 PM   #16
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Instead of using two pieces (inlet and elbow) why not get one?
AVO Silicon Intake Tract - WRX
$345.00
It spans from the turbo to the airbox unlike others that stop at the accordian section. It eliminates both the plastic intake pipe and the silicon accordian section with an ultra smooth hose made of thick multi-layer silicon with a wire skeleton.
It is pricey, but isn't your WRX worth it? I plan to get one before the year is out. They are availble from
Quantum Racing and I think Vivid sells them too.
dbrier is offline   Reply With Quote
Old 08-19-2003, 08:51 PM   #17
IndySport
Vendor
Member#: 35611
Dale,
Not all of us have a wife (gf) that lets us spend our money as we please
Jake
IndySport is offline   Reply With Quote
Old 08-19-2003, 09:34 PM   #18
tdxflex
Member#: 13634
$345.00
I'm pretty sure all of the inlet hoses have a metal coupler to use the stock accordian piece or an aftermarket. That all-in-one I'm almost positive does not have any metal coupler so it's all silicone and won't be as rigid. Shouldn't be a problem in that location, just an observation. My old MRT tmic had a full silicone Y-pipe with a metal coupler at the Y and it still felt flimsier than the stock intercooler with the Y-pipe because the mrt had shorter elbows from the end tank than stock.
tdxflex is offline   Reply With Quote
Old 08-19-2003, 09:44 PM   #19
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
The AVO does have a wire skeleton. That should make it plenty rigid enough.
Old 08-20-2003, 02:09 AM   #20
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Does the AVO turbo inlet with the extention work with the Turbo XS short ram intake? Once again thanks for the feedback guys keep em comming.. thanks,eric
Old 08-20-2003, 02:49 AM   #21
Spanky
Member#: 19574
2002 WRX Sedan
Had the AVO on mine...greatly improved throttle response...Horse power? Dunno...
Spanky
Spanky is offline   Reply With Quote
Old 08-20-2003, 12:17 PM   #22
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
This may not be the right thread, but I'm curious. I was looking at my turbo inlet pipe last night and it is smooth inside. What gains can be had when the design already looks decent? Increased cross-sectional area? More gradual tapers? I'm not sure what people are hoping to accomplish except to blow an extra $200-$300 on a pretty silicone piece.
-Jon
Old 08-20-2003, 02:49 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Originally posted by stimpy
This may not be the right thread, but I'm curious. I was looking at my turbo inlet pipe last night and it is smooth inside. What gains can be had when the design already looks decent? Increased cross-sectional area? More gradual tapers? I'm not sure what people are hoping to accomplish except to blow an extra $200-$300 on a pretty silicone piece.-Jon
The stock turbo inlet pipe is not 100% smooth inside. Look closer (as in, get your face 3 inches from the intake manifold) and you will see, as I recall, another flex/accordian piece buried in there.
Old 08-20-2003, 02:51 PM   #24
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
See: subaruparts.com picture, top left of page = Accordian that is hidden under IM.
Old 08-20-2003, 02:53 PM   #25
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
It is one of the safe mods. You probably only gain a couple of HP, but everything adds up. I think changing the accordian elbow would help as much if not more than the rest of the inlet.
I have improved my intake alot in small steps. The AVO part is the last one.
Currently it is: velocity stack in my fender conected to the stock airbox with an itg filter. Then the AVO one piece inlet hose(soon), stock turbo, Samco intercooler hoses and finally to a ported, polished and knife edged throttle body. That should give me better flow of air to the engine.
Perrin Turbo Inlet and EBCS Install Question trite Factory 2.5L Turbo Powertrain 4 03-31-2010 01:12 PM
WTT Perrin Turbo Inlet, I/C Hoses, Afta MAF Hose!!! nwindyz MWSOC Private Classifieds 3 08-26-2009 07:55 AM
BNIB Perrin Turbo inlet and slightly used AFTA MAF hose Drakar VIC Private Classifieds 8 03-20-2009 01:49 AM
FS WA: FPgreen Turbo w/ perrin turbo inlet and Perrin Big Maf Intake. wrxwagon253 Engine/Power/Exhaust 10 10-04-2008 04:00 AM
installed perrin turbo inlet and samco maf hose, WOW! wrxracer55 Factory 2.0L Turbo Powertrain 0 01-18-2004 02:19 PM
Message Board Statistics All times are GMT -4. The time now is 03:04 PM.
