Old 08-17-2003, 08:40 AM   #1
Vinnie
Member#: 7869
2011 STi
TheUrbanRallyProject.com
Question N02 line placement?
I just got a new NX nitrous kit and was getting ready to install it. Is it better to run the line in the inside or outside of the car?
I was going to mount it in my trunk. My buddy suggested the hole in the spare tire well. That would make the line run outside the car. I was thinking about running it through the rear seat and under the carpet, out to the engine
Any thoughts?
Vinnie is offline   Reply With Quote
Old 08-17-2003, 10:31 AM   #2
wickedwrx
Member#: 23826
2002 impreza
No color it is invisible.
I ran it outside the car in my DSM. Just make sure to tuck it up and away so it is protected from road debris and such.
wickedwrx is offline   Reply With Quote
Old 08-17-2003, 04:25 PM   #3
V REX
Member#: 11102
02 WRX,05STi sold
B5 WB Nogaro S4
I went throught the spare tire well and ran it under the car. I've seen people do it both ways, so which ever is easiest for you.
V REX is offline   Reply With Quote
Old 08-17-2003, 04:28 PM   #4
Vinnie
Member#: 7869
2011 STi
Thank for the help guys!
Old 08-17-2003, 04:46 PM   #5
KKoepp31
Member#: 13544
2011 ML550
It's actually very simple to run it inside the car, tucking it under the plastic trim down the drivers side. You'll find that there is already a bracket that I believe holds fuel lines and the nitrous hose will snap right into it, making for a nice, clean install. Just run the line up and send it through the rubber grommet on the drivers side firewall and you're all set. This way you keep that line away from the driveshaft and the very hot exhaust.
KKoepp31 is offline   Reply With Quote
Old 08-18-2003, 08:08 AM   #6
Vinnie
Member#: 7869
2011 STi
KKoepp31.... sent you a pm!
Thanks!!!
Going from rotated turbo back to stock placement, Coolant lines? mrkt321 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2009 05:57 PM
Boost gauge vacuum line placement VBwrex13 Newbies & FAQs 1 06-14-2009 01:11 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
Help, line placement Rick539 Built Motor Discussion 3 10-13-2007 08:16 PM
Anyone run ZEX or any DRY N02 setup? WRX300 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-21-2002 04:13 PM
