Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-17-2003, 10:51 AM   #1
TR11
Member#: 35784
Default STi Shut off.
Ok so i was driving last night and twice when i was turning left, (not even hard) my car just shut off?...i had to restart it....no check engine lights or anything....
anyone have any clue?...
TR11 is offline
Old 08-17-2003, 11:00 AM   #2
Damien
Member#: 25234
2016 DGM WRX Premium
287 Igg-Points just `cuz
Did you remember to reflash your turbo belt?
-Damien
Damien is offline
Old 08-17-2003, 11:25 AM   #3
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Don't mean to be a D!!k but the car already gave you the clue...something is malfunctioning take it to the dealer for warranty repair
DonA is offline
Old 08-17-2003, 11:52 AM   #4
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
how much gas did you have in the tank? Was it really low by chance?
davidm_sh is offline
Old 08-17-2003, 12:02 PM   #5
TR11
Member#: 35784
reflash my turbo belt?
TR11 is offline
Old 08-17-2003, 12:23 PM   #6
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
You guys are really helpful with a legitimate concern.
I would take it to the dealership but without a CEL I don't know how much they are going to be able to pull from the ECU. I honestly would try not to worry about too much unless it happens again.
lstepnio is offline
Old 08-17-2003, 12:26 PM   #7
TR11
Member#: 35784
thanks lstepnio, i wasnt really too concerned about it...there was no power loss, no cel's nothing changed about the car...it was just weird....i am not worried about it but just wanted to know if its happened to anyone else...thanks..
could it be something with a G-sensor?...actually now that i think abnout it before when i e-braked around a 180 turn, it shut off...hmm....i am hesitant to take it in because as you said...i doubt they would be able to find anything out with no trouble codes...
TR11 is offline
Old 08-17-2003, 12:31 PM   #8
Guyver
Member#: 37319
2004 WRX STi
Silver/Silver
I had a problem with an eagle talon that was simular. The car would just die without warning or CEL. The car was in for service 27 times the first year.
The replaced the computer, most of the wire harness.
They beleived the problem had to do with a short.
It even died as I was driving it out of the shop.
Go and explain what happened to your dealer. It may be a short or a bad fuel system electronics. Check the Subaru.CA site for information about the STI fuel system. The U.S. site does not have the nifty diagram of how the STi fuel system works.
Can you what would happen if you were making an emergency left turn and you STi died! Oh the humanity.
Good Luck
Guyver
Guyver is offline
Old 08-17-2003, 12:31 PM   #9
WRX 2002
Member#: 11211
2004 STi
Rally Blue
If the fuel is low you will get fuel surge on left hard corners. It happened in the WRX and it happens in the STI. If on the track due to the higher G force in corners it can happen in left or right hand corners even with a few gallons of fuel left in the tank.
If the tank warning light was not on and there is plenty of fuel I would be worried and get it checked out by the dealer or at least get it logged for future reference.
As it might be caused by a Gsensor I don't think there is any any connection between the 2.
my 2.5 cents worth.
WRX 2002 is offline
Old 08-17-2003, 12:38 PM   #10
Guyver
Member#: 37319
2004 WRX STi
Silver/Silver
The G sensor? Is that the same as the rollover sensor i read about? I beleive the STi has a sensor that kills the motor if the car flips. I do not know the name ot location of the part but maybe someone else here can fill us in?
Guyver is offline
Old 08-17-2003, 06:30 PM   #11
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Guyver
You didn't keep the car did you? wouldn't that fall under the lemon law?
el~sharko is offline
Old 08-17-2003, 09:25 PM   #12
Guyver
Member#: 37319
2004 WRX STi
Silver/Silver
Chrysler bought it back at sticker plus interest.
Guyver
Guyver is offline
Old 08-17-2003, 09:44 PM   #13
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Whoa Whoa Whoa, DO NOT touch the e-brake while driving,that is all.
Hondaslayer is offline
Old 08-17-2003, 10:53 PM   #14
1LapGTi
Member#: 33092
2004 WRX STi
The car definitely does not like to be pushed with less then 1/4 of a tank of gas. I was at the track today and anytime I would get close to 1/4 it would hesitate coming out of a long banked left hander. At one point the car died and I ended up coasting for bit until I could pull off in a safe area. Check engine light came on and the cruise light kept flashing.
I unplugged the battery for a few minutes to reset the ECU and all was back to normal. I added gas and did not have anymore problems. Now I Know I will never let it get down near or under 1/4 of a tank.
How much fuel was in yours??
Later,
Enrique
1LapGTi is offline
Old 08-17-2003, 10:55 PM   #15
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Just because there is no CEL does not mean the dealer won't find a problem... It could be something as stupid as a bad ign switch that would not trip a code.
There are far more systems that do not trip MIL codes than there are ones that do.
To my first point take it in for repair if they can't find the problem then try to find the answer
DonA is offline
Old 08-18-2003, 12:57 AM   #16
TR11
Member#: 35784
thanks for all the input guys....
i had almost no gas....gas light was NOT on but i was expecting it to come on soon...the thing that i thoght was weird was that the car didnt just die (like engine shutting off) but everything blanked, gauges, stereo, all of the dash etc...like how your car would be if you just got in it in the morning....weird stuff!!!...anyways...its warrentied so im not too worried about it...if it happens again ill make note of the conditions on which it occured and bring it to the dealer...i also have my 12000km checkup coming up soon so ill get it checked out then...
and hondaslayer, thanks for your comment but it isnt needed in this forum...
thanks all...
TR11 is offline
Old 08-18-2003, 11:02 AM   #17
SportyBry
Visiting NASIOC Timeout
Member#: 40648
2004 STi
Blue, of course
TR11,
My guess is that you are experiencing gas pickup problems on those hard lefts. An e-brake left is a high-g load which will slosh the fuel away to one side.
I also found the fuel system a little flakey in my STi per my earlier 'ran out of gas' thread. First time warning light came on I went right to the pumps and put in 45 litres meaning it had a 15 litre reserve when the light came on. On the second tank after the light came on I drove less than 75 km and then my car just sputtered and died. There couldn't have been more than 6 or 7 litres in the tank when the light came on that time. As it was sputtering, weaving back and forth gently caused the engine too pickup more gas and drive fine for a little bit. I imagine there would be alot of fuel movement during higher g turns which is what you experienced.
Now that I have the rear seats & interior out to install a rear strut bar I can hear the gas in the tank sloshing around all the time -- it doesn't seem to be well baffled in there. I NEVER hear that in my 323GTX race car unles it is very, very low on gas- and it has the same style of axle stradling tank in it.
....Brian
SportyBry is offline
Old 08-18-2003, 12:23 PM   #18
Janq
Member#: 33246
thanks all...
My car buddy & his wife just last week experienced _exactly_ what you describe to a tee, including the gauges going dead and the car going completely 'cold' at a momeonts notice. Further this happened several times during normal driving (i.e. straight line on a highway, turn in to their parking pad, parking at the mall).
The only difference from you is that thier car is a '01 VW GTI with 1.8T.
The dealer diagnosis was a bad connector for the MAS at the harness. They replaced the sub-harness and cleaned his MAS then put him back on the road. He hasn't had a problem since.
I don't know if the same thign applies to us/STi but your reports are uncannily the same to what they experienced with a previously reliable car/engine.
- Janq
Janq is offline
Old 08-18-2003, 12:28 PM   #19
Janq
Member#: 33246
Originally posted by SportyBry
...Now that I have the rear seats & interior out to install a rear strut bar I can hear the gas in the tank sloshing around all the time -- it doesn't seem to be well baffled in there. I NEVER hear that in my 323GTX race car unles it is very, very low on gas- and it has the same style of axle stradling tank in it.
....Brian
I can definitely confirm that.
I've not pulled any interior compents but when the tank in my car is at 1/2 or less I hear lots of fuel slosh. I'd figured though that it was due to our cars not having any sound deadening material.
- Janq
Janq is offline
Old 08-18-2003, 02:41 PM   #20
TR11
Member#: 35784
thanks a lot guys....when i bring it in soon ill have them look at that!!!...
TR11 is offline
Old 08-18-2003, 10:51 PM   #21
Hondaslayer
Member#: 4562
1995 Legacy LSi
thanks all...
And what is not needed in my statement?If you like your powertrain warranty I would not use the Handbrake to execute turns,Doing so WILL shorten the life of your differentials.
Ben,
Old 08-18-2003, 10:59 PM   #22
Janq
Member#: 33246
Ben,
Ben,
The e-brake has an e-sensor in the housing that detects actuation and tells the DCCD to go into open mode allowing jutst such a maneuver. Its even documented in the owners manual.
Click here for more specific info on this unique STi feature.
No harm will come to ones diff's as the STi is built for it.
- Janq
Janq is offline
Old 08-19-2003, 12:15 AM   #23
TR11
Member#: 35784
sweet!!!
TR11 is offline
08 STI fuel pump shut-off Mike.J General Community 3 03-31-2009 02:46 PM
Clunk when I shut off my '04 STi AlxSti Newbies & FAQs 3 10-06-2006 04:54 PM
Why would a car shut off when you lift off the gas? linux>windows Off-Topic 28 03-08-2006 08:38 PM
question about sti engine shut off.. bhs515 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-09-2006 06:31 PM
STi shut off on highway at WOT TurboPhoon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 11-17-2003 03:18 PM
