Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 08-17-2003, 12:49 PM   #1
el~sharko
Member Sales Rating: (5)
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Default Whiteline Rear Subframe Lock Bolts
I forget what they are officially called, but they kick ass. I wasn't expecting to feel any difference really, but wow!, a great addition to engine and tranny mounts. The feels even more solid, the shifting is even more crisp now. Makes the most noticeable difference when accerating from a stop or when you do a u-turn and hit the gas. I didn't really follow the torque specs, I just loosened the 4 factory mounting bolts and tightened these babies all the way the down. They are very hard to tighten had to use air gun and still barely went all the way in. I highly suggest this $20 mod
el~sharko is offline   Reply With Quote
Old 03-23-2004, 06:11 PM   #2
ride5000
Member Sales Rating: (3)
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, also highly suggested by me.
i think some of their effectiveness relates to how the rear sway bar is mounted... by removing compliance from subframe to chassis, the bolts also make the rear sway bar more effective, since it's mounting/fulcrum points are on the chassis itself.
got 'em used from another nabisco member for $25 shipped.
ken
ride5000 is online now   Reply With Quote
Old 12-18-2005, 03:03 PM   #3
Ziggyrama
Member Sales Rating: (21)
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
Any negative side effects on the locking bolts? I am considering picking up a pair.
Can you guys explain to me how this makes things better? I am not quite sure how this mod works. What does it bolt together that the 4 bolts you end up loosening do not bolt? Thanks!
Ziggyrama is offline   Reply With Quote
Old 12-18-2005, 11:19 PM   #4
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
In simple terms it removes compliance from the mounting of the subframe to the chassis. This way, since parts of the suspension/swaybars, etc, are mounted to this subframe so its response to bumps/turns is more accurate and direct, instead of squishy. Kinda hardenes s*(t up. So I guess.
Never tried them but me thinks NVH goes up with these though. Might have to give it a try.
Sir_Xenon is offline   Reply With Quote
Old 12-19-2005, 08:05 AM   #5
salem
Member Sales Rating: (2)
Member#: 56143
Fit is Go
I didn't notice anymore NVH than I had before, though I have hardened polyurethene bushings just about everywhere, group n mounts, cusco braces, etc so I used to it... I wasn't expecting to notice much difference myself, however you can feel the difference in turns.
salem is offline   Reply With Quote
Old 12-19-2005, 10:06 AM   #6
psyber_0ptix
Member Sales Rating: (25)
Member#: 60671
1992 Miata
it fixed my alignment issues as well...
no noticable NVH increase (over pillowball upper mounts)
psyber_0ptix is offline   Reply With Quote
Old 12-19-2005, 11:17 AM   #7
garie
Member#: 26607
2002 wrx wagon
I like mine alot.
garie is offline   Reply With Quote
Old 12-20-2005, 10:53 AM   #8
anthonyrb98
Member Sales Rating: (185)
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
good bang for the buck for sure
anthonyrb98 is offline   Reply With Quote
FS CA: BNIB Whiteline rear subframe lock bolt orwrx Suspension/Brakes/Handling 4 03-30-2010 07:24 PM
wrx/sti whiteline rear subframe locking bolts arrowscooby Suspension/Brakes/Handling 3 08-04-2008 02:05 AM
Whiteline Rear Subframe Lock Bolts (NIB) PARANOID56 Suspension/Brakes/Handling 4 02-28-2007 11:35 PM
02-03 wrx sedan whiteline rear subframe locking bolts anthonyrb98 Drivetrain 3 12-15-2006 08:50 PM
Whiteline rear subframe lock bolts SillyAssKilby Transmission (AT/MT) & Driveline 26 02-26-2004 11:37 AM
