Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-17-2003, 07:06 PM   #1
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Default jumpy idle speed... is this normal?
Hi everyone! I've put around 400 miles on my Sti and I've noticed something that seems a bit odd.
When I'm at a long stoplight, my idle would sometimes go up and down. For example... normally it's around 4-5k, but sometimes it would go really low like it's about to stall, and then all of a sudden the idle would jump a litle bit to 5-6k (i guess to prevent it from stalling). I thought this might have been due to the compressor turning on and off, but I've noticed this with the ac off.
Is this normal and has anyone experienced this as well?
volkl23 is offline
Old 08-17-2003, 07:51 PM   #2
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
My car does the same thing.
Zoso is offline
Old 08-17-2003, 08:31 PM   #3
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
Default Re: jumpy idle speed... is this normal?
i hope you don't mean 4-5000 rpm. that is a little high.
look at your guage again. the first mark on the taco is 500 rpm then 750.
yes it is normal to flucuate slightly especially when the ac compressor is on and when the fans kick on and off.
wrxtuner02 is offline
Old 08-17-2003, 08:58 PM   #4
wewu
Member#: 38767
a little ot here but ne one get this when they cold start their car. The car idles at 2k then slowly as it warms up drops to normal 500rpm?? Then one time during a cold start the car was at 2k idle then as I pressed the clutch to reverse out of my driveway the rpm started to rev. Scared me so I let out the clutch and the idle returned to 2k. Seemed that the clutch was acting like the throttle for a second there, ne one know what that was??
wewu is offline
Old 08-17-2003, 11:21 PM   #5
RichQY
Member#: 31948
2004 STi
idles @ 4-5K.
omg...
must be an anti lag system..
mine idles at around 6-700, doesn't fluactuate that much, only visible differnece is when the fan turns on and off
RichQY is offline
Old 08-18-2003, 01:52 AM   #6
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Sorry guys! I meant that the tach is around 400-600, but it would drop a little and then surge to 500-600 over and over again. I would say the cycle is around a min or so. The compressor is off when this happens.
Weirdness.
volkl23 is offline
Old 08-18-2003, 04:16 AM   #7
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
Every subaru ive been in does that.
Kostamojen is offline
Old 08-18-2003, 09:58 AM   #8
QUICKONE
Member#: 40519
Mine did this when I had the malfunction in the A/F sensor and the surging problem while driving.(see thread "car feels like it's surging) Since they fixed this problem idle is very smooth no noticable flucuations. Have them check the A/F sensor.
QUICKONE is offline
Old 08-18-2003, 10:43 AM   #9
PRGWRX
Member#: 22498
BLUE
mine has done that for a while<idle at 600...sometimes it even sounds like its about to cut off or give a rotary sound when just turning on the car. always wondered if that was a problem or not
frederick
PRGWRX is offline
Old 08-18-2003, 12:13 PM   #10
Janq
Member#: 33246
1993 Legacy L+ AWD
Phoenician blue met./blue
My STi has been doing the same but only recently (last 800 miles or so). When I take it in for a 2K mile fluid change and general check over I'll inquire about it.
It sounds & feels similar to old muscle car engines with big loping cams at idle. Also I noticed that my headlights some times dim for a split second at idle. My '04 Honda Pilot w/VTEC is well known to do the same thing and its a normal condition. As such I figured the weird idle might have somthing to do with the AVCS system.
I too at times have thought the engine was going to cut out. It seems to do this only when the engine is warm and been under load for long stretches (i.e. highway) and then brought down to stop & go traffic conditions. I've not noticed the effect on a cold engine or when commuting only.
This is my fifth Subaru owned and second in my current possesion. I've never noticed this phenomenon on any other model.
- Janq
Janq is offline
Old 08-18-2003, 12:52 PM   #11
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
- Janq
My Sti is doing the same thing after long drives and I stop. I never see this at cold starts other than my idle going pretty high (to warm the engine). My car has only 400 miles on this and it's doing this, as opposed to your's Janq at 800. Is this something worth taking in to inquire about at the dealer?
volkl23 is offline
Old 08-18-2003, 01:07 PM   #12
Janq
Member#: 33246
1993 Legacy L+ AWD
I'm just over 2K miles as of last night and I first noticed the idle lumpiness at about the 1200 mile mark.
Now that other folks are reporting the same thing I'm begining to think this just might in fact be a normal condition for STi's. I'll still ask about it though when I go see my Subie master tech.
It doesn't bother me though as its just caught me by surprise when it first started to occur. Again, the Honda Pilot does exactly the same thing and mine in specific has been since I drove it off the dealers lot.
One other item, this idle lumpinesss seems to occur most often when the A/C is off. I tend not to use A/C in my cars at all (I just don't like it and prefer an open window) but I find that under similar/same conditions with the A/C activated I do not get the idle lumpiness. Just an observation...
Thus far the only item that truly bothers me about this car is the notchiness of my shifter mechanism. At times it's resistant to shifting in/out of gear without a bit more authority than I'm used to (probably a remnant of its race application). Also the internal shift gate could have been a bit more precise as it takes a lot of getting used to.
- Janq
Janq is offline
Old 08-18-2003, 01:15 PM   #13
renichms
Member#: 38550
2004 Impreza WRX STi
WR Blue
With a cold start, mine idles at 1500 RPM until it warms up or until I start moving (which makes it not idle, obviously...).
RN
renichms is offline
Old 08-18-2003, 02:31 PM   #14
happasaiyan
Member#: 37731
'07 TL-S 6MT
'07 RDX-T
i get the boxer "shake" in mine, but only once have i experienced the symptom you guys describe. kinda scared me, and luckily never came back. i had a similar problem in my celica before, and all i had to do was make sure the intake tubing was properly secured. the maf gets messed up if there is a leak.
happasaiyan is offline
Old 08-18-2003, 02:40 PM   #15
old blue
Member#: 39710
I was wondering if the erratic idle had something to do with
the on board diagnostics...
old blue is offline
what is your idle RPM? - is this normal? cnriver2002 Impreza Forum 6 06-04-2008 02:18 AM
faint fluttering at idle. is this normal? Chris85xlt Newbies & FAQs 6 10-01-2007 03:07 PM
Is this normal at idle? 05ImprezaRS Newbies & FAQs 8 02-12-2007 10:29 PM
points for speeding ticket in CO: is this normal? bleuquila Rocky Mountains Impreza Club Forum -- RMIC 8 09-29-2003 12:40 AM
My idle speed is inconsistent at Idle, is this normal? LisaPhish Legacy Forum 17 07-15-2003 02:01 AM
Message Board Statistics All times are GMT -4. The time now is 08:28 AM.
