Old 08-18-2003, 12:16 PM   #1
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Default !!~ brake question on GC8
I own a 95 L 1.8 and am having brake problems. My
passenger side front caliper went bad (sticking) My
friend owns a 00 RS and gave me his calipers he had on
his car before he upgraded his to wrx brakes. Will
these calipers from a 00 RS clear my stock 14 inch
factory alloy wheels? Or do I have to buy new wheels. If I can't use these calipers with my wheels I need to know like today because of $$$ reasons. I do have a 4 disc ABS system on my car currently.
I hope to hear from you guys soon,
J K
jkjersey is offline   Reply With Quote
Old 08-18-2003, 12:22 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you need new wheels and new rotors, they will clear 15" wheels but not 14"
Old 08-18-2003, 11:08 PM   #3
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Are you sure about that jeremy? As long as he uses the stock mounting plates the caliper should bolt to the stock location and work with the stock rotors.
-Brad Weingartner
ChicksDigWagons is offline   Reply With Quote
Old 08-19-2003, 02:34 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
-Brad Weingartner
brad IIRC the calipers on the 1.8's are 1 pots and ours are 2 the swept volume on the 1pots is 10.4 and ours is 10.7.
i could be wrong as that is just off the top of my head. don't forget that the 2 pot is also a larger caliper which will not clear 14" wheels, the brackets are more then likely very different so i don't see a possible hybrid, all you would need is a WRXC wheel set or RS wheel set, or OBS wheel set
Old 08-19-2003, 02:58 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You are 100% right. The 95 has 1 pot front brakes, you have to swap the whole shabang to get it to work, and nothing I repeat NOTHING other than the stock brakes clear those dinky wheels! (yes, i know first hand)
Old 08-19-2003, 02:38 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
ditto what has been said. The one pots on the 1.8 are probably the same or very similar to what was on my legacy stock, and they just snuck those calipers under the 14" rims. Anything bigger, you need bigger rims and larger rotor.
Legacy777 is offline   Reply With Quote
couple quick brake questions on an 06 wrx rkjunior Brakes, Steering & Suspension 3 05-26-2010 11:26 AM
05-08 Legacy GT turbo rear brake setup on GC8? Plus suggestions on pads/rotors? legacy2003 Brakes, Steering & Suspension 11 06-05-2009 03:16 PM
Brake Question on 2.5i - Long Distance kero Brakes, Steering & Suspension 9 09-14-2007 09:21 AM
AEM big brake kit on gc8 wei Interior & Exterior Modification 8 07-05-2003 01:23 PM
Question re: GC8 to WRX brake upgrade RallyOttawa Brakes, Steering & Suspension 3 01-13-2003 11:02 PM
