Old 04-21-2001, 09:20 PM   #1
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Question EJ20 vs EJ25 (Turbo vs Turbo)
Who would win? What are the pros and cons of each? Performance? Reliabilitiy?
MagicMT is offline   Reply With Quote
Old 04-21-2001, 11:55 PM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
The answer depends on far too many variables to provide a short answer. How about "it depends"?
bsquare is offline   Reply With Quote
Old 04-22-2001, 04:24 AM   #3
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Yea...it depends.
Let's say stock EJ20 on the MY02 WRX and a Vishnu'd EJ25. In this scenario the EJ25 will win barring transmission failure.
Keiho is offline   Reply With Quote
Old 04-22-2001, 07:15 AM   #4
markus
Member#: 438
2004 STi
White on Gold
Post
My vote goes for Minnam/Vishnu EJ25.
markus is offline   Reply With Quote
Old 04-22-2001, 07:27 AM   #5
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
My vote goes to whoever has the most $$$. An EJ20 can produce ungodly amounts of HP and TQ. Be real. Think Rigoli.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 04-22-2001, 06:26 PM   #6
Digital_Boy
Member#: 730
Post
My vote goes to the turbo EJ25.
When running on stock internals, an EJ25 can make somewhere above 300HP at the crank. Shiv just proved this recently, and there are numerous others who've done the same.
I'm unsure what the EJ20 is capable of sustaining, since Simon Lines from Prodrive has stated that the EJ20 is only good to 280-300HP reliably. Others have differing opinions.
However, when you change pistons/rods and engine management, then the advantage of the EJ25 becomes even more evident.
The EJ20 is a great motor, and I think there'll be a few people who swap in some forged higher compression pistons to help cure the WRX's off boost bog.
But for my tastes, which include abundant torque down low for powering out of corners on the track or at the auto-x, I'll take a turbo EJ25 with good engine management.
On an endurance course, where you're keeping the car in a relatively narrow powerband, the EJ20 might make better sense.
Digital_Boy is offline   Reply With Quote
Old 04-23-2001, 12:48 AM   #7
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Wink
ken - are you ever right?
think rogoli? then think ASR!
if someone spent as much money on a 2.5L as the rigoli wrx then i would vote on the RS. if you look at it this way, the RS may have weaker internals than the WRX, but the wrx sure isnt running on many stock internals (if any!) when cranking out so much torque.
NickSTi is offline   Reply With Quote
Old 04-23-2001, 01:58 AM   #8
MichiganRS
Member#: 3069
Post
Sweet n simple and straight to the Point
EJ20 - Lower compression PRO (more boost)
EJ20 - Smaller displacment CON
EJ20 - Less low down torque CON
EJ25 - Higher Compression CON (with turbo)
EJ25 - Larger Diplacment - PRO
EJ25 - More low end PRO
EJ25 - Sexy headlights PRO
MichiganRS is offline   Reply With Quote
Old 04-23-2001, 02:44 AM   #9
Digital_Boy
Member#: 730
Post
Not quite that cut and dried Michigan.
My boost built short block from ASR will be 9:1 compression, maybe 8.8:1 if I get the thick metal head gasket from Subaru.
That's only .7 to .9 down from stock (9.7:1), and will be capable of taking 400HP and torque. Off boost response will be very much like stock, so I'm not really losing much at all in response.
The EJ20 turbos are a much softer 8:1, so they can run more boost, and they'll exhibit really nice top end pull when all the restrictions are removed (like the 3 cat setup), but will still be soft off the line.
IMO, given that once you venture too far from the simple mods of boost controller, RRFPR for the EJ20, or a 8PSI turbo kit on an EJ25, you'll want to do internal mods and add an aftermarket ECU, so while the engine's open, might as well bump the static compression up half a point or so on the EJ20, and down half a point or so on the EJ25. Would serve to wake the EJ20 up a bit.
Old 04-23-2001, 06:31 AM   #10
legacyb4
Member#: 4099
1999 Legacy B4 RSK
Violet-blue Mica
Post
For what it's worth, I posted the results of a dyno test of my friend's WRX STi Type IV alongside my Legacy B4.
Kinda cool to see how the single vs. twin turbo setups deliver their power...
The test conditions were identical and the writeup of how to interpret the results are pretty much the same.
WRX STi Type IV Dyno Results
Cheers.
legacyb4 is offline   Reply With Quote
Old 04-23-2001, 09:59 AM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
I think a properly prepared and reinforced EJ25 would kick some EJ20 butt.
Forged ShortBlock
Forged Pistons
Forged Rods
Forged Crank
MY99 2.5GT is offline   Reply With Quote
Old 04-23-2001, 11:52 AM   #12
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
Point is Nick, when getting real...Spending $$$ an Ej20 can hang with an EJ25. Don't belive it. keep the Ej25 and move on with your life. See ya in the Jungle.
Ken
Gtr Vs. Lp460 Vs. 911 Turbo Vs. Gallarado Sl Vs. Exige turbotimein253 Non-Subaru News & Rumors 17 04-15-2008 04:56 PM
('93-'01) Supra TT vs MR2 Turbo vs 2.5RS onikageka Impreza Forum 9 06-12-2002 12:16 AM
EJ20 (Single Turbo vs. Twin Turbo) legacyb4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-23-2001 06:47 AM
EJ20 vs. EJ25 Imprezanator Technical Forum Archive 4 09-17-2000 06:03 PM
Putting the EJ20/22 turbo vs EJ25 turbo debate to rest! Andre Vandenberg Technical Forum Archive 42 06-04-2000 07:53 PM
