Old 08-18-2003, 07:39 PM   #1
mca
Member#: 5447
2002 95 Integra GS-R
92 Sentra SE-R, 90 Miata
Default Cobb Access ECU: Fireballs after Reflash w/full Turboback?
Just like the title says.
I currently have a catless uppipe and full turboback exhaust with BOV vented to atmosphere. Will the Stage 2 Cobb reflash still produce fireballs (technically, afterfire) ouu the exhaust on up and downshifts?
Aaron
mca is offline   Reply With Quote
Old 08-18-2003, 08:26 PM   #2
Koua Jones
Member#: 3806
2010 MX-5 Touring
Koua Jones is offline   Reply With Quote
Old 08-19-2003, 01:30 AM   #3
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
hmmmm.......... cool?
-mike
mcu81 is offline   Reply With Quote
Old 08-19-2003, 12:34 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
probblay
Old 08-19-2003, 01:29 PM   #5
CobraKLR
Member#: 12986
Anti-lag system - cool. Of course that is bad for your turbo. Try switching to a 50/50 bov.
CobraKLR is offline   Reply With Quote
Old 08-19-2003, 01:55 PM   #6
mca
Member#: 5447
So does anyone know the answer to the actual question?
I'm asking because the stock WRX ECU is known to run rich. I would liek to know if the Cobb Access ECU will produce the same conditions, hence the fireballs.
Aaron
Old 08-19-2003, 02:00 PM   #7
CobraKLR
Member#: 12986
It really depends on the map they load as to what AFRs you will get. The stock ECU does run rich, as it should with this motor. After market ECUs run rich as well for safety. Part of your problem is probably your BOV as you are venting off metered air, which causes an even more rich condition between shifts. One question I would ask is what is igniting the fuel in your exhaust? How high are your EGTs?
Old 08-19-2003, 07:37 PM   #8
DAVE98RS
Member#: 525
<<98 2.5RS(RIP)>>
02, Cobb stg 2.5, FMIC
Try putting your stock BOV back on and see if it still breathes fire.
DAVE98RS is offline   Reply With Quote
FS: New Cobb Access Port (AP-SUB-002), Sti Full Exhaust, Sti Springs.. dmedak33 NWIC Private Classifieds 7 11-09-2008 07:40 PM
TurboXS full turboback exhaust with COBB axleback, brand new samcoYpipe anthonyrb98 Engine/Power/Exhaust 31 03-02-2007 05:00 PM
turboxs full turboback with cobb axleback exhaust anthonyrb98 Engine/Power/Exhaust 29 02-22-2007 11:01 AM
The after effects of Cobb Access Stg. 2 Lordhowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-31-2003 06:52 AM
FS: Cobb Access ecu reflash Lit4 Tri-State Area Forum 11 06-06-2003 12:22 PM
