Old 08-18-2003, 09:59 PM   #1
whiterabbit
Member#: 16755
Default what map to run with FMIC/stock turbo/catless
What map are people running with those mods? Catless and FMIC still on the stock turbo. I've got the UTEC and I just want to run a map temporarily until I get it tuned.
Thanks
whiterabbit is offline   Reply With Quote
Old 08-18-2003, 10:30 PM   #2
Mildmanneredman
Member#: 29962
Have you tried stage 3? It's for a TMIC, but it might be a starting spot.
Mildmanneredman is offline   Reply With Quote
Old 08-19-2003, 02:20 AM   #3
eightballrj
Member#: 18520
2005 L GT Limited
Hey,
I have basically a Stage II car plus a Blitz front mount intercooler. I just took and downloaded the stage III map and did datalogs for the first week or so. It is working PERFECTLY. I did notice a gain like I figured I would. I only had maybe 3 knock instances in the last 2 months and that was the first few days I had it. I now have made a closed loop map and it works great!! I hope this helps!!! Good luck!
Richard Jackson
eightballrj is offline   Reply With Quote
What Map To Run With On VF39 and EWG before TUNE dan1587wrx AccessPort 4 12-06-2008 11:36 PM
what map to run to get to dyno? wrxgti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-28-2006 09:00 AM
What do I need to run 12's w/stock turbo lilsix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-17-2005 06:11 PM
What LB of boost is safe to run with the stock uppipe? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-26-2003 01:15 PM
Whats needed to run a VF series turbo? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 13 01-12-2003 01:17 PM
