Old 08-18-2003, 10:00 PM   #1
msdavis4
Member#: 23410
2002 WRX sedan
Default Oil leak, help needed
I noticed some dirty caked oil on the black plastic to the left of the crankshaft pulley and it seems to be originating some where to the right of the water pump. I was thinking it maybe the head gasket, but I really don't know. Does anyone have any experience this type of leak?
msdavis4 is offline   Reply With Quote
Old 08-19-2003, 01:40 AM   #2
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Oil pump o-ring, crank seal...
Was it on the outside or the inside of the timing belt cover?
Austin is offline   Reply With Quote
Old 08-19-2003, 08:53 PM   #3
msdavis4
Member#: 23410
2002 WRX sedan
It was on the outside of the Timing belt cover.
Old 08-20-2003, 02:00 AM   #4
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Have you cleaned the area and has any oil returned?
If you do have a leak, it's definitely not from the water pump.
Your description is a bit confusing also... Assuming you're facing the engine, the crank damper pulley is in the middle (mounted on the crankshaft, of all places ) and the water pump is on the right side (driver's side). The oil pump is crank driven - it's casing is directly behind the crank timing gear, which is directly behind the crank damper pulley.
You said the oil was to the left of the crank pulley and to the right of the water pump... but the water pump is to the right of the crank pulley...
Old 09-16-2003, 06:20 PM   #5
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
I think I've got this leak too.
How bad is it to just let it go? My leak seems very minor, and since I'm already fighting with my dealer and SOA about fixing a bad CV joint, the last thing I want to do is add yet another item in the mix that needs to be fixed.
After checking the service manuals, it doesn't look like too hard of a job to do myself (replacing the o-ring and gaskets on the oil pump), but it does look like it will take me a weekend to get gona, and I don't have one to spare for a while... so how much damage am I doing, and what are the risks to letting this problem go for a while?
sperry is offline   Reply With Quote
Old 12-22-2003, 01:07 AM   #6
Tomnel
Member#: 12625
MY02 WRX Impreza
Anyone? I want to know as well as I think I may have this too.
Tomnel is offline   Reply With Quote
Old 12-22-2003, 01:38 AM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you are under warranty It would be preferable for you to take it in. You could go through the effort of removing the two side timing belt covers and try to locate the leak. But to remove the center cover you would have to remove th crank pulley.
A leak is a leak. Will it get worse? it might. Will it harm anything? If enough oil gets on the timing belt it sure could cause failure.
If you are concerned you should have it looked at.
Tim Sanderson is offline   Reply With Quote
Major oil leak... help needed. bball831 Newbies & FAQs 4 08-25-2009 05:39 AM
Oil leak found. Need help to identify part 03STAGE2 Factory 2.0L Turbo Powertrain 26 04-25-2008 04:01 PM
Oil Leak Help Help Help blackbeast Built Motor Discussion 3 05-25-2007 09:22 AM
Oil Leaking! help! stajerker Outback Forum 2 12-02-2003 08:54 AM
Oil leak... help! ElDuderino Factory 2.0L Turbo Powertrain 5 07-28-2002 04:14 AM
Message Board Statistics All times are GMT -4. The time now is 06:55 AM.
