Old 08-18-2003, 11:57 PM   #1
JSR
Member#: 39741
2011 WRX Hatch
Default Is My New XT Too Cool, Or What?
I posted this query in the Forester Forum, but thought I'd repeat it here to benefit (I hope) from more responses.
I've just put about 1400 miles on our new Forester XT 5-speed, and from the beginning it's run a bit cooler than I expected. No matter how hot the day or the kind of driving (city, hiway, etc.), AC on or off, the temp needle rises to just a smidgen over the first hash mark on the gauge -- the one that's about a third up from cold -- and stays there.
Since this is well within the normal range I assume there's no problem, but this is considerably cooler than I've seen in all my other cars, and I'm just wondering if it's too cool.
Would appreciate your thoughts.
JSR is offline   Reply With Quote
Old 08-19-2003, 12:59 AM   #2
mike270
Member#: 12863
2002 2.5RS
That is precisely where my 02 sits. Right above the 1/3 mark I guess it would be. no worries mate!!
mike270 is offline   Reply With Quote
Old 08-19-2003, 01:03 AM   #3
mike270
Member#: 12863
2002 2.5RS
also, btw, your Forester is definitely a cool car. In case you didn't know that already.
Old 08-19-2003, 01:31 AM   #4
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
I dig your Forrester. I want one for myself.
The coolant temp gauge (should be called an idiot gauge...) in your Forrester is every bit as crappy as every other Subaru.
They're very non-linear. Ther're at the normal range (which varies between meters) around 155F and stay there until at least 200F. Above 200F, they climb rapidly.
With your closed by 180F open by 190F t-stat and your fans coming on at 195F (with the AC off), you should always be between 180 and 195F.
The only way to tell the actual temperature is to use a Subaru Select Monitor or an OBD2 scanner.
Austin is offline   Reply With Quote
OT: Is my new girl too hot for me? Timmy Burns Off-Topic 128 07-13-2008 03:37 PM
OT: Is my new grill too hot for me? Matt A Off-Topic 159 06-13-2008 04:08 PM
Is my STi running too lean or other other underlying issues? j2los Newbies & FAQs 17 10-11-2006 11:21 AM
My New XT Too Cool? JSR Forester Forum 6 08-20-2003 12:06 PM
235/45 ZR18 on XT, too big or not too big ? Aleksey Forester Forum 12 08-08-2003 02:48 PM
Message Board Statistics All times are GMT -4. The time now is 03:22 AM.
