Old 08-19-2003, 01:52 AM   #1
SharP
Member#: 41705
1995 Legacy L Sedan
Baby Blue
Default Front Wheel Drive
OK - while gas prices are high and my car is getting a REALLY low milage for some reason lately (i ran it on highways for 270 miles and its already on E after i filled it with 16 gallons of gas few days ago - which is less than ever) I was thinking about turning my car into a FWD for some time , The question I have is whats the good and bad things about it , and can it damage the engine or a transmission in the long run(since its been on AWD since the beggining) and if i will really get higher gas milage using that?
SharP is offline   Reply With Quote
Old 08-19-2003, 01:57 AM   #2
mike270
Member#: 12863
2002 2.5RS
I'm not sure but I wouldn't think it could damage engine. IF anything were to happen it would be the differentials that would go first. You might try posting this in the transmission section. You may get more help there. Also a search in the tranny section might help you out.
mike270 is offline   Reply With Quote
Old 08-19-2003, 03:21 AM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
If you have a 4EAT you can put a 15 amp fuse in the slot marked "FWD" or something like that. If you have a manual, you're out of luck.
BAN SUVS is offline   Reply With Quote
Old 08-19-2003, 09:44 AM   #4
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
even with the fuse in the slushbox trick, I don't think it's good to run like thth for long. I think harmonics can damage the center diff since it's not meant to be the end of a rotating systme, if you get my drift.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-19-2003, 08:17 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You can make it RWD...(yes it's possible!). I'll give more info if requested....
FuJi K is offline   Reply With Quote
Old 08-20-2003, 04:58 AM   #6
SharP
Member#: 41705
1995 Legacy L Sedan
Baby Blue
If you can please give me the info of how i can change it 2 RWD
Old 08-20-2003, 06:53 AM   #7
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
It still won't help that much... if you really want to improve your mileage, get a Honda or Toyota.
Old 08-20-2003, 09:26 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
I'm just curious... how do you make it RWD?
Oh, and, 16 gallons? I didn't think the tank held that much.
orndog is online now   Reply With Quote
Old 08-20-2003, 11:52 AM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
There was few threads in the "Subaru Conversions" forums about this conversion. I have been following up on it because it's pretty interesting and how much pwerformance it can give being RWD.
It's just a simple taking out the center diff and disassembling it and welding the parts together. A thread show's you how to do this. It is messy in a way too because of the fluid that you must take out.
Here are a few of those links, enjoy reading.
http://forums.nasioc.com/forums/show...&highlight=rwd
Old 08-20-2003, 07:01 PM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
This will work (it's how the Cusco JGTC car does it) but unfortunately, it's not reversible. What's the point of a RWD Subaru come winter time?
Old 08-20-2003, 10:39 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Converting the car over to anything besides awd for increased miles per gallon is a waste of time. If that is your concern go buy a 1993 tercel with 100k miles for 1200 dollars and drive that to work every day.
Old 08-21-2003, 06:25 PM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
IF ALL the Subaru center differentials on the 5 speed trannys are the same, picking one up shouldn't be a problem.
But then again, you'd probably would want a beater car for gas milage and save your Impreza for the fun driving.
I'm stuck with the beauty of Front Wheel Drive! What's a guy to do?? SubieDriver2004 Subaru Conversions 19 04-10-2004 08:19 PM
turning my car into front wheel drive. need to run with srt-4s STEALTH-WRX Transmission (AT/MT) & Driveline 27 06-18-2003 07:45 PM
wrx front wheel drive trick RUDEBWOY Newbies & FAQs 13 05-18-2003 01:06 AM
"Why Front Wheel Drive Sucks" bluesunlion Off-Topic 18 04-12-2003 08:47 PM
my all wheel drive is reduced to front wheel drive archer Transmission (AT/MT) & Driveline 12 01-07-2002 05:29 PM
