Old 08-19-2003, 01:24 AM   #1
WRX2002
Member#: 14521
Default Need some advice for a newbie!?
Hey guys, I am thinking about upgrading my stock wrx. A friend advised me to get the following parts... What do you guys think overall this will do for me?
Flex Uppipe
5 piece SD Gasket Kit
ECUtek Reflash
Samco Intercooler Hoses
NGK one step colder plugs
Like I said, Im completely stock, and just looking for some advice.
Thanks,
John
WRX2002 is offline   Reply With Quote
Old 08-19-2003, 01:27 AM   #2
Erudition
Member#: 7560
Lol.
Good starting mods for power:
-up-pipe/downpipe/catback
Good suspension mods:
-Coilovers
That should REALLY keep you busy for a while.
Erudition is offline   Reply With Quote
Old 08-19-2003, 03:36 AM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Looks good to me..
my advised mod path is..
upipe
catless turboback
Samco ic hoses
Sti hoodscoop
UTEC<-- thats where you can gain alot of power. I dislike the ecutek reflash personally
PaulRex is offline   Reply With Quote
Old 08-19-2003, 08:38 AM   #4
Rickyh
Member#: 40453
Do the uppipe. It will make a big differnce.
Rickyh is offline   Reply With Quote
Old 08-19-2003, 08:38 AM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
Default Re: Need some advice for a newbie!?
Flex Uppipe
Flex pipes have had mixed emotions, you may be better off getting a solid pipe for 1/2 the money. I have a gruppe-s pipe for 10k miles I've been fine, it's all in the installation.
again do some research on here, subydude is great but i've heard a few bad things about those gaskets. You can get a set of stock gaskets from the vendors around here.
You won't see much gains with these with the other mods, this is more of a long term type of mod, it helps more as you mod more.
useless at your stage, save the money
ECUtek Reflash
I have one and it's great, but if I were to do it all over again. I'd get a UTEC. Mainly because I've been slapping items on over time. With the UTEC you can download the stages from Turbo-XS, or have a KNOWLEDGEABLE friend or shop tweak the maps as you add more. Once you are set and happy with you're mods, either stay with the UTEC or go with the ECUTEK and sell the UTEC.
If I were stock, I'd get a turbo-xs stealthback, samco hoses, and gruppe-s uppipe, UTEC. that will make you happy for a few months. then it's suspension and braking mods.
MikeWRX-NJ is offline   Reply With Quote
Need Good advice for a newbie?? lbrackin Newbies & FAQs 9 07-20-2007 03:36 PM
need some advice for which engineering field to go into... josh...just josh Off-Topic 39 11-02-2005 04:26 PM
Need some advice for which turbo to run... pightr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-05-2004 09:44 AM
Need some advice for which turbo to run... pightr Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-04-2004 03:40 PM
Computer Science Major: Need some advice for the future FuzzyNips Off-Topic 14 02-03-2004 09:09 AM
