08-19-2003, 10:03 AM | #1 |
Member#: 18709
STi I/C water level sensor
does anybody know where the STi's I/C water spray bottle water level sensor is located? (i.e. is it on the gauge cluster, a seperate light indicator, etc.) any information would be helpful. thanks. right now i have the 12L spec C tank, however i'm wondering where or what would i need in order to make the water level sensor useful. i'm not sure where i can get the male connector that plugs right into the socket on the water bottle. anyone?
08-20-2003, 05:09 PM | #2 |
Member#: 23341
Vehicle:04 Rex STi WRB/Gold |
The sensor itself is inside the tank on ours. It's just a float inside the tank.
I haven't looked at it specifically, but it should be a two wire hookup, with an input and an output. I'd assume it sends out a ground signal when the 'empty' light should illuminate. |
08-21-2003, 12:50 AM | #3 |
Member#: 18709
cool thanks! and i think it's the same as the US STi's water tank, just bigger.
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani | jakesurfin | Engine/Power/Exhaust | 9 | 06-15-2009 01:28 PM |
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor | jakesurfin | TXIC Private Classifieds | 4 | 06-15-2009 01:28 PM |
WTB STI Fuel Level Sensor | JasonM913 | Private 'Wanted' Classifieds | 0 | 04-16-2009 01:30 PM |
Do you know about checking your battery's water level? | HamFist | General Community | 26 | 12-13-2005 06:24 PM |
Physics gurus- lake, boat, cannonball, water level puzzle.. | boxxxer | Off-Topic | 70 | 09-01-2005 06:59 PM |
