Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 08-19-2003, 01:22 PM   #1
timjoh
Member#: 36547
Question smoke on start-up? 2003 WRX
My 2003 WRX has been parked in front of my house for the last 2 1/2 months while I was travelling out west. When I came back, I got a fair amount of black smoke on start-up.
Since the smoke is black, I'm assuming fuel, and since the car has been parked on a hill, I'm assuming that unburnt fuel somehow went where gravity took it.
I didn't think much of it until I came back to the car on the second day and it did it again. It was still parked on the hill, so I haven't ruled out that factor, but it still seems odd.
Any thoughts? The car is virtually unmodded (K&N, shifter bushings) and has 12k miles on it. I'll leave it in the driveway tonight to see if a level surface helps, but am at a loss otherwise. I guess this is the joy of having a warranty. If I can't figure it out, I drop it off and make them work on it.
Thanks,
Tim Johnson
2003 WRX - silver
Arlington, VA
timjoh is offline   Reply With Quote
Old 08-19-2003, 02:13 PM   #2
Karl
Member#: 13110
You need an Italian tuneup!!
Karl is offline   Reply With Quote
Old 08-19-2003, 03:04 PM   #3
timjoh
Member#: 36547
Default Hmmm?
Does that mean I have to tune it up the same way I broke it in? I.e., drive it like you stole it? Or does that mean I have to stick a Genoa salami up the tailpipe so I can't see the smoke?
Inquiring minds want to know.
Tim
Old 08-19-2003, 05:21 PM   #4
Karl
Member#: 13110
Alright all kidding aside...
How much smoke are you talking about here, and does it eventually go away?
And how much have you driven it since you come home? Have you got your car fully warmed up before you turn it off and let it sit around?
Old 08-19-2003, 07:46 PM   #5
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
You should have changed the oil when you got home. It'll absorb moisture while sitting for that long... moisture that's normally burnt off when you drive the car.
I'd suggest changing the oil, and seeing what happens. If you'd rather not, go on a long hard drive... should get the moisture out, and blow any thats accumulated in the exhaust out as well. Go from there.
heffergm is offline   Reply With Quote
Old 08-20-2003, 02:28 AM   #6
jlevy
Member#: 15696
2015 WRX 6 speed
Did you have any stabilizer in the gas? if not, bad gas and/or dirty injectors may be part of the problem.
-my 0.02
jlevy is offline   Reply With Quote
Old 08-21-2003, 09:10 AM   #7
timjoh
Member#: 36547
Default Problem fixed
The problem seems to have self-resolved. After being parked on a level surface overnight, I haven't had any smoke at all for two days. The smoke had only been on startup and went away immediately after one good puff. As the smoke was black, I was pretty sure we were looking at a fuel issue rather than an oil issue (oil smoke should be blue, I think).
No CEL, oil looks good, all is right with the world.
Thanks for everyone's suggestions,
Tim
2003 WRX
Arlington, VA
blue smoke on start up BradRS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 07-13-2009 06:49 PM
Blue smoke on start up... audio1der Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-04-2005 08:28 AM
Brief smoke on start up? SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-22-2004 07:25 PM
blue smoke on start up BradRS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-31-2003 09:14 AM
White smoke on start-up? Scrat WRX Service & Maintenance 6 09-04-2003 09:06 PM
