#1 |
Member#: 40409
All,
I may get some Engine Work done to my car. I have 29K miles on the car, would you recommend I change the TB anyway. If YES, would you guys recommend any after market ones which are stronger? PE sells one. Finally, is there anything else I should change while the tech has the engine apart. Any recommendations Thanks
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The service interval on the timing belt is 105K miles. At 29K it should still be like new. If it's going to be off/apart inspect it and change it if you want, but a new stock one is all you need if you do decide to change it.
#3 |
Member#: 40409
Thanks for your reply
#4 |
Trust no one
Definitely 105K replacement interval with inspections every 30K. The same goes for the accessory drive belts although those are easy to inspect more frequently and cheap enough to change well before 105K.
#5 |
Member#: 38696
Vehicle:2002 WRX White |
We recently had an 02 wrx that had the belt jump at 26k. If its off, change it. All you get is 3 teeth before the valves are damaged, so better safe than sorry. You can get an STI belt from the dealer for the WRX. It is slighty noisier, but stronger.
Rich |
#6 |
Trust no one
What was the cause for the belt jumping? I'd assume something went wrong with the tensioner to allow that to happen since the belt itself should still be in excellent condition at 26K. If the belt actually failed it would be unusual.
#7 |
Member#: 38696
Tensioner had not "failed", but was replaced as a precautionary measure. This car had an 18g on it, and was overboosted a time or two from what the cust said. I had a chat with AZ Scoobie, and he had some good possible scenarios, including speed shifting and a lack of a guide on the intake cam on the drivers side. Seeing a timing belt actually broken is very rare, they tend to jump rather than break, sometimes getting chewed in the process. SO basically, keep an eye on them.
Rich |
#8 |
Member#: 24475
Vehicle:1999 Forester L Dirty |
What is the easiest way to inspect the belt without disassembling everything? Just take off the timing belt cover?
| Thread Tools | |
| Display Modes | |
| brand new sti timing belt for wrx 02-07 | Speedster329 | Engine/Power/Exhaust | 3 | 02-17-2010 07:33 PM |
| New Sti timing belt for wrx 02-07! | Speedster329 | Tri-State Area Private Classifieds | 0 | 01-25-2010 12:37 PM |
| ej257 timingbelt tensioner, belts+timing belt cover, wrx intake manifold+throttlebody | White 2.5rs | Private 'Wanted' Classifieds | 1 | 07-19-2005 01:11 PM |
| Need Timing belt covers, WRX! | AK'S REX | Private 'Wanted' Classifieds | 2 | 08-20-2004 07:25 PM |
| Procedure to set timing on 02 wrx engine? | Aspen_2.5RS | Service & Maintenance | 5 | 09-01-2003 10:50 PM |
