08-19-2003, 06:54 PM | #1 |
Member#: 33293
Vehicle:2011 4-door STi Plasma Blue |
Headlights go on...oil pressure guage goes crazy
The needles just pins past 100 psi. It only happens when I turn on the headlight switch. The only thing I can think of is that I tapped the ground for the oul pressure gauge with the same ground that used to be for the light in the stock guage. This way i can contol the brightness. It works perfectly fine with the lights off. I always thought a ground is a ground no matter what but not the case here. can anyone suggest why this is happening?
08-20-2003, 01:58 AM | #2 |
Member#: 15409
A ground is not always a ground, especially in a negative dimmer wire. The negative voltage varies with the dimmer. However, a chassis ground is always a chassis ground, and you can't go wrong with that.
josh |
08-21-2003, 02:11 PM | #3 |
Member#: 33293
Yeah the dimmer ground must be messing with the guage. I completly overlooked that. I always thought that the dimmer was controlled by the amount of voltage sent through the power wire. Oh well can you tell me a good spot to get a chasis grounding point somewhere near the front of the car. Maybe I can just pull it from the radio ground.???
08-21-2003, 04:37 PM | #4 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
As stated, the "ground" for the stock gauge actually varies with the dimmer switch.
08-21-2003, 04:52 PM | #5 |
Member#: 15409
I wouldn't recommend using the radio ground because you'll increase your chance of inducing noise into your system. There is plenty of metal behind the radio and under the dash.
josh |
08-22-2003, 10:52 AM | #6 |
Member#: 33293
Anyone that have a good suggestion for a chassis ground. Maybe someone else who has the center mount defi style pod can tell me where they grounded there guages.
Thanks, Danny |
High coolant temp, cel, oil pressure light goes on and off? wtf | cazwrx187 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 03-05-2010 03:25 PM |
High coolant temp, cel, oil pressure light goes on and off? wtf | cazwrx187 | Electrical & Lighting | 1 | 02-14-2010 12:58 AM |
WTB: boost, oil temp., oil pressure guages | shampy2k | NESIC Private Classifieds | 2 | 02-19-2009 10:54 PM |
Defi boost, egt, water temp, oil temp, oil pressure guages | plycette29 | Interior/Dressup/Audio & Security | 7 | 09-22-2008 01:25 PM |
oil gauge needle goes crazy | StarDogChampion | Electrical & Lighting | 1 | 10-02-2005 02:36 PM |
