Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-19-2003, 07:59 PM   #1
pkirby11
Member#: 41732
Default CEL Light and Hard Idle
I have 03 WRX Sedan with no mods what so ever. I have had the car for about seven months now. After taking it on a trip to Florida when I got back into town the CEL came on and the car started idleing very hard. The RPMs don't go up or down they stay within 700 RPMS at idle. I took it to the dealer and they told me it needed to have the ECM flashed with a new program. Well here it is today with the new ECM and after 15 min. same thing happens again. Any suggestion as to what it might be would be a help so I can go and yell at the dealer and SOA. Its really pissing me off. My car is brand new with no mods. I always use 91 or higher octane. I get my oil changed all the time. I should not have to deal with this on a new car.
pkirby11 is offline   Reply With Quote
Old 08-19-2003, 08:05 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No, you shouldn't but unfortunately these things do happen sometimes. The dealer has to fix it, it sucks that they didn't get it the first time but hopefully they will now.
As for what it could be there really isn't enough information here to even speculate on. Do you know what the code was that set the CEL? We need to know that to have any idea what the problem was.
Old 08-19-2003, 09:12 PM   #3
dana
Member#: 25191
03.5 mazda slowness
not WRB
you didnt touch the 2 green connectors under the steering column did you?
dana is offline   Reply With Quote
Old 08-20-2003, 02:32 AM   #4
pkirby11
Member#: 41732
well I have no way of telling what the code is. I need to get me a program. All I know is that it is quite anoying and frustrating. And no I never even knew there were two green connectors under the steering colum. What would happen is I connect them.
Old 08-21-2003, 01:34 AM   #5
dana
Member#: 25191
03.5 mazda slowness
not WRB
Your idle will go bad radiator fans will come on and off and your car will run like poop take a look just to make sure. Maybe someone else had your car or maybe it was the ghost from family circle. Go to an autozone to check the CEL for free!
CEL Light and Cruise light on miiike Service & Maintenance 2 05-09-2010 09:59 PM
Bucking HARD in 1st and 2nd, idling rough, rain related Audiosavvy Built Motor Discussion 15 02-08-2010 06:13 PM
Rough initial idle and hard start problem after injector install Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-23-2009 09:32 AM
Cel light and ECU code BlackFly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-04-2004 08:27 PM
Hard starts and rough idle Brooke Legacy Forum 3 12-12-2003 07:00 PM
