Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 08-19-2003, 11:22 PM   #1
mike270
Member#: 12863
2002 2.5RS
Default Click when start rolling
I have noticed that I get a click when I get my car over like 3mph. Does it when accelerating, never when braking, forward or reverse, only when first started up, and at night and my lights are against a building or something I can see the lights dim for a split second when it clicks.
Any idea what it could be?
mike270 is offline   Reply With Quote
Old 08-20-2003, 01:44 AM   #2
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
ABS unit cycling?
Subietonic is offline   Reply With Quote
Old 08-22-2003, 02:30 AM   #3
mike270
Member#: 12863
2002 2.5RS
Would it do this only when you start rolling regardless of how long the engine has been on. Hot or cold?
What does the cycling do by the way?
Old 08-22-2003, 02:00 PM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
When you first start your car, the logic circuitry checks a number of different sensors, one being the ABS pressure available. These systems operate at tremendous pressure, somewhere in the neighborhood of IIRC 1.5-2.5K psi. The noise you hear is the ABS pump itself, "pressurizing" the system. It usually comes on within a few seconds after you start the car, cold, warm or hot to make sure it's up to speed, pressure-wise, and ready to go when you are. Since it's a high amp motor, it puts a pretty good draw on the electrical system so that's probably why you're seeing the lights dim.
If you want to check it out, lift your hood and look in the front right corner, left of the radiator (as you face the engine), down and to the left, attached just above the frame, is a round motor attached to a square aluminum box with small brake piping coming out of it. Have someone start you car and listen in that area. You'll hear the pump motor cycle/pressurize the system.
HTH
Br, Dale
Old 08-22-2003, 02:40 PM   #5
mike270
Member#: 12863
2002 2.5RS
Post
But I only hear it when I start rolling. It doesn't matter how long I have been running the engine for. The ABS light comes on when I first start the car then goes away without hearing any noise.
Old 08-22-2003, 04:18 PM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
The ABS light is just to show that it has completed a search of all the known connections, controllers, etc., and that everything is still connected, ready to go.
Re-reading your first post, I was presuming that the "click" came immediately after you started the car. At some point in the Subaru ABS development (cannot recall what year/models), the engineers added additional logic to the ABS that kept the ABS servor motor (pump motor) from initially pressurization until the car was put in motion. Perhaps to keep some unsuspecting shade tree mechanic from blasting out an eye or losing a hunk of hide when they cracked open one of the lines. So now you have to "move" the car, with the motor and the auto or manual transmission providing the motive power before the servo motor pressurizes the system.
I've gotten so used to this click with all of mine that I just don't listen for it. I did listen on my 99 Legacy this AM as I was going through my startup routine and the ABS servo motor didn't come on until I had backed the car out of the garage and started forward at 1-3 mph. This from a cold start. I checked it again after it had been parked for a few minutes later on this morning and it did exactly the same thing so I'm still pretty sure that the "click" that you identified is the ABS servor motor.
And given that your car's ABS pressurizes with forward movement, please ignore the "check it this way" advice provided earlier. Wouldn't want you to get in the way of the driver trying this would the hood open....
HTH - did it clarify it for you?
Br, Dale
Old 08-22-2003, 05:03 PM   #7
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Did you recently replace your brake pads?
I replaced my pads with Axxis Metal Masters and have just recently been experiencing a click when I apply the brakes when the rotors and brake assembly are still cold. My subaru tech friend tells me its just the pads shifting slightly because of a little bit of play when there cold. He says its common for replacement brakes.
MY99 2.5GT is offline   Reply With Quote
Old 08-22-2003, 06:50 PM   #8
mike270
Member#: 12863
2002 2.5RS
That makes sense now, and what you describe seems to be exactly what I am seeing. Thanks a lot for all your help. I was never concerned about it but just curious as to what system would be causing this.
Also I didn't recently change my brake pads but the first time I brake when the brakes are cold, I also here a click from them. I still have a completely stock brake system as well.
Old 08-23-2003, 03:44 AM   #9
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
You should be able to completely replicate the brake pad shift "click" every time you back up from a parking spot. Simply come to a stop with your foot on the brake. Keep your foot on the brake, set your e-brake and turn it off. Just keep your foot on the brake pedal through that whole evolution. When you get back in your car to move it, put your foot on the brake pedal, start the car, put it in reverse, release your e-brake, and back up coming to a stop in reverse using the brake pedal. When you start to move forward, the first time that you hit the brake pedal you should get a snap/click sound from the front brake pads shifting. This happens even with stock brakes with little to no wear on them. Just the nature of the beast... so to speak.
mike270
Sounds like you're satisfied that your question is answered. The lights dimming is almost a dead give away, unless you're also running your A/C and that "clicks" on and off too causing the lights to dim... but from your description it really sounds like your ABS servo motor.
Br, Dale
Cold Start click when accelerating Subee05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-14-2010 04:21 PM
help car just clicks when trying to start GuitarkidM3 Electrical & Lighting 3 10-18-2008 11:22 AM
07 LGT auto clicks when starting out kcmusa Transmission (AT/MT) & Driveline 1 06-01-2007 12:13 AM
Rapid clicking when trying to start memccain Texas Impreza Club Forum -- TXIC 8 01-18-2007 12:03 AM
Rapid Clicking When Attempting to Start Star*Child Electrical & Lighting 15 05-11-2005 02:21 PM
