08-20-2003, 12:06 AM | #1 |
Member#: 9237
Vehicle:2008 Saab Turbo X 400+ lbft |
Standalone Fan switch?
Has anyone set up a standalone fan switch for the radiator fans?
I'm really looking to set up a switch where i can turn on the fan at will, but the fan will still work off the thermostat aswell.... Has anyone done this, if so, how, and do you have pictures? Thanks in advance (cooling off the engine at the track would be so mcuh easier if you could get air to flow thru the engine bay =P
08-20-2003, 01:08 AM | #2 |
Member#: 30577
Vehicle:2003 WRX Blue |
I did this in my previous car, it really helped. I'm not sure if you know it or not, but you can force the fans to come on without the engine being on (keeping the car stock). This works in my 03 at least.
Turn the key to the run position, turn the fan speed to 1, press the A/C button to enable the compressor. This blows air out the vents and also turns on the fans up front. Not sure if this is what you're looking for since it requires you to leave the keys in the ignition...but it's a neat trick I discovered. |
08-20-2003, 08:33 AM | #3 | |
Member#: 34670
South East
Vehicle:2016 slowmobile |
Hey, it does work! |
08-20-2003, 10:33 AM | #4 |
Member#: 30577
Awesome, so it works on the OBS too.
08-20-2003, 11:50 AM | #5 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Works on all Subaru's from 1990 on AFAIK.
FS: New Mishimoto Aluminum Radiator, Two 12" Slim Fans, Cap, Fan Switch, 02~07WRX/STI | wrx_limited | Engine/Power/Exhaust | 12 | 04-03-2009 07:44 AM |
Installing fan switch | WRXBob | Electrical & Lighting | 14 | 06-29-2005 03:15 AM |
Lower Temp Fan Switch? | blk04 | Service & Maintenance | 4 | 07-21-2004 09:50 AM |
Fan switch | Rickyh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-15-2003 02:08 PM |
radiator fan switch | smew | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 05-16-2003 07:23 PM |
