Old 08-20-2003, 02:51 AM   #1
dgp
Member#: 15593
Default Accessecu Help!!!!!!!!!!
I just had a clutch put in and they disconnected my batt. My car is slow now and it seems my accessecu is not working at all. I only hit 12psi instead of 20. I used to have 300 awhp custom tuned by trey. WHAT HAPPENED? I disconnected the batt again and pressed the brake as suggested in someone else's thread. HELP! I am calling trey tomorrow but any advice would be appreciated.
dgp is offline   Reply With Quote
Old 08-20-2003, 03:41 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Unless they reflashed your ECU, there should be nothing wrong with the Access flash. It's not like disconnecting the battery erases the programming, unless something went horribly wrong during the write to your ECU (not likely). Make sure you give the car time to relearn it's IAM settings. Don't cry wolf just yet.
You can't kill a reflash just by disconnecting the battery.
supermarkus is offline   Reply With Quote
Old 08-20-2003, 03:43 AM   #3
dgp
Member#: 15593
thanks
Old 08-20-2003, 11:17 AM   #4
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Did you do a lightweight flywheel along with this clutch? What clutch did you put in?
Just curious.
I think you just need some time for it to relearn.
If you're really worried call Cobb. They support their products just like most vendors on this site, they'd be most likely to know about any possible issues.
There is always a chance for an exhaust leak too some exhaust brackets mount to the tranny you know.
omahasubaru is offline   Reply With Quote
Need Turbo Help!!!!!! 07subywrxtr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-05-2010 03:52 AM
Does AccessECU Stage 2 help prevent backfiring? hys420 Engine Management & Tuning 8 09-13-2003 07:28 AM
AccessECU is here! silvercharged Engine Management & Tuning 19 03-22-2003 10:50 AM
COBB/AccessECU norseone Engine Management & Tuning 38 03-21-2003 11:52 PM
COBB AccessECU tuned today norseone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-14-2003 02:08 PM
