Old 08-20-2003, 03:21 AM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Should I get an A/F meter?
I have a rallitek intake and MRT full headerback exhaust on my '99 DOHC 2.5. I've heard that intakes can really mess up the A/F ratio on MAF's and I'm really curious to see how my engine is running before I think about getting an S-AFC or ProECM chip to change my A/F ratio. I'm looking at a Split Second ARM 1 Meter - Part# SPOAFCM from rallitek.com. Is this what I'm looking for to determine whether my A/F ratio has been messed up by my mods? Do I need this? I'm just worried that my mods aren't performing as well as they could.
whtlegacy is offline   Reply With Quote
Old 08-20-2003, 09:37 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Borrow a high accuracy volt meter and print out the voltage to A/F ratio chart. No reason to buy it just yet. Wire it up so you can watch it while driving (mount it somewhere, zip ties and double stick tape works great).
Old 08-20-2003, 10:57 PM   #3
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
IIRC the rallitek intake was one of the few that actually worked well with the MAF? Do you have a lean spot around 5.5K?
Poppa smurf is offline   Reply With Quote
Old 08-20-2003, 11:45 PM   #4
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Yeah I actually heard that too. I'm not sure if I have a lean spot. How can I tell? Would my exhaust radically change the A/F ratio? It would make sense that an intake would change it a lot more I guess.
('93-'01) Should I get an Outback? JC Impreza Forum 29 07-10-2010 02:44 AM
Should I get an oil cooler for my 1997 L with the 2.2 liter motor? dsc Normally Aspirated Powertrain 2 04-05-2002 12:37 PM
Should I get an aftermarket BOV? cmaj7 Factory 2.0L Turbo Powertrain 14 12-05-2001 12:40 AM
just installed H&R's, should I get an alinement? SWEETWRX Brakes, Steering & Suspension 22 08-28-2001 09:09 PM
should I get an AFC? Keirik Technical Forum Archive 7 07-06-2000 05:25 PM
Message Board Statistics All times are GMT -4. The time now is 02:05 AM.
