08-20-2003, 08:05 AM | #1 |
Member#: 20870
Vehicle:2002 WRX Midnight Black mica |
ODBII question
Can a/f, boost, and/or oil pressure be monitored via the ODBII port?
I know I probably sound naive, but if the ECU is regulating/monitoring these through existing sensors, are the results readable without installing extra gauges and tapping pipes, etc? Or, alternatively, are there any gauges that function through the port?
08-20-2003, 08:30 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
A generic OBDII scan tool can monitor MAP readings which correlate to boost. It cannot show A/F because generic scanners cannot read data from the wideband front sensor. You will be able to see short and long term fuel trims, and the ECU switching between rich/lean status. Oil pressure is not monitored by the ECU.
A Delta Dash would be able to read A/F and boost, as well as all other ECU parameters, but it requires a laptop so you wouldn't want to use it all the time. Also the OBD port is right above your feet so the cable would be in the way unless you relocate the port. There is a digital gauge unit that operates through the port and reads some of the sensors, there are threads about it but I don't have time to look right now, gotta go. |
08-20-2003, 01:12 PM | #3 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Please don't crosspost.
See my reply in your other thread. -Jon |
08-20-2003, 02:13 PM | #4 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
yea you can, you might take a look atmaxqdata they have a moudual that plugs into that port, then you just plug it into your PDA, and read almost every sensor on your car
Shane |
08-20-2003, 02:18 PM | #5 | |
Trust no one
ODBII Cable Question?? | SnowmanFX | Engine Management & Tuning | 4 | 10-16-2005 10:29 PM |
ODBII output question | RafalW | STi Forum Archive | 9 | 09-12-2003 12:38 AM |
ODBII question | simwahWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 08-20-2003 01:07 PM |
which odbii protocol? | iceweazel | Newbies & FAQs | 1 | 08-20-2001 11:08 AM |
Anyone have an ODBII scan tool? | blaster88 | Mid Atlantic Impreza Club -- MAIC | 5 | 04-12-2001 06:43 AM |
