Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 08-20-2003, 11:27 AM   #1
[27]
Member#: 9731
2k2 wrx '13 Audi S4
Midnight Gray
Default 161 F on an AMD 2600+?
This normal or bad?
i had motherboard montior set to go off at 158 which it did, i was watching teh intro to Icewind dale II when it happened. i have 4 chassis fans, 2 of which are tornados and a huge honking proc fan that had the distilled water built into the copper tubing....any input?
[27] is offline   Reply With Quote
Old 08-20-2003, 11:30 AM   #2
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Well 70 degrees C is pretty hot....much hotter than I would want it.
What does your average temps look like?
-=C=- is offline   Reply With Quote
Old 08-20-2003, 11:31 AM   #3
[27]
Member#: 9731
2k2 wrx '13 Audi S4
Midnight Gray
right now its 114 with chassis temp of 98.
normally underload it hits the 150s
ive never seen it do that before, looks like im not watching the intro
Old 08-20-2003, 11:32 AM   #4
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
I would say that is overly hot. I *think* my AMD 2500+ runs at 45-50 C.
beethoven is offline   Reply With Quote
Old 08-20-2003, 11:33 AM   #5
Kaiser
\_(ツ)
Member#: 7170
Aut Kaiser,
aut nullus.
Normal operating temp (i.e., under load) should be 60 to 65 C (140 to 149F). So yeah, that's a little high considering you've got decent cooling (it sounds like). Maybe something's amiss...one of the fans not working or maybe the heatsink's loose? Or another component (video?) is getting really hot and heating the inside of the case more than usual?
Kaiser is offline   Reply With Quote
Old 08-20-2003, 11:33 AM   #6
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
And I only have 1 case fan, plus the PSU fans. My CPU fan is the stock AMD.
Old 08-20-2003, 11:34 AM   #7
-=C=-
Member#: 7719
99 F-150 crew cab
pretty much same here....I run 38 to 45 all the time...on an XP 2500 proc with an ok aftermarket fan/sink/arctic silver 3.
Old 08-20-2003, 11:37 AM   #8
micah
Member#: 3154
micah is offline   Reply With Quote
Old 08-20-2003, 11:42 AM   #9
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Mine runs below 50 degrees. I have six 80mm fans though, and I used arctic silver between my cpu and volcano 7 heatsink.
http://www.my-wrx.com/home/pics/xp2000pc.jpg
Actually tonight I'm building another PC, I got the last parts yesterday.
70 is too hot. That page says 95 but that's total bull. That's what AMD says, but you'll damage the CPU way before you get to 95 degrees.
kenshiro is offline   Reply With Quote
Old 08-20-2003, 11:54 AM   #10
Kaiser
\_(ツ)
Member#: 7170
Aut Kaiser,
aut nullus.
Originally posted by micah
My CPU is running at xx degrees, is it too hot?
Good info, though the list of CPUs is a bit out of date. Newer CPUs/GPUs manufactured at .13 micron or better should run significantly cooler.
Old 08-20-2003, 11:56 AM   #11
micah
Member#: 3154
Yah, I realized that after I posted... I googled on "Xp2600 maximum temperature" and found a good page (first hit).
http://www.google.com/search?sourcei...um+temperature
Old 08-20-2003, 12:45 PM   #12
sorbee711
Member#: 14259
OT, we're a-holes
b/c we are bored at work
Smile
My AMD runs at about 35C and sometimes hits ~41C, I have 1 80mm and 2 smaller ones. Good compound and heatsink/fan for the chip too. Plus its in the basement (finished - nicer than my old apt.) which stays about 65F.
sorbee711 is online now   Reply With Quote
Old 08-20-2003, 06:34 PM   #13
[27]
Member#: 9731
2k2 wrx '13 Audi S4
Midnight Gray
all this being said, any idea why icewind dale ii would cause the jump in proc temp? ive rendered video for 20 hours before and never even had thsi happen
Old 08-20-2003, 06:41 PM   #14
mr_disco
Member#: 7760
2002 Truly Slow
2006 Audi A3 in the shop
Mine runs at 42 C to 55 C, overclocked.
mr_disco is offline   Reply With Quote
Anyone with an AMD CPU (Socket AM2) want a free heatsink/fan upgrade? proletariandan MWSOC Private Classifieds 1 08-05-2007 12:22 AM
Multiple tire setup on an 8" and 8.5" wheel on an STI suby_dude Tire & Wheel 6 10-30-2006 05:58 PM
need help on an 05 injen intake install on an 06 2.5i skribblez32 Normally Aspirated Powertrain 3 08-23-2006 09:11 PM
AMD 2600+ vs. AMD 3000+ 64bit - Who wins? Guru Imakuni Off-Topic 11 08-05-2004 01:08 AM
Don King on IP Access Lists, Elizabeth Hurley On the Cisco 2600 Series FunkerVogt Off-Topic 3 10-08-2003 01:55 PM
