Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 08-20-2003, 12:01 PM   #1
SpeedShift
Member#: 35495
2015 STi
Default should i get an uppipe?
only mod right now is a reflash.
should i get an uppipe? will an uppipe give me more power, or just help me spool up faster? can you hear the turbo even more with an uppipe?
i have $500 and i dont know whether to spend it on an uppipe or a V1 radar detector....
SpeedShift is offline   Reply With Quote
Old 08-20-2003, 02:44 PM   #2
digitaltekniq
Member#: 18029
An uppipe will give you better long term reliability - as there's no cat to disintegrate for your turbo to ingest. There will be quicker spool, depending on the design of the pipe.
Autospeed and Helix with flex sections are good bets, and not ludicrously priced.
digitaltekniq is offline   Reply With Quote
Old 08-20-2003, 03:51 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Yes.
jblaine is offline   Reply With Quote
Old 08-20-2003, 04:47 PM   #4
Blueridge72
Member#: 7617
2003 REX
Yellow Wagon
yes, but gut your stock one for free.
Blueridge72 is offline   Reply With Quote
Old 08-20-2003, 05:16 PM   #5
SpeedShift
Member#: 35495
2015 STi
thats what i was thinking. now to just do some research on what an uppipe looks like and where it's at
wont i need another reflash if i have an uppipe?
Old 08-20-2003, 05:47 PM   #6
Bookmanx
Member#: 40895
2011 Sti Sedan
Plasma Blue
Gut the stock one, then get the V1.
But be prepared for WORK doing it that way.
OR, get the Gruppe-S uppipe (cheapest I have seen) and still get the V1.
Either way, replacing the up-pipe is a pain. Use the Vishnu instructions and it helps to have a helper on a few spots.
Bookmanx is offline   Reply With Quote
Old 08-21-2003, 12:04 AM   #7
mawgyit
Member#: 33807
03 WRX
Default UTEC Stage 1
I'm thinking about getting TurboXS UTEC Stage 1, (no other engine mods) with 15.1 psi. Do you guys think 15.1 psi is SAFE for stock uppipe with the cat crap inside?
Thanks, Maw
mawgyit is offline   Reply With Quote
Old 08-21-2003, 11:22 AM   #8
digitaltekniq
Member#: 18029
Boost target on stg1 is 16psi - your 15.1psi is low - and consequently pretty safe
Old 08-21-2003, 10:46 PM   #9
BOFslime
Member#: 23845
2015 FLAT SIX
I would recommend NOT gutting the stock pipe. This will cause turbulent air, and not help you. That and its a LOT of work.
perrin or vishnu uppipe's are good. I'm running a aps flex uppipe (and no, there are no deformities)
isn't this the wrong forum? this should be in FI
BOFslime is offline   Reply With Quote
Old 08-21-2003, 10:53 PM   #10
supermarkus
Member#: 6971
2008 WRX STi
SSM
Prove it.
http://clubwrx.net/forums/showthread...=gutted+uppipe
Though not a thoroughly scientific experiment, it suggests that the "turbulence" introduced doesn't do jack to a mildly tuned WRX. I'm pushing 209-213 to the wheels with a gutted stock pipe. So far so good.
supermarkus is offline   Reply With Quote
Old 08-21-2003, 11:39 PM   #11
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Originally posted by supermarkus
Prove it.
I second that.
turbulent air? I polished mine to a near mirror finish. You can't beat the price, and if you do a little homework it won't take that long. i did the entire thing in about 45min.
Marcel
scrappydoo is offline   Reply With Quote
Old 08-22-2003, 12:34 AM   #12
BOFslime
Member#: 23845
2015 FLAT SIX
Prove it.
I would be more interested in boost vs time, in this type of experiment. peek HP didn't change, but this doesn't paint the whole picture, and proves little.
Old 08-22-2003, 02:04 AM   #13
supermarkus
Member#: 6971
2008 WRX STi
SSM
And your conjecture on the effect of the turbulence proves lots?
If boost vs RPM is an indication of up-pipe performance, I make full boost by ~2700 RPM in 3rd gear. I'm still at stock boost, ~14 psi. I wish I still had my DD so I could read my old datalogs, I may be able to convert some of my Pocketlogger datalogs. I think they show MAP vs RPM. I'll get back to you guys on this.
Old 08-22-2003, 02:25 AM   #14
supermarkus
Member#: 6971
2008 WRX STi
SSM
BAH! My friggin datalogs are crap, it doesn't look like I managed to find a place to do one dyno-style pull. I'll try to get some logs this weekend, they'll be on my Pocket logger though, so they won't be directly comparable to Delta Dash stuff, or as high resolution, but they show general trends. More to come.
Old 08-22-2003, 09:49 AM   #15
BOFslime
Member#: 23845
2015 FLAT SIX
I never said my opinion was end-all, be-all fact. This is a msg board where people post there expirences, first hand or word of mouth. Don't need to get all up in a bunch about it.
and yes spool time, is a much better mesurment of an up-pipes performance than peek HP. My dd is in the mail, and should be here either today, or monday. I'll get some logs of my own car, although they will not be directly comparable to others, as exhaust and my ecutek boost map, play's into this aswell.
Old 08-22-2003, 12:22 PM   #16
Davenow
Member#: 23676
Default turbulance is irrlevant in real life, nice theory though...
The fact of he matter is this.
I have talked to 3 different peopl that do dyno tuning. All 3 have dyno tuned cars with multiple brands of up pipes. Here is what they ALL said
They have seen no power/spool difference between ANY of the up pipes (other than they are better than stock)
That's with cast iron, matched to the inlet sized pipes (txs)
Thats with larger than the inlet stainless
thats with gutted stock up pipes.
no difference whatsoever between them all.
So while the turbulance theory is solid, and looks great on paper, it falls on its face in real world testing.
BUT gutting the stock uppy is a MAJOR PITA.
with 500 bucks I would
buy another stock up pipe for 45 bucks then gut it, swap it in, then sell my stock up pipe for 45 bucks
I would then buy some Somco intercooler hoses and the V1.
Old 08-22-2003, 12:50 PM   #17
TheMadScientist
Member#: 23717
2005 Big red
Default Re: turbulance is irrlevant in real life, nice theory though...
What he said
TheMadScientist is offline   Reply With Quote
Old 08-22-2003, 01:40 PM   #18
BOFslime
Member#: 23845
2015 FLAT SIX
thats all i've ever implyed..
Old 08-22-2003, 10:51 PM   #19
supermarkus
Member#: 6971
2008 WRX STi
SSM
You're going to love your DD, I'm bummed that I never found a laptop to run it with. But I traded it straight up to a buddy of mine that I know would put it to far greater use than my broke ass could, for Prodrive springs
One of the cool things was being able to activate the logger by hitting the rear defrost button, and the road dyno feature was pretty cool if you had enough space to make some pulls.
If you have a buddy with a stock WRX, you could A/B the two cars on the same stretch of road to make some legit comparisons.
Old 08-23-2003, 01:47 AM   #20
BOFslime
Member#: 23845
2015 FLAT SIX
I hope so, looking forward to getting it..
sadly i rarly see any wrx's, impreza's, or anything other than outback wagons around here. let alone know someone..
although tonight!!.. i saw a new modded WRX in Saginaw (city just south of mine) i thought me and rattler(nasioc) were the only one's ANYWHERE around Mid mich.
but good news is.. there are plenty of roads for me to do dyno pulls on.. (4th gear pulls too )
Old 08-24-2003, 01:49 PM   #21
Platinum2003WRX
Member#: 33515
2003 WRX
That's what I did. I bought a stock gutted uppipe and put it in.
Platinum2003WRX is offline   Reply With Quote
('93-'01) Should I get an Outback? JC Impreza Forum 29 07-10-2010 02:44 AM
Should I get an oil cooler for my 1997 L with the 2.2 liter motor? dsc Normally Aspirated Powertrain 2 04-05-2002 12:37 PM
Should I get an aftermarket BOV? cmaj7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-05-2001 12:40 AM
just installed H&R's, should I get an alinement? SWEETWRX Brakes, Steering & Suspension 22 08-28-2001 09:09 PM
should I get an AFC? Keirik Technical Forum Archive 7 07-06-2000 05:25 PM
