08-20-2003, 08:09 PM | #1 |
Member#: 34204
Vehicle:2004 WRX WR Blue |
Will radar detector work through semi-metallic tint (front & back windshield)?
Hey all, I wanted to mount a radar detector above the rear view mirror, but I have a 13% titanium semi-metallic tint on the front windshiled (it's a 5" strip along the top of the windshield). I also haev 22% semi-metallic tint on my rear window. Anyone know if a radar detector will still work okay through this tint, or should I not even bother? I really want to mount it above my rear view mirror for a stealth install. Thanks.
08-20-2003, 10:13 PM | #2 |
Member#: 34670
South East
Vehicle:2016 slowmobile |
I think it has been tested to reduce sensitivity. If you want stealth, get one of those systems that mount sensors behind your grill and rear bumper.
08-20-2003, 11:43 PM | #3 |
Member#: 32546
Vehicle:2002 Impreza RS 2.5 Aspen White |
Here is my install of a remote sensor system (the white RS):
http://forums.nasioc.com/forums/show...&highlight=sr7 As for performance behind the tint, you will probably trash any Laser reception, both Escort and V1 state that tinted glass can adversely affect RADAR detection range (actually, this link here hints that tinting the rear and side windows can "confuse" the directional tracking abilities of the unit. I haven't heard as much by the V1 users here, but my sensors are mounted outside the vehicle so I have no such problem . |
08-21-2003, 01:57 AM | #4 | |
Member#: 34204
03-03-2006, 01:12 AM | #5 |
Member#: 31511
SCIC
Vehicle:2003 GD2 GM4 BP9 www.ITNRally.org |
ok, how well does a radar detector work behind regular tint? been thinking about getting one and mounting above the rear view mirror, but I have a tint border covering the area.
TIA, RR |
03-03-2006, 05:29 AM | #6 | |
Member#: 72910
Read here: http://valentine1.com/lab/MikesLabRpt2.asp http://valentine1.com/lab/Previously6.asp |
03-03-2006, 11:00 AM | #7 |
Member#: 3601
NWIC
Vehicle:2006 WRX Wagon BRIGHT BLUE! |
06 Windshield
Speaking of which, the 06 WRX, and I assume all the 06 cars, have a darkened section above the mirror. Hard to tell exactly WHAT it is made of, but I suspect it's a metallic substance. I wonder how it affects a detector mounted up there. For the time being I've mounted mine down low and offset to the left of center about 6 inches to avoid shading the sun sensor. Which seems to be OK, but I wonder if the hood scoop is blocking some of it's view. Arrgh.
03-03-2006, 01:04 PM | #8 | |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
03-03-2006, 02:08 PM | #9 |
Member#: 31511
SCIC
cool thank you for the response
03-03-2006, 02:17 PM | #10 |
Member#: 935
Vehicle:Will Woollard Fan Club |
When I use the V1, I attach it to the right of the mirror. The sensor's petty much just below the shading. It works as well as it did with the RS that had clear glass up there.
03-03-2006, 02:30 PM | #11 | |
Member#: 66815
SCIC
Vehicle:2005 WRX Wag -SOLD:( CGM STX #125 |
my '05 has the same stuff on the windshield. i have a V1 mounted above the rearview mirror, to the left of the post. however, there is enough room for the v1 to "see" underneath the darkend section. the suction cups stick fine to the darkend section. i'm still shopping around for a good price on some ceramic tint. it's been pretty cold this winter, will probably put it off 'till late spring |
FS: (IN) V1 Radar detector!! works perfectly | Boxer519 | Interior/Dressup/Audio & Security | 6 | 11-04-2006 09:03 PM |
FS: (IN) V1 Radar detector!! works perfectly | Boxer519 | Non-Subaru Stuff | 5 | 10-30-2006 12:35 PM |
Where to go: I want to match my tint, front and back doors | Yoo Shin | Texas Impreza Club Forum -- TXIC | 12 | 06-25-2006 10:10 PM |
Is my radar detector working? | Gr8fulDave | Car Audio, Video & Security | 8 | 11-10-2004 05:12 PM |
