Old 08-20-2003, 11:01 PM   #1
NYCshopper
Member#: 5126
Question Is my Engine Dying???
Is my engine dying??? (that is what a friend said)
It's gotten to the point where even my GF says that your car sounds funny....and she hates cars and rarely notices anything...
background info...
2000 RS (auto) w/ 42k miles
mods: Ganzflow CAI
Suby Sports Lighten Pulleys
Greddy EVO Catback Exhaust
past 2 days....noticed my engine not sounding right...
usually when i drive it's usually a steady sound
like...
rrrrrrrrrrrrrrrrrrrrrrRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRR
now it sounds like...
rr rr rr rr rr rr rr rr R R R R R R R R R R R R R R R R R R R R R
not a steady beat....
plus everything sounds lower.....my exhaust is no longer loud unless a mash the pedal.....it is acting weird...???
Don't know if it is bad gas (89 octane) since we just had a blackout, but i was on half tank today and just filled it up w/ 93 octane....just to be safe....
my warranty has expired....
also could it be my plugs? (last time i changed them was @ 20k miles w/ NGK plugs)
NYCshopper is offline   Reply With Quote
Old 08-21-2003, 02:53 AM   #2
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
How long have you had those mods on for?..If it hasn't been for long it sounds like the ECU adjusting to the new parts. And for that fact it just sounds/ looks from your post, just like a normal boxer idle....dunno...mabey someone else can enlighten you more?
CheezeWeezle is offline   Reply With Quote
Old 08-21-2003, 09:45 AM   #3
NYCshopper
Member#: 5126
thanks....
i have had the mods on for about 1 1/2 yrs....haven't done anything much....trying to save $$$....
Old 08-21-2003, 11:18 AM   #4
jdk
Member#: 26114
06 rs
Arrow
Check your spark plug wires and coilpack.
jdk is offline   Reply With Quote
Old 08-21-2003, 04:03 PM   #5
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
22k miles may be too long for your copper plugs, as well. What does your tailpipe look like? Running rich?
BlueTDimly is offline   Reply With Quote
Old 08-21-2003, 04:14 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
A note on your gas comment. Higher octane is not better gas. Putting higher octane in there will actually make it harder to detonate and your engine will not burn it off as quickly or cleanly.
You car is spec'd for 87, 89 is fine, but don't go with 91 or higher.
I'm not going to hi-jack this whole thread, but a search will give you a ton of info on octane and gas quality and all the nitty gritty you could want.
Like the others, I'm gonna guess you need to check your plugs. And check your air filter and fuel filter while you are at it. Any of those things could cause the vague problem you are describing.
Where did my color red go? Is my monitor dying? Brad Pittiful Off-Topic 29 08-26-2009 08:13 PM
Is my engine dying? dstan Normally Aspirated Powertrain 10 08-22-2007 09:29 PM
Is My Outback Dying? harthag Outback Forum 9 12-02-2003 08:59 AM
my engine died, help! no_rex_yet Service & Maintenance 16 01-31-2003 08:52 AM
Why is my car dying on startup? TimCat Newbies & FAQs 16 03-13-2001 12:57 AM
