![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 36697
E. Canada
Vehicle:2003 Impreza 2.5 TS |
as my first mods im looking into rear swaybar and a rear tower bar. I was wondering if these are good mods for a daily driver and if so how will they alter the preformance of my car? and whats a good/affordable company to get the parts from?
are these mods easy to install? and whats a good size for the rear swaybar 20mm? or more? need help!!!!
#2 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
If you are on stock tires, you may want to buy better rubber first.
By firming up the rear end with the bars, you may induce quite a bit of snap oversteer and ruin your whole day. |
#4 |
Member#: 32198
Vehicle:MY13 Impreza Limited 5-door hatchback |
From my personal experience, yes.. good and simple mods for everyday driving!
I had an adjustable 18-20-22mm rear sway bar installed first. I originally had it set at 18, which was the "safest" setting - neutral. But when I got used to that, I bumped it up to 20 - a little bit of oversteer, which is what it's currently set at. I dare not set it at 22 yet since I have a Forester and not sure how well I can control it. The rear sway bar feels like it reduces body roll, but I think it actually helps me to complete my turns quicker. The brand I have is Whiteline (baby-blue in color), and it seems suspectible to rust if you have snowy areas that use salt on the road. From what I was told, the rust is only on the surface and should be nothing major. The rear strut tower bar is sweet! My Forester felt so much stiffer, almost like driving a european car. Very secure in handling, but you might feel more of the roads irregularities, like bumps and potholes! I got this one from Whiteline also. Other than that, my Forester is pretty much stock, except for the grounding mod, front strut bar, K&N air filter, and Ganzflow (which I usually put on during the weekends and take off on rainy days). |
#5 |
Member#: 36293
Vehicle:03 OBS PS |
rear strut bar in a forester? i guess you dont put your seats down very often?
#6 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA 797 |
#7 |
Member#: 32198
ent2b: yes, rear strut bar in a forester, and nope.. don't really put seats down very often unless I got something huge to lug around, which is rare. exactly what satrya said.. the rear strut bar is very easy to remove without touching the bolts on the strut tops - probably in about 1 minute. I was also lucky enough to install the rear/sides/and front cargo nets on my first generation Forester and with the rear strut bar installed. I'll need to take some pictures and post here one of these days!
#8 |
Member#: 36697
E. Canada
I live in Quebec (canada for those who are scratching their heads) so I'm in snow for about half the year+ so will salt have bad effects on a sway bar? and will the a new sway bar make it harder to drive in snow?
#9 |
Member#: 40501
Vehicle:2005 Decathalon 21sp One WheelSeanPower |
Simple answer with regards to snow - yes. Body roll is ~good in snow, because it throws the weight to the outside builds traction there. Your car would probably drive better in the snow with no ASB at all. But, you probably have lots of snow driving experience by now, so once you learn how it feels, it'll probably only be a mild effect on your driving. If you can find a bar that goes 18-20-22, set it to low (18) in winter, then, when it dries out, bump it to 22 and enjoy the available oversteer.
I don't know the size of the stock rear ASB in an Impreza, only WRXs, but 18 is probably not much larger than stock, if at all... |
#10 |
Member#: 36697
E. Canada
Okay so which company has the best adjustable sway bar and for how much? what are some other manufacturers that have more affordable sway bars?
i know cobb has a sway bar and strut tower package is that good for the price? |
#11 |
Member#: 32198
Not sure what company has the best sway bar, but I can tell you that it seems like most folks would go for the Cusco brand, which is more expensive. Believe Cobb's bars are from Cusco as well. I picked Whiteline, because it was on sale.
#12 |
Member#: 25227
Vehicle:2006 Kodo Homage Dark Titanium |
Gekko-
I have the 17mm sway bar off my stock WRX wagon - I'm selling it very cheap and you can use it as a "starter" bar to see the effect. Your stock bar is 13mm, so this would be a nice little upgrade. If you decide you want stiffer for summer, you can get an adjustable for then and keep the 17mm for a stiffer winter ride. newayz....pm me for more details - my price wouldn't even dent your pocket much and I get a little more space in my garage and maybe a round of golf out of it...... |
#13 |
Member#: 25227
Oh, and one more thing - I upgraded my rear sway with an MRT adjustable 20-24, currently on the middle setting. In conjunction with MRT alloy endlinks and Whiteline rear strut, I am VERY tight in the rear -
, I mean I'm very stiff, ![]() , I mean, I like it ![]() ![]() |
#14 |
Member#: 32198
sonicblue: nice! that looks like a cusco. I'm afraid to set mine to 22. Have you ever have the rear slid out before, like when going hard through a corner or making a turn?
#15 |
Member#: 25227
I can't say I've ever REALLY pushed it into a turn, but I've certainly had a little fun and never even felt like it was trying to get away from me in the back end. Now if I set it to 24....???
#16 |
"Tekeli-li! Tekeli-li!"
Moderator Member#: 14145
NWIC
Vehicle:'02 WRX Cars? Stupid! |
I'm running a Cusco rear bar set to 22mm with Perrin solid droplinks as well as a Cusco carbon fiber rear bar with the V attachment. It definately stiffened up the rear of the car and improved the turn-in response. I also have a cusco front sway bar and the combination has proved very well balanced, just a hint of understeer at the corner exit. I'm not making enough power to break the Falken Azenis free yet.
Here's a pic of my strut bar setup. ![]() |
#17 | |
Member#: 24463
Vehicle:2003 Chevy S10 91 Hunduh Civic BASE |
#18 |
Member#: 38805
Vehicle:2007 BUILT STi urban Silver? |
Please forgive a newbie question,
Specifically, what YEAR and MODEL (WRX?) stock Subaru rear swaybar would be a bolt in replacement on my '01 Forester? From reading the above discussion, a 20mm bar sounds about right for my needs. Would you suggest buying aftermarket (brands mentioned above)? Will my stock (13mm bar) endlinks allow installation of a 20mm bar or will I need new links? Thank you for sharing your expertise! Last edited by 1modh; 11-29-2003 at 04:49 PM. |
#19 | |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
) With tire pressure 32F 29R the car would feel like it wasn't understeering but the back end would hope around turns. Then with 34F and 31R i just get a bunch of understeer, front tire dont want to grip. |
#20 |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
I have a stock 17 mm sway bar off a 2003 WRX wagon for sale as well if anyone is interested.
#21 |
Member#: 38805
Mike or Sonicblue-
I might be interested in the struts/springs from your WRX wagon to put on my '01 Forester. Let me know.. |
| Thread Tools | |
| Display Modes | |
| Genuine STi rear sedan strut tower bar | impreza2 | Suspension/Brakes/Handling | 19 | 01-02-2009 05:59 PM |
| FS: MI- Whiteline endlinks, Swaybars, Strut Tower Bar | bcristea | Suspension/Brakes/Handling | 25 | 11-08-2008 08:27 AM |
| FS: Rear sway, strut tower bars, endlinks, cusco brace, lightweight battery | SilverSubaab | NESIC Private Classifieds | 14 | 03-25-2007 02:45 PM |
| 02+ Front and Rear Cusco Strut tower bar w/ V-brace | keirnna | Private 'For Sale' Classifieds | 8 | 07-30-2005 02:04 PM |
| FS locally WRX front and rear Whiteline strut tower bars and HD end links 150 | Scooby do | Mid West Subaru Owners Club Forum -- MWSOC | 6 | 07-05-2002 06:28 PM |
