Welcome to the North American Subaru Impreza Owners Club Wednesday September 17, 2014
Old 08-21-2003, 07:27 AM   #1
GQ
Member#: 4830
12 DucatiSF/Abarth
Red/Nero
Default When are people changing timing belts?
I know that the recommended timing belt change is 105,000 miles, but when are people actually changing them. I am at 60,000 miles and just a little leary.
Rob
GQ is offline   Reply With Quote
Old 08-21-2003, 03:30 PM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
At the 96,000 km service.
Ken is offline   Reply With Quote
Old 08-22-2003, 01:21 AM   #3
Austin
Member#: 7089
The 105000 mile mark is to comply with California emission laws.
I'd do it at 60,000, especially if you can do it yourself. Timing belts are cheap insurance for an interference motor.
Austin is offline   Reply With Quote
Old 08-23-2003, 07:14 PM   #4
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
I changed mine at 111,000. I checked it against the new belt and the teeth all looked the same, no knicks, cracks, marks or anything. Both belts were of the same length so I don't believe there was any stretching. This is not to say that the old belt wouldn't have broken but I believe that who ever makes these belts makes them to last longer than what Subaru states in their owners guide.
I would say no later than 105,000 miles.
spshultz is offline   Reply With Quote
Old 08-24-2003, 02:18 PM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
did u pull the water pump too? how was it condition?
cuz i've done a few for honda's, and at 100k, the belt and pump seems too always look good, then again, these cars were maintain well
vile is offline   Reply With Quote
Old 08-26-2003, 07:13 AM   #6
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
I didn't pull the pump. I just didn't have the money at the time. Although if I ever need a pump it won't be that hard to do.
The pump looked good. No squeaking or lateral movement. It turned smoothly. I figure though in about another 25k - 50k it will need one.
I did have to replace the timing belt tensioner though. Mine was making that awful noise when first started. A loud tapping noise like the car had no oil. Noise is now gone.
Old 08-27-2003, 04:15 PM   #7
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
I was working for a dealer this summer and they talked about a few cases of timing belt failing between 100-110K km or 65-70K miles on those who recommend 160K km or 100K miles. wouldn't take a chance on these. mine will be changed at 100 000 km
NicEJ25 is offline   Reply With Quote
Old 08-28-2003, 01:26 PM   #8
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I have 92k miles on my 00RS. Timing belt will be done within the next month or so. Both miles and time take its toll on the belts. Figure cars that are driven into high miles in a short time are different than a here and there car with the same amount of miles over a longer period of time.
moogoob is offline   Reply With Quote
Old 08-28-2003, 02:11 PM   #9
wombatsauce
Member#: 31550
WorldRallyDirt
Default I would say..
If you have the major services/inspections performed on your car, and the timing belt breaks BEFORE the manual requires replacement - you should get a new engine. Seems like Subaru would have worked to prevent this happening - as it doesn't seem financially smart for them to suggest replacing a critical item at 100k miles that *could* fail at 60-70k miles.
-Jacob
wombatsauce is offline   Reply With Quote
Old 08-28-2003, 03:48 PM   #10
Pursuit
Member#: 38370
For what it's worth, dealers here replace at 60K mi. service.
Pursuit is offline   Reply With Quote
Old 12-23-2003, 09:43 PM   #11
Longitude
Member#: 2216
0000 Gee See
dented
So, I'm a bit confused with the terminology in the maintenance manuals.
Is the SUBARU "Camshaft drive belt" the same as a "Timing belt" of other vehicles, like Toyotas, Fords, etc.??
Your information is appreciated,
--Long
Longitude is offline   Reply With Quote
Old 12-23-2003, 10:07 PM   #12
Karl
Member#: 13110
Camshaft drive belt is the timing belt.
The belt that controls the timing, no?
Karl is offline   Reply With Quote
Old 12-23-2003, 10:25 PM   #13
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I have a CA-spec Legacy. The manual said change the belt every 105,000 miles instead of 60k, which is for non-CA cars. The dealer said the belts were all the same and should all be done at 60k.
Mike Wevrick is offline   Reply With Quote
Old 12-24-2003, 10:11 AM   #14
cvalle-sd
Member#: 420
2001 Cr-V
The dealer says 60k, because the dealer gets paid almost twice as often as if it's replaced at 100k. They have nothing to gain by telling you there's a longer interval. I'm not saying it's not a good idea to swap at 60k, but there's a definite bias, if the dealer's your source. I've been seriously thinking about both our cars, as my wife's OBS has~75k, and I'm just under 80k. How much are people paying for this, and is anybody DIY-ing it?
-I guess that'd be DIT.
I miss my SVX's timing chain - and it's prodigious power.
cvalle-sd is offline   Reply With Quote
Old 12-24-2003, 12:45 PM   #15
Full_Clip
Member#: 22218
Toyota recommends a timing belt change at 70k on their MAX service schedule. If you can do it yourself, do it sooner. Spark plugs are rated at 100k, but do you think they are deliver the same spark at 100k than 50k?
Full_Clip spends in advance.
Full_Clip is offline   Reply With Quote
Old 12-24-2003, 08:37 PM   #16
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Originally posted by cvalle-sd
The dealer says 60k, because the dealer gets paid almost twice as often as if it's replaced at 100k. They have nothing to gain by telling you there's a longer interval. I'm not saying it's not a good idea to swap at 60k, but there's a definite bias, if the dealer's your source. .
True, but I looked at the belts and they are exactly the same. It seemed crazy to leave it twice as long as recommended for non-CA cars.
Old 12-25-2003, 08:51 PM   #17
cptplt
Member#: 22439
02 WRX
black
IIRC I read once that the CA 105K change has something to do with their emissions regulations and nothing to do with when Subaru thinks it ought to be changed.
cptplt is offline   Reply With Quote
Old 12-28-2003, 12:09 PM   #18
ufoguy
Member#: 45179
2004 Forester XT
wannabe!
what have you paid for timing belt and water pump replacement at a dealership? what should i expect to pay at a dealer or elsewhere? i can't do it myself.
ufoguy is offline   Reply With Quote
Old 12-28-2003, 01:23 PM   #19
Siper2
Member#: 1134
2007 BMW 328xi wagon
60k seems awfully low mileage, to me. Most car manufacturers that I've seen say about 90k. Subaru is indeed a bit higher.
Oh well.
I replaced mine by necessity at about 65k or a bit more. (I forget.) My timing belt tensioner blew, so I told them to just replace the belt while they were at it. ("They" = Exeter Subaru in NH.)
-S2-
Siper2 is offline   Reply With Quote
Time for changing timing belt??? Elminster Service & Maintenance 3 09-06-2008 06:58 PM
Changing Timing belt & other belts at 95K Outback Help! Mad Aaron Normally Aspirated Powertrain 4 03-01-2007 04:24 PM
Changing timing belt. How's it come off? Wellhung Service & Maintenance 2 02-04-2003 08:46 PM
Changing Timing belt on 91 Legacy , need manual help ! Legacy Service & Maintenance 1 12-12-2001 05:54 PM
91 Legacy & changing timing belt.. who has a manual ? Legacy Normally Aspirated Powertrain 0 12-12-2001 03:13 PM
