Old 08-21-2003, 10:12 AM   #1
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default My car isn't fast.... :(
Ok this is weird. All you guys know that I got tuned this past monday. Last night I went to the track. I was using dry ice for the first few runs, and it seemed I wasn't getting enough boost. So I stopped using it, and I still wasn't getting enough boost. Basically I would normally boost like 1.1-1.2 in 3rd gear, but it was a lot lower than this. So I turned the ABC up 3.5 turns and it got me back to around what I was running before the tune. What is going on? Here are the dyno sheets, and the logs I took of the last three runs.
First, the best timeslip:
60 - 1.840
330 - 5.541
1/8 - 8.619
MPH - 82.15
1000 - 11.266
1/4 - 13.506
MPH - 100.46
Dyno sheet:
Next, the log for this run:
Code:
                   Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %                    deg   duty   deg    %   (OL)    V
   00  -0.6 0.7   0  00    00   14.8 +30.0    0.0 ECU.   +0.0 ECU.   0.7
 2716  -6.7 2.2   0  00    00   rich +11.8    8.0 ECU.   +0.0 ECU.   2.2
 2673  -6.7 2.2   0  00    00   rich +11.8   18.0 ECU.   +0.0 ECU.   2.4
 2981  -6.5 2.7  42  00    00   12.1 +31.7   14.0 ECU.   +0.0 ECU.   2.7
 3479  -6.7 1.9   0  00    00   15.8 +11.4    8.0 ECU.   +0.0 ECU.   2.3
 3340  -8.1 2.8  26  00    00   rich +32.0   14.0 ECU.   +0.0 ECU.   2.9
 4182  -5.5 3.0  55  00    00   16.1 +31.7   27.0 ECU.   +0.0 100.00 3.1
 4629  -5.9 2.0   0  00    00   rich +11.1   10.0 ECU.   +0.0 ECU.   2.6
 4761  -6.1 3.2  50  00    00   12.0 +30.5   34.0 ECU.   +0.0 100.00 3.3
 5583  -4.9 2.4   0  00    00   rich  +8.7   18.0 ECU.   +0.0 ECU.   1.9
 5200  -8.1 2.7   0  00    00   rich  +8.8   19.0 ECU.   +0.0 ECU.   2.8
 4844  -9.4 2.7   6  00    00   rich +38.6   19.0 ECU.   +0.0 ECU.   3.1
 4852  -9.8 2.0   0  00    00   rich +10.9    9.0 ECU.   +0.0 ECU.   2.3
 4952 -10.4 3.2  40  00    00   rich +31.8   31.0 ECU.   +0.0 ECU.   3.3
 5583  -6.9 3.6  79  10    00   12.3 +31.7   48.0 ECU.   -3.1 180.00 3.6
 4688  -1.8 3.9  96  30    00   rich +13.6   63.0 ECU.   -2.2 100.00 3.8
 4273  +3.5 3.8  99  60    00   rich +10.4   66.0 +22.8  -1.8 100.00 3.7
 3454  +9.0 3.7  98  80    00   rich  +8.4   55.0 +20.0  +0.1 100.00 3.6
 3353 +12.5 3.6  99  80    00   rich  +9.6   50.0 +20.0  +0.9 100.00 3.6
 3885 +14.1 3.6  99  80    00   rich +11.6   51.0 +22.0  -1.3 100.00 3.6
 4166 +14.3 3.8  99  80    00   rich +13.7   61.0 +22.8  -1.1 100.00 3.7
 4967 +13.9 3.9  99  70    00   rich +16.6   69.0 +26.0  -2.6 100.00 3.8
 5455 +13.5 4.0  98  70    00   rich +21.8   78.0 +26.0  -2.8 180.00 3.9
 5973 +12.9 4.1  98  70    00   rich +23.4   86.0 +26.0  -2.6 180.00 4.0
 6410 +12.3 4.1 100  60    00   rich +26.5   89.0 +26.0  -2.4 180.00 4.0
 6435  +9.4 3.0   0  00    00   rich +10.9   25.0 ECU.   +0.0 180.00 2.8
 6060  +4.1 3.1   0  00    00   12.2 +39.0   14.0 ECU.   +0.0 ECU.   3.6
 4522  +1.9 3.8  99  10    00   rich +22.1   52.0 ECU.   -2.3 100.00 3.6
 4403  +1.7 3.7  98  40    00   rich  -9.2   62.0 +23.9  -1.8 100.00 3.7
 4391  +4.5 3.8  99  70    00   rich  -8.2   68.0 +24.3  -2.0 100.00 3.8
 4597 +10.2 3.9  98  70    00   rich  -4.3   74.0 +24.7  -2.7 100.00 3.8
 4761 +13.3 3.9  99  80    00   rich +12.7   74.0 +25.4  -2.7 100.00 3.8
 4982 +14.1 4.0  98  80    00   rich +15.0   76.0 +26.0  -2.6 100.00 3.9
 5316 +13.9 4.0  98  70    00   rich +20.8   78.0 +26.0  -2.9 180.00 3.9
 5455 +13.9 4.1  98  70    00   rich +21.0   81.0 +26.0  -2.9 180.00 4.0
 5602 +13.3 4.1  98  70    00   rich +21.8   85.0 +26.0  -2.7 180.00 4.0
 5817 +13.5 4.1  98  70    00   rich +21.9   88.0 +26.0  -2.6 180.00 4.0
 6049 +13.7 4.1  99  70    00   rich +23.5   89.0 +26.0  -2.6 180.00 4.0
 6265 +13.3 4.1  98  70    00   rich +23.9   89.0 +26.0  -2.5 180.00 4.0
 6373 +12.9 4.1  98  70    00   rich +26.0   91.0 +26.0  -2.6 180.00 4.0
 6548 +11.9 4.2  98  60    00   rich +26.8   92.0 +26.0  -2.4 180.00 4.0
 6844 +11.5 4.2  88  60    00   rich +27.4   81.0 +26.0  -2.6 180.00 4.0
 6361  +6.4 3.0   0  00    00   rich +10.8   35.0 ECU.   +0.0 ECU.   3.1
 5717  +2.9 3.8  99  10    00   16.0 +28.5   61.0 ECU.   -3.1 ECU.   3.7
 4775  +2.3 4.0  99  20    00   rich +12.3   74.0 ECU.   -3.0 100.00 3.9
 4990  +3.1 4.0  98  60    00   rich +13.8   82.0 +25.8  -2.7 100.00 3.9
 5012  +8.6 4.0  98  80    00   rich +18.4   80.0 +25.9  -2.7 100.00 3.9
 4967 +13.7 4.1  98  90    00   rich +17.7   81.0 +25.9  -2.7 180.00 3.9
 5128 +15.1 4.1  98  80    00   rich +19.3   81.0 +26.0  -2.8 180.00 4.0
 5224 +15.5 4.1  98  80    00   rich +20.6   81.0 +26.0  -2.9 180.00 3.9
 5482 +15.1 4.1  98  80    00   rich +21.0   83.0 +26.0  -2.9 180.00 4.0
 5527 +14.3 4.1  99  80    00   rich +21.0   85.0 +26.0  -2.9 180.00 4.0
 5546 +14.3 4.1  98  70    00   rich +21.2   86.0 +26.0  -2.8 180.00 4.0
 5640 +13.7 4.1  98  70    00   rich +21.0   88.0 +26.0  -2.8 180.00 4.0
 5737 +13.7 4.1  98  80    00   rich +21.4   89.0 +26.0  -2.7 180.00 4.0
 5910 +13.7 4.1  98  80    00   rich +21.9   89.0 +26.0  -2.6 180.00 4.0
 5899 +13.9 4.1  99  70    00   rich +22.0   91.0 +26.0  -2.6 180.00 4.0
 6138 +13.7 4.1  99  70    00   rich +22.2   92.0 +26.0  -2.6 180.00 4.0
 6060 +12.9 4.2  98  70    00   rich +22.9   93.0 +26.0  -2.5 180.00 4.0
 6161 +12.5 4.2  98  70    00   rich +23.1   93.0 +26.0  -2.5 180.00 4.1
 6325 +11.7 4.1  98  60    00   rich +23.0   94.0 +26.0  -2.5 180.00 4.1
 6253 +11.5 4.2  98  60    00   rich +24.6   94.0 +26.0  -2.6 180.00 4.1
 6325 +11.7 4.2  98  70    00   rich +25.2   94.0 +26.0  -2.6 180.00 4.1
 6485 +11.7 4.2  98  70    00   rich +25.1   95.0 +26.0  -2.5 180.00 4.1
 6666 +11.9 4.2  98  60    00   rich +25.2   95.0 +26.0  -2.4 180.00 4.1
 6561 +11.9 4.2  90  60    00   rich +26.3   91.0 +26.0  -2.4 180.00 4.0
 5984  +7.2 3.0   0  00    00   rich  +8.6   22.0 ECU.   +0.0 ECU.   3.0
 4952  +3.7 3.9  98  10    00   17.8 +14.6   64.0 ECU.   -2.9 100.00 3.8
 4591  +3.5 4.0  99  30    00   rich +11.5   72.0 ECU.   -2.5 100.00 3.9
 4852  +4.7 4.0  98  70    00   rich +11.4   82.0 +25.0  -2.8 100.00 3.9
 4789 +10.0 4.0  99  80    00   rich +12.1   79.0 +24.8  -2.8 100.00 3.9
 4923 +14.7 4.0  98  80    00   rich +12.7   80.0 +25.1  -2.8 100.00 3.9
 4909 +15.5 4.0  98  80    00   rich +12.4   80.0 +25.2  -2.8 100.00 3.9
 4923 +15.3 4.0  98  80    00   rich +13.0   81.0 +25.6  -2.7 100.00 3.9
 4952 +15.3 4.0  98  80    00   rich +13.5   81.0 +25.7  -2.7 100.00 3.9
 4960 +15.1 4.0  98  80    00   rich +16.9   82.0 +25.9  -2.7 100.00 4.0
 5208 +15.7 4.0  98  80    00   rich +17.9   82.0 +26.0  -2.6 180.00 3.9
 5184 +15.5 4.0  98  80    00   rich +18.3   83.0 +26.0  -2.8 180.00 4.0
 5058 +15.9 4.1  98  90    00   rich +17.9   84.0 +26.0  -2.9 180.00 4.0
 5073 +15.7 4.1  98  90    00   rich +18.5   84.0 +26.0  -2.9 180.00 3.9
 5104 +15.5 4.1  98  80    00   rich +18.3   85.0 +26.0  -2.8 180.00 4.0
 5316 +15.9 4.1  98  80    00   rich +19.6   84.0 +26.0  -2.9 180.00 4.0
 5385 +15.7 4.1  99  90    00   rich +19.6   85.0 +26.0  -2.8 180.00 4.0
 5359 +15.5 4.1  98  80    00   rich +19.6   85.0 +26.0  -2.9 180.00 4.0
 5402 +15.5 4.1  71  80    00   rich +20.6   74.0 +26.0  -2.9 180.00 2.9
 5333  +9.8 3.0   0  00    00   rich  +8.8   18.0 ECU.   +0.0 ECU.   3.4
 4952  +3.5 3.3   0  00    00   20.6  +8.7   18.0 ECU.   +0.0 ECU.   3.2
 4585  -2.8 3.1   0  00    00   24.0  +8.7   18.0 ECU.   +0.0 ECU.   3.0
 4214  -8.9 2.9   0  00    00   24.0  +8.9   18.0 ECU.   +0.0 ECU.   2.8
 3903 -10.0 2.8   0  00    00   24.0  +8.9   18.0 ECU.   +0.0 ECU.   2.7
 3584 -10.4 2.6   0  00    00   24.0  +9.1   18.0 ECU.   +0.0 ECU.   2.6
 3330 -10.6 2.5   0  00    00   24.2  +9.3   18.0 ECU.   +0.0 ECU.   2.5
 3049 -10.6 2.5   0  00    00   24.0  +9.3   18.0 ECU.   +0.0 ECU.   2.4
 2791 -10.8 2.4   0  00    00   24.2  +9.4   18.0 ECU.   +0.0 ECU.   2.4
 2566 -11.0 2.3   0  00    00   23.7  +9.7   18.0 ECU.   +0.0 ECU.   2.3
 2319 -11.2 2.2   0  00    00   24.0  +9.8   18.0 ECU.   +0.0 ECU.   2.1
 2109 -11.4 2.0   0  00    00   24.0  +9.9   18.0 ECU.   +0.0 ECU.   2.0
 1868 -11.4 1.8   0  00    00   24.0 +12.3   18.0 ECU.   +0.0 ECU.   1.8
 1649 -11.6 1.7   0  00    00   23.7 +12.4   18.0 ECU.   +0.0 ECU.   1.6
 1417 -11.6 1.6   0  00    00   24.0 +12.8   18.0 ECU.   +0.0 ECU.   1.5
 1225 -11.8 1.4   0  00    00   23.7 +20.9    7.0 ECU.   +0.0 ECU.   1.4
 1183 -11.6 1.1   0  00    00   24.0 +21.1    2.0 ECU.   +0.0 ECU.   1.1
 1126 -11.6 1.2   0  00    00   23.7 +20.9    1.0 ECU.   +0.0 ECU.   1.2
 1041 -11.4 1.2   0  00    00   21.6 +21.1    1.0 ECU.   +0.0 ECU.   1.2
  891 -11.2 1.2   0  00    00   13.7 +21.2    1.0 ECU.   +0.0 ECU.   1.3
  817 -11.0 1.3   0  00    00   12.6 +21.6    1.0 ECU.   +0.0 ECU.   1.3
  806 -10.6 1.2   0  00    00   13.2 +21.5    1.0 ECU.   +0.0 ECU.   1.2
Any help, suggestions, etc, you can give would be greatly appreciated. Thanks!
ScreaminFast is offline   Reply With Quote
Old 08-21-2003, 01:16 PM   #2
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
I'm not sure what you were expecting but based on your dyno chart you're right where you should be. Your driving can be improved because with a 100mph trap you should be running about a 13.2.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-21-2003, 03:51 PM   #3
BOFslime
Member#: 23845
2015 FLAT SIX
what are your mods?
13.5 seems alright, according to the numbers you got on your dyno.
BOFslime is offline   Reply With Quote
Old 08-21-2003, 05:37 PM   #4
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Well, I was expecting just that, Phil, a 13.2 I'm not ripping on XXTuning at all. I thought they made a great tune. I had run a 13.57 with the MBC instead of the UTEC. The problem is that when I got to the track I was running significantly less boost, well at least it seemed. After turning the ABC 3.5 turns I was back down around that 13.5 range. I saw in the UTEC, there is a boost gain setting, is there a way I can just use that to turn up the boost? What is the ratio of boost gain to "turns on the ABC" ?
Also, since you said I can improve my driving, can you give me some suggestions on when to shift or if my launch should be improved?
XXTuning also gave me a race map, which was to be used with 1-2gals of c-12 or c-16. I was hoping to get 12s on that map, but i'm not sure.
I wonder if it was the dry ice cooling down the IC too much...
My Mods:
GFB Pulleys
Perrin Intake
GTspec V2 Header/up-pipe
Deadbolt P&P TD04 w/ light clip
Invidia DP
JIC 505Ti Catback
Denso IK22 Plugs
Thanks guys, keep the help coming!
Old 08-21-2003, 06:06 PM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Wrap your log info above in a [ c o d e ] [ / c o d e ] block (don't put spaces in like that example though). It will make the columns line up properly. It makes my eyes bleed as it is.
jblaine is offline   Reply With Quote
Old 08-21-2003, 06:48 PM   #6
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Code:
I just wanted to try out the code tags
That's pretty cool
MAD REX is offline   Reply With Quote
Old 08-21-2003, 09:17 PM   #7
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
yea i just changed it to a code tag.....thanks
now help me
Old 08-22-2003, 10:52 AM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Re: My car isn't fast.... :(
Well, I'll try to help, but I really think the analysis of your log belongs in Proven Power Bragging. I'd don't believe your car is slow. That said, here we go, and you should know now that I am not a racer:
Code:
So there's your launch. A 1.84 60' is pretty damn good as far as I know.
Code:
End of first gear too early? Talk to racers.
Code:
End of 2nd gear.
Code:
End of 3rd gear
Code:
Here's my suggestion: Go back to the track, leave the dry ice alone, and use 16" wheels with either stock or lower profile tires if you aren't already. Where to shift for best results, I do not know.
That said, I think 13.506 is damn fine unless you care to launch at higher RPMs and shift 1-2 with no mechanical sympathy.
You've proven you have a 13.2-ish car. Getting there without shredding something is a different story. I'd be satisfied as Phil suggested, but what do I know.
Old 08-22-2003, 05:07 PM   #9
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
ok cool, thanks man!
Old 08-23-2003, 12:39 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I was expecting a higher trap speed, but thats still a good time..
Is your boost map open loop or closed? Someone told me that the boost gain setting only worked with the CLB map, but I'm not 100% on that, its probably in the manual if I looked though.. I made a CLB map finally for my car and the boost gain worked just fine, i lowered the number to get a quicker response but with slight spiking initially.
edit: You might want to calibrate your TPS to reach 100% because otherwise you are not getting into your 100% boost map column.
PaulRex is offline   Reply With Quote
Old 08-23-2003, 08:36 PM   #11
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Good point paul....thanks man
Old 08-24-2003, 12:11 PM   #12
Giamilton
Member#: 8002
2013 WRX 5dr/Abarth
WR Blue/Nero
hey just a quick note, same thing with me, low speeds low boost, guess what? Loose IC hose clamp! Factory had it loose and I had to tighten it 10 turns of a screwdriver just to snug it! then another 4 to tighten it!
I have never had my IC off the car so Subaru left it loose from the factory! I knew something was wrong but couldn't pinpoint it untill I was trying to fly around PIR yesterday and noticing my boost would hit my target then drop to 11 psi at wot in 4th.
So moral of the story is check your hose clamps etc, before you mess with the tuning, I had actually spent hours programing and trying to sort it out when all I needed was a screwdriver!
Good Luck!
Giamilton is offline   Reply With Quote
Old 08-25-2003, 09:52 PM   #13
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Good Luck!
Thanks i'll definitely check everything, but i'm pretty sure it ended up just being the fact that the dragway is at a higher altitude and it was extremely humid that night.
Also, I'm getting some knock at 4500-5000 rpm in all gears, but it goes away with some octane booster....which should I do? Always get octane booster, or retard the timing 1 degree and add some fuel??
Old 08-26-2003, 01:06 PM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Don't always use octane booster, that stuff isn't so good.
You have several options if you are consitently getting knock in one area. After you've determined that it's not a bad tank of gas..
You can decrease timing one degree around where it knocks; Your only running a peak of 26 degrees I think from looking at your log so it's not terribly high IMO.
You can add .2 of fuel in the area it knocks
You can lower the boost values in the boost map alittle too.
Here is a log I did last night. My ic was alittle heatsoaked so the boost pressure was about 1psi lower than normal but the car still felt great.. I think we have similar fuel maps.
Code:
DATA1
       psia  V   %                    deg   duty   deg    %   (CL)    V
   00  -0.4 0.7   0  00    00   14.8 +30.0    0.0 ECU.   +0.0 ECU.   0.7
  704 -11.0 1.2   0  00    00   14.7 +13.5    1.0 ECU.   +0.0 ECU.   1.2
  715 -11.0 1.2   0  00    00   14.7 +14.6    1.0 ECU.   +0.0 ECU.   1.2
  719 -10.8 1.2   0  00    00   14.7 +14.2    1.0 ECU.   +0.0 ECU.   1.2
  720 -10.8 1.2   0  00    00   14.7 +13.0    1.0 ECU.   +0.0 ECU.   1.2
 1536 -10.6 1.6   0  00    00   14.9 +22.9    3.0 ECU.   +0.0 ECU.   1.5
 1530 -10.6 1.5   0  00    00   14.9 +23.2    3.0 ECU.   +0.0 ECU.   1.6
 1548 -10.6 1.6   0  00    00   14.8 +23.9    3.0 ECU.   +0.0 ECU.   1.6
 1587 -10.4 1.7   2  00    00   14.8 +27.3    3.0 ECU.   +0.0 ECU.   1.9
 1629  -9.8 1.9   4  00    00   14.8 +33.3    5.0 ECU.   +0.0 ECU.   1.9
 1716  -8.9 1.9   4  00    00   14.5 +15.4    5.0 ECU.   +0.0 ECU.   2.0
 1827  -7.9 1.9   4  00    00   15.0 +32.9    6.0 ECU.   +0.0 ECU.   2.0
 1936  -7.3 2.0   4  00    00   14.8 +33.8    6.0 ECU.   +0.0 ECU.   2.0
 2015  -7.1 2.0   4  00    00   14.4 +35.3    6.0 ECU.   +0.0 ECU.   2.0
 2171  -6.5 2.2   8  00    00   13.6 +34.9    8.0 ECU.   +0.0 ECU.   2.2
 2305  -6.1 2.2   7  00    00   15.0 +36.2    9.0 ECU.   +0.0 ECU.   2.2
 2415  -5.5 2.2   9  00    00   14.9 +37.0    9.0 ECU.   +0.0 ECU.   2.2
 2506  -4.9 2.3   9  00    00   14.9 +36.2   10.0 ECU.   +0.0 ECU.   2.3
 2694  -4.9 2.3   9  00    00   14.7 +34.7   10.0 ECU.   +0.0 ECU.   2.3
 2759  -5.1 2.3   9  00    00   14.6 +34.4   10.0 ECU.   +0.0 ECU.   2.3
 2898  -5.5 2.3   9  00    00   14.6 +34.4   11.0 ECU.   +0.0 ECU.   2.3
 3024  -5.7 2.3   9  00    00   14.5 +34.7   11.0 ECU.   +0.0 ECU.   2.3
 3106  -5.9 2.3   9  00    00   14.6 +35.4   11.0 ECU.   +0.0 ECU.   2.4
 3220  -6.1 2.4   9  00    00   14.7 +35.4   11.0 ECU.   +0.0 ECU.   2.4
 3356  -5.9 2.4  14  00    00   14.7 +35.4   89.0 ECU.   +0.0 ECU.   3.0
 3654  -4.0 3.1 101  10    00   14.5 +31.1   26.0 +23.0  -3.0 380.00 3.1
 3977  -1.2 3.4 101  20    00   14.6 +27.3   33.0 +22.0  -2.9 380.00 3.4
 4403  +2.5 3.7 101  40    00   13.5 +18.4   54.0 +23.6  -2.9 380.00 3.7
 4916  +7.2 3.9 101  60    00   rich +22.2   73.0 +25.9  -2.7 380.00 3.9
 5446 +10.2 4.1 101  70    00   rich +24.0   82.0 +26.0  -2.4 400.00 4.0
 6082 +12.1 4.1 101  70    00   rich +24.6   91.0 +27.0  -2.2 430.00 4.0
 6561 +12.7 4.2 101  70    00   rich +28.3   92.0 +27.9  -2.1 430.00 4.1
 6218  +9.8 1.8   0  00    00   12.5 +11.1   31.0 ECU.   +0.0 ECU.   1.9
 5621  +3.7 2.0   0  00    00   22.9 +11.2   31.0 ECU.   +0.0 ECU.   2.1
 4990  -2.4 2.3  23  00    00   24.5 +13.6   16.0 ECU.   +0.0 ECU.   3.3
 3591  -4.3 3.5 101  10    00   17.8 +22.9   35.0 +23.0  -2.9 380.00 3.4
 4016  -2.6 3.7 101  30    00   13.1  -3.5   49.0 +22.0  -2.9 380.00 3.6
 4438  +3.5 3.8 101  60    00   rich  -2.8   66.0 +23.6  -2.9 380.00 3.8
 4585 +10.0 3.8 101  80    00   rich +17.9   67.0 +24.2  -2.8 380.00 3.8
 4708 +12.9 3.9 101  80    00   rich +20.4   68.0 +24.9  -2.8 380.00 3.8
 4938 +14.3 3.9 101  80    00   rich +21.9   72.0 +26.0  -2.4 380.00 3.9
 5089 +14.5 4.0 101  80    00   rich +23.1   77.0 +26.0  -2.3 400.00 3.9
 5376 +14.5 4.1 101  80    00   rich +22.5   83.0 +26.0  -2.2 400.00 4.0
 5564 +14.7 4.1 101  80    00   rich +23.3   87.0 +26.0  -2.2 400.00 4.0
 5899 +14.3 4.1 101  70    00   rich +24.6   91.0 +26.4  -2.3 400.00 4.0
 5931 +13.9 4.1 101  70    00   rich +23.8   91.0 +26.5  -2.3 420.00 4.0
 6138 +12.9 4.2 101  70    00   rich +24.5   93.0 +27.0  -2.2 430.00 4.1
 6349 +12.3 4.2 100  70    00   rich +26.9   93.0 +27.0  -2.1 430.00 4.1
 6472 +12.5 4.2 101  70    00   rich +27.4   94.0 +27.0  -2.0 430.00 4.1
 6361 +11.5 3.7   0  00    00   rich +10.9   30.0 ECU.   +0.0 ECU.   1.9
 5858  +6.4 1.9   0  00    00   13.8 +11.1   30.0 ECU.   +0.0 ECU.   2.1
 5402  +1.7 3.4  98  10    00   24.2 +15.2   35.0 +26.0  -2.6 400.00 3.5
 4775  -0.2 3.8 101  10    00   13.0  -3.2   62.0 +25.6  -2.8 380.00 3.8
 4714  +0.8 4.0 101  50    00   rich +19.4   76.0 +25.1  -2.8 380.00 3.9
 4990  +7.4 4.0 101  80    00   rich +20.6   76.0 +25.4  -2.7 380.00 3.9
 5065 +12.1 4.0 101  80    00   rich +22.0   74.0 +26.0  -2.4 380.00 3.9
 5136 +14.3 4.0 101  80    00   rich +21.6   78.0 +26.0  -2.4 400.00 3.9
 5136 +14.5 4.0 101  80    00   rich +21.8   81.0 +26.0  -2.3 400.00 4.0
 5274 +14.3 4.1 101  80    00   rich +21.4   84.0 +26.0  -2.2 400.00 4.0
 5316 +14.7 4.1 101  80    00   rich +22.1   86.0 +26.0  -2.2 400.00 4.0
 5537 +14.3 4.1 101  80    00   rich +22.6   87.0 +26.0  -2.2 400.00 4.0
 5678 +14.7 4.1 101  80    00   rich +23.0   88.0 +26.0  -2.2 400.00 4.0
 5678 +14.5 4.1 101  80    00   rich +23.7   89.0 +26.0  -2.2 400.00 4.0
 5767 +14.5 4.1 101  80    00   rich +23.3   90.0 +26.1  -2.2 400.00 4.0
 5941 +14.7 4.1 101  80    00   rich +23.4   90.0 +26.5  -2.1 420.00 4.1
 5920 +14.3 4.2 101  80    00   rich +24.1   91.0 +26.8  -2.1 420.00 4.1
 6006 +14.1 4.1 101  80    00   rich +24.4   93.0 +27.0  -2.0 430.00 4.1
 6207 +13.7 4.2 101  70    00   rich +24.6   92.0 +27.0  -2.2 430.00 4.1
 6184 +13.1 4.2 101  70    00   rich +24.6   93.0 +27.0  -2.2 430.00 4.1
 6289 +12.9 4.2 101  70    00   rich +27.2   93.0 +27.0  -2.1 430.00 4.1
 6447 +12.5 4.2 101  70    00   rich +27.0   94.0 +27.0  -2.1 430.00 4.1
 6397 +12.1 4.2 101  70    00   rich +27.5   94.0 +27.1  -2.0 430.00 4.1
 6548 +12.1 4.2 101  60    00   rich +27.4   94.0 +27.1  -2.0 430.00 4.1
 6788 +11.9 4.2 101  70    00   rich +27.9   93.0 +27.7  -2.0 430.00 4.1
 6872 +11.9 4.2 101  70    00   rich +27.7   93.0 +27.6  -2.1 430.00 4.1
 6277  +8.0 1.9   0  00    00   rich +10.8   31.0 ECU.   +0.0 ECU.   1.8
 5727  +2.1 2.1   0  00    00   21.4 +11.1   31.0 ECU.   +0.0 ECU.   2.1
 5282  -2.6 3.4 101  10    00   lean +16.0   35.0 +26.0  -2.6 400.00 3.5
 4714  -4.5 3.8 101  10    00   12.6 +20.3   57.0 +25.2  -2.8 380.00 3.8
 4782  +0.2 4.0 101  50    00   rich +17.1   76.0 +25.2  -2.8 380.00 3.9
 4837  +7.0 4.0 101  80    00   rich +17.6   78.0 +25.3  -2.8 380.00 3.9
 4866 +12.7 4.0 102  80    00   rich +20.6   74.0 +25.4  -2.6 380.00 3.9
 4975 +15.5 4.0 101  90    00   rich +21.2   75.0 +25.6  -2.5 380.00 3.9
 5035 +15.3 4.0 101  80    00   rich +22.1   75.0 +26.0  -2.3 400.00 3.9
 5005 +15.1 4.0 101  80    00   rich +19.6   80.0 +25.9  -2.5 380.00 4.0
 5050 +14.9 4.0 101  80    00   rich +19.6   81.0 +26.0  -2.3 400.00 3.9
 5167 +14.5 4.0 101  80    00   rich +21.0   82.0 +26.0  -2.3 400.00 3.9
 5128 +14.7 4.1 101  80    00   rich +19.6   83.0 +26.0  -2.3 400.00 4.0
 5200 +14.9 4.1 101  80    00   rich +21.3   83.0 +26.0  -2.3 400.00 4.0
 5184 +15.1 4.1 101  80    00   rich +20.9   86.0 +26.0  -2.2 400.00 4.0
 5307 +15.5 4.1 101  90    00   rich +20.9   86.0 +26.0  -2.2 400.00 4.0
 5428 +15.3 4.1 101  80    00   rich +21.2   87.0 +26.0  -2.2 400.00 4.0
 5437 +15.7 4.1 101  80    00   rich +21.1   88.0 +26.0  -2.2 400.00 4.0
 5473 +15.3 4.1 101  80    00   rich +21.8   88.0 +26.0  -2.2 400.00 4.0
 5518 +14.5 4.2 101  70    00   rich +23.0   87.0 +26.0  -2.4 400.00 4.0
 5509 +14.9 4.2 101  80    00   rich +22.4   89.0 +26.0  -2.2 400.00 4.1
 5518 +14.7 4.1 101  90    00   rich +22.5   89.0 +26.0  -2.2 400.00 4.0
 5649 +15.1 4.1 101  80    00   rich +22.8   90.0 +26.0  -2.2 400.00 4.1
 5621 +15.9 4.1 101  80    00   rich +23.3   90.0 +26.0  -2.2 400.00 4.0
 5668 +15.3 4.2 101  80    00   rich +23.6   89.0 +26.0  -2.2 400.00 4.0
 5707 +14.9 4.1 101  80    00   rich +23.1   90.0 +26.0  -2.2 400.00 4.0
 5737 +15.1 4.2 101  80    00   rich +23.0   90.0 +26.0  -2.1 420.00 4.1
 5787 +14.5 4.2 101  80    00   rich +23.3   90.0 +26.0  -2.1 400.00 4.0
 5787 +14.9 4.2 101  80    00   rich +23.0   91.0 +26.3  -2.1 420.00 4.1
 5827 +14.3 4.2 100  80    00   rich +23.2   70.0 +26.6  -2.1 420.00 3.1
 5952  +8.6 1.7   0  00    00   12.2 +11.1   28.0 ECU.   +0.0 ECU.   1.9
 5420  +2.5 2.1   0  00    00   23.4 +11.2   28.0 ECU.   +0.0 ECU.   2.1
 4866  -4.3 2.1   0  00    00   lean +11.4   28.0 ECU.   +0.0 ECU.   2.1
 4391 -10.2 2.1   0  00    00   lean +11.4   28.0 ECU.   +0.0 ECU.   2.1
 3954 -11.0 2.0   0  00    00   lean +11.4   28.0 ECU.   +0.0 ECU.   2.0
 3523 -11.0 2.0   0  00    00   lean +11.6   28.0 ECU.   +0.0 ECU.   1.5
 3223 -10.6 1.9   0  00    00   24.5 +11.7   28.0 ECU.   +0.0 ECU.   1.9
 2866 -10.4 1.8   0  00    00   lean +11.8   28.0 ECU.   +0.0 ECU.   1.8
 2532 -10.4 1.8   0  00    00   lean +12.2   28.0 ECU.   +0.0 ECU.   1.7
 2182 -10.4 1.7   0  00    00   24.5 +12.2   28.0 ECU.   +0.0 ECU.   1.7
 1885 -10.4 1.6   0  00    00   lean +12.3   28.0 ECU.   +0.0 ECU.   1.6
 1582 -10.4 1.6   0  00    00   lean +12.8   28.0 ECU.   +0.0 ECU.   1.6
 1299 -10.4 1.5   0  00    00   lean +12.7    3.0 ECU.   +0.0 ECU.   1.4
 1375 -10.0 1.4   0  00    00   lean  +9.9    2.0 ECU.   +0.0 ECU.   1.3
 1353 -10.2 1.2   0  00    00   23.7 +12.6    2.0 ECU.   +0.0 ECU.   1.3
 1204 -10.4 1.3   0  00    00   16.4 +16.6    1.0 ECU.   +0.0 ECU.   1.3
 1112 -10.6 1.3   0  00    00   16.2 +20.9    1.0 ECU.   +0.0 ECU.   1.3
 1055 -11.0 1.3   0  00    00   16.7 +20.9    1.0 ECU.   +0.0 ECU.   1.3
 1018 -11.0 1.3   0  00    00   15.7 +20.9    1.0 ECU.   +0.0 ECU.   1.3
my car isn't starting Wookie768 New England Impreza Club Forum -- NESIC 39 02-06-2010 04:51 PM
The one night my car isn't in the driveway.... Rys-rex New England Impreza Club Forum -- NESIC 11 05-06-2007 03:47 PM
My car isn't cool anymore. rjp New England Impreza Club Forum -- NESIC 18 04-02-2006 09:23 AM
My car isn't starting.. Alternator? Bahumut Normally Aspirated Powertrain 26 08-31-2001 09:20 PM
My car isn't for sale N E more (relieved) zaidallas Texas Impreza Club Forum -- TXIC 3 07-11-2001 07:05 PM
