Old 08-21-2003, 01:36 PM   #1
svx_commuter
Member#: 41373
1997 Impreza
Default Back-up Light Switch
I think I have a problem with the backup light switch. The back-up lights sometimes work and sometimes don't and sometimes blink.
Can I replace the back-up light switch on the 5spd box?
Is there any adjustments?
Thanks
svx_commuter is offline   Reply With Quote
Old 08-25-2003, 11:04 PM   #2
svx_commuter
Member#: 41373
1997 Impreza
Hi all I fixed the backup light switch. It's the switch on the driver side closest to the engine. A 3/4" wrench fits it well. The connector is next to the brown one on the back of the engine passenger side. After disconnecting the connector I jumped the leads for the switch and sure enough the backuplights worked. Then I removed the switch, after getting the wire un-hooked. There was a thick washer, oh about 1/8" thick between the switch and the tranny, I replaced it with a thinner washer made of flashing and it works great. The switch must have worn over time. This fixed moved the switch deeper into the trans.
See ya..........
NY: Neutral Position and Back-up Light switches PolarisSnT Drivetrain 3 01-26-2010 07:57 AM
Where is the Back-up Light Switch??? seowitz Service & Maintenance 13 10-17-2001 12:52 AM
Back Up Lights! CRAZY KEN Interior & Exterior Modification 3 10-15-2001 04:33 PM
Extra Back-up Lights BrysImpreza Interior & Exterior Modification 13 07-05-2001 03:24 PM
back up lights Ragstylz Technical Forum Archive 7 08-13-2000 09:22 AM
