Old 08-21-2003, 02:17 PM   #1
rdrandal
Member#: 11852
2002 Impreza WRX
Default Removing UTEC - What effect on ECU?
I have a PDE Up-Pipe and TurboXS TB Exhaust. I've been running their UTEC for about two weeks. I've decided to purchase the new STI and am getting my WRX-02 back to almost stock condition. If I remove the UTEC and keep the up-pipe and TB exhaust will I have any problems with the stock ECU?
rdrandal is offline   Reply With Quote
Old 08-21-2003, 02:21 PM   #2
dust12
Member#: 13417
Your ECU will work just fine.
dust12 is offline   Reply With Quote
Old 08-21-2003, 02:27 PM   #3
rdrandal
Member#: 11852
2002 Impreza WRX
So I shouldn't have any CELs or the car dying on the interstate?? Thanks
Old 08-21-2003, 02:42 PM   #4
dust12
Member#: 13417
You may get a CEL - but the car will run fine.
If you do get a CEL - either put the upipe and TB back to stock or you can do the resistor mod which will fool the stock ECU.
P.S. I am currently running my car with the vishnu uppipe and turboback without engine management and my car works just fine. I did have a CEL for the cat, but it disapeared after a couple hundred miles.
Old 08-21-2003, 03:07 PM   #5
rdrandal
Member#: 11852
2002 Impreza WRX
I appreciate your reply. I think that I should be OK. I don't have the original stock Up-pipe and don't really want to locate a used one. I plan to get the UTEC on E-Bay this week-end. Thank you.
Old 08-21-2003, 08:28 PM   #6
SysRq
Member#: 31347
() support your
/\ sysadmins
If you are not getting CELs now, you won't be getting them without the UTEC as the UTEC does absolutely nothing to prevent them. Do yourself (and the next owner) a favor and leave the uppipe in.
SysRq is offline   Reply With Quote
Old 08-25-2003, 05:51 AM   #7
amazingchinc
Member#: 41859
2003 WRX
Yellow
are you selling your utec...how much do you want for it?
amazingchinc is offline   Reply With Quote
Ok so what will a FMIC do to my spool and what effect on power output? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-01-2004 06:46 PM
Does ECU tampering (e.g. Cobb, Vishnu) have the same effect on Autos? thrillho Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-04-2004 05:06 AM
effect on pollution from removing/replacing cats? no_rex_yet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 04-18-2003 03:51 PM
New Information on Inductions Systems and their effect on ECU calibration DAVID-ECUTEK Engine Management & Tuning 5 03-09-2003 11:07 AM
Cat removal effect on emissions quynce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 03-04-2003 04:36 PM
