Old 08-19-2003, 02:33 PM   #1
tellravi
Member#: 40409
Default Timing Belt 02 WRX
All,
I may get some Engine Work done to my car. I have 29K miles on the car, would you recommend I change the TB anyway.
If YES, would you guys recommend any after market ones which are stronger? PE sells one.
Finally, is there anything else I should change while the tech has the engine apart.
Any recommendations
tellravi is offline   Reply With Quote
Old 08-19-2003, 05:14 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The service interval on the timing belt is 105K miles. At 29K it should still be like new. If it's going to be off/apart inspect it and change it if you want, but a new stock one is all you need if you do decide to change it.
Old 08-19-2003, 06:29 PM   #3
tellravi
Member#: 40409
Default is it 105k or 60k for 02 WRX
Thanks for your reply
Old 08-19-2003, 06:42 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Definitely 105K replacement interval with inspections every 30K. The same goes for the accessory drive belts although those are easy to inspect more frequently and cheap enough to change well before 105K.
Old 08-20-2003, 12:30 PM   #5
Precision Tuning
Member#: 38696
We recently had an 02 wrx that had the belt jump at 26k. If its off, change it. All you get is 3 teeth before the valves are damaged, so better safe than sorry. You can get an STI belt from the dealer for the WRX. It is slighty noisier, but stronger.
Rich
Precision Tuning is offline   Reply With Quote
Old 08-20-2003, 12:32 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
What was the cause for the belt jumping? I'd assume something went wrong with the tensioner to allow that to happen since the belt itself should still be in excellent condition at 26K. If the belt actually failed it would be unusual.
Old 08-21-2003, 12:47 PM   #7
Precision Tuning
Member#: 38696
Tensioner had not "failed", but was replaced as a precautionary measure. This car had an 18g on it, and was overboosted a time or two from what the cust said. I had a chat with AZ Scoobie, and he had some good possible scenarios, including speed shifting and a lack of a guide on the intake cam on the drivers side. Seeing a timing belt actually broken is very rare, they tend to jump rather than break, sometimes getting chewed in the process. SO basically, keep an eye on them.
Rich
Old 08-21-2003, 03:57 PM   #8
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
What is the easiest way to inspect the belt without disassembling everything? Just take off the timing belt cover?
BlueTDimly is offline   Reply With Quote
brand new sti timing belt for wrx 02-07 Speedster329 Engine/Power/Exhaust 3 02-17-2010 07:33 PM
New Sti timing belt for wrx 02-07! Speedster329 Tri-State Area Private Classifieds 0 01-25-2010 12:37 PM
ej257 timingbelt tensioner, belts+timing belt cover, wrx intake manifold+throttlebody White 2.5rs Private 'Wanted' Classifieds 1 07-19-2005 01:11 PM
Need Timing belt covers, WRX! AK'S REX Private 'Wanted' Classifieds 2 08-20-2004 07:25 PM
Procedure to set timing on 02 wrx engine? Aspen_2.5RS Service & Maintenance 5 09-01-2003 10:50 PM
Message Board Statistics All times are GMT -4. The time now is 11:36 PM.
