Old 08-21-2003, 10:19 PM   #1
Mancini
Member#: 20726
Default Major fueling problem
What can cause excessive richness?
Fuel pressure is same as always. I'm running stock ECU with safc2 and itc. My front o2 was ruined with all the carbon. I took it out and am running without it. Wideband is showing ~10.8 at idle and low 9's on boost. It basically never rises above 12. All 4 plugs are showing signs of excessive rich conditions.
So something is seriously wrong. TPS and MAF are working correctly (safc verified). What else could it be?
I've been playin with this since Monday and I'm seriously stumped...
Mancini is offline   Reply With Quote
Old 08-23-2003, 05:22 PM   #2
Mancini
Member#: 20726
I went to Autozone and had all my CEL's pulled and nothing unusual.
I picked up a new front O2 and it's tstill running in the high 10.x:1 ratio anytime you step on the gas. It's almost as if it goes to full throttle (fueling wise) if you touch the gas at all. I've checked the wiring and connections for the sensor and everything is fine so I'm fairly confident that o2 isn't the problem.
Could any other sensors cause this? Or could my ECU be messed up? Anyone have some input or something I can try?
Old 08-23-2003, 08:28 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Are your settings on the S-AFC zeroed out?
Really, there are only a few things that could cause it... changed injectors (larger) without correction, higher fuel pressure, or bad settings on engine management. Even without an O2, it shouldn't run that rich.
Old 08-23-2003, 10:35 PM   #4
Mancini
Member#: 20726
I haven't touched a thing on the SAFC since before I had the engine out and I checked all the settings and they are the same. Injectors are the same and fuel pressure is the same.
Do you think timing could cause excessive richness...since I did replace my timing belt. The odd thing is it pulls into open loop I get the exact EGT I did before, so it's definately a closed loop problem.
I dunno...I'm stumped, I think it's time to take it to the dealer
major major install problems please have help me out! kefalonitis Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-13-2009 12:08 PM
Major Fuel Problem: Going Crazy!! emsmap Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 04-29-2008 12:16 PM
Major MY98 problems. Anyone else with an MY98 have clutch/tranny problems? Sean Warranty Issues & SOA Problems 20 11-03-2001 10:33 PM
Major car problem.... plez help jeffg General Forum Archive 7 01-18-2001 07:15 PM
